lg42lb5500 losses the settings when turn off
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    In the above model, the TV works normally, but when I turn it off and on, it takes me by itself to the settings menu, asking for language, channels, etc.
    and as soon as I finish the settings it works normally when I close it again the same
    I have done a factory reset without success
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: lg42lb5500 losses the settings when turn off
    Update the firmware and it should be fine
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      thanks a lot sir
      or else i have flash eprom issue ?
        • 12276
        • U.S.
        there's some crap here about settings but it might not pertain to your model: https://community.bt.com/t5/Archive-...f/td-p/2112868
        • Xristakis795
          • Mar 2021
          • 162
          • Greece
          thanks sir i will try it
          • Xristakis795
            • Mar 2021
            • 162
            • Greece
            can you help me to find the right firmware for my model just to be sure ?
            lg42lb5500-za
              • 12276
              • U.S.
              this seems to be the lg site in Greece, maybe choose support, software and firmware, put model number in, if available follow instructions precisely, being around 7 years old they may have taken the firmware off of their site, seems they all like to remove firmware from their sites as soon as they can, I think it's for the usual reason, they don't want you to fix your tv, they want you to buy another from them, if you don't see it maybe you can get firmware by contacting them by email etc: https://www.lg.com/gr
              • yokoono
                • Apr 2010
                • 505
                The last one is Version 03.50.14 from the year 2015
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Link to firmware. https://gscs-b2c.lge.com/downloadFil...4339-b1-a4.zip
                  • ducky29
                    • Dec 2015
                    • 369
                    • Europe
                    The set should have a toshiba nand. If the firmware from diif dosent fix the problem ill send you the firmware later. Please let me know.
                    • Xristakis795
                      • Mar 2021
                      • 162
                      • Greece
                      thanks a lot for your answers
                      mr diif your file for install it with usb i can follow the steps of bellow video ?
                      https://www.youtube.com/watch?v=NQLvqbtAriU
                      • ducky29
                        • Dec 2015
                        • 369
                        • Europe
                        Yes extract the zip file. Make a folder called LG_DTV put the epk file inside and then plug in the usb stick into the tv.
                        • Xristakis795
                          • Mar 2021
                          • 162
                          • Greece
                          • Xristakis795
                            • Mar 2021
                            • 162
                            • Greece
                            its working
                            thanks a lot for the help
                            • RetroComputingGrotto
                              New Toy UNI-T UTi260B - What Settings?
                              by RetroComputingGrotto
                              I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
                              After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
                              I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
                              09-02-2025, 08:36 AM
                            • pajdek
                              Lenovo Y700-17ISK turn on and off
                              by pajdek
                              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                              09-20-2023, 02:49 AM
                            • RdeveLabs
                              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                              by RdeveLabs
                              To all the members here...
                              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                              05-05-2025, 04:59 AM
                            • masoksian
                              Dell latitude e7470 not turn on .power buton on off and Run Power problem
                              by masoksian
                              I am dealing with the problem of turning on and off my Dell e7470 notebook.
                              The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                              The system does not turn on, there is no post.
                              I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                              The problem continues in the same way.
                              I tried to turn on the Fn key, nothing came to the screen....
                              02-15-2025, 12:08 PM
                            • dqtech
                              lenovo x240 nm-a091 wont turn on
                              by dqtech
                              i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                              board number VIUX1 NM-A091 REV:1.0...
                              02-07-2024, 01:57 AM
