Help diagnosing faulty Samsung TV 32' UE32D5000
  • DarkGT
    • Dec 2022
    • 9
    Greetings. That's my first post here, I hope this is the right section for my question.
    I have 11 years old Samsung TV that develop backlight issues week after I decided to update the firmware from 1011 to 1028. Not sure if related considering the age.
    At first the backlight would blink and then would start working fine, if I turn off and on the tv the issue will re-appear. I dissemble it and found that none of the caps show any discoloring, leaks or signs for problems. Sound and screen would work fine, only the backlight will blink once every 5 sec or so. I tried to disconnect the main board and check if the screen would stay on with the power supply board as suggested in the internet tutorials, but the screen would do the same thing - blink.
    After a while it got worse and the backlight barely turns on now. I checked the connector voltage and on pin 1 it's around 350-370v and it's jumping between that with every blinking cycle. The most strange thing is that the screen would blink more often when I'm probing with my multimeter, suggesting powerboard issue? From the holes I can see that the whole length of the screen lights up, so maybe the LED strips are okay?
    I can't disassemble the screen, there seems to be plastic screen with grid matrix that look like leds or some kind of diffuser on the last layer that's glued on the frame.
    Any hope that it's fixable in economical way? Can't find any LED backlights strips or powerboards in my country for this model of TV panel.
    Open to suggestions, any jumper like JP854 that would force the screen light to stay on?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8339
    Re: Help diagnosing faulty Samsung TV 32' UE32D5000
    Turn the backlights down to 50%. If there is a problem with the LEDs it should stay on. Any mod you do to force the backlights to stay on, just results in the LEDs dying earlier and then it will stay off.
    • DarkGT
      • Dec 2022
      • 9
      Not sure if I can do that, since I can't see what's going on on the screen, the flashlight doesn't help much. I would really want to rule out if is backlight or powerboard issue, anything on the board that I can test to verify? I'm newbie, currently reading the articles troubleshooting that are posted in the forum.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4498
        • Italy - Milan
        Suspected bad caps on the leds elevator circuit or bad soldering on the power diode of same circuit
        • DarkGT
          • Dec 2022
          • 9
          Thanks for the reply Davi, no bad solder joins, all solid and shiny. I did some testing and probing. All diodes beep on only one direction as they should. There is this small black inductor I guess that have very low resistance I have link with image and readings I wrote on it, you can zoom in and tell me if I'm right to suspect it. https://imgur.com/a/7F4jjUx
          Schematics of the power board
          BTW where is " leds elevator circuit" located? Mainboard or powerboard? If is on the powerboard you can tell where to look based on the picture I shared.
          Thanks in advance, it's my only tv and the budget is thigh right now.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4498
            • Italy - Milan
            The second choice is bad caps, check/replace those on the secondary around 100v..
            third choice maybe inside led pool there are bars connected betweem each one, connection can be loose..
            • nomoresonys
              • 12305
              • U.S.
              check voltages of cnm803, neg. probe on metal chassis, check in standby[plugged in power off] take note, leave probes in place, power on take note, report both conditions here for every pin, example power on, standby 0, powered on 3.3 volts, example of testing: https://www.youtube.com/watch?v=XH9GfkGQX1I
              • nomoresonys
                • 12305
                • U.S.
                try heating the caps on the powerboard for a couple minutes with a hairdryer, heat the electrolytic caps right by there connector then try the tv, DON'T wait til it cools down, try it while its still hot, if no joy, try heating the rest of the caps including the blue ones, no joy, try heating the whole board.
                • DarkGT
                  • Dec 2022
                  • 9
                  Thanks for the suggestion nomoresonys. Here is the readings I took.
                  OFF (stand by) Power ON all DC voltages measured
                  - 0.6v - 13v
                  - 0.63v - 12.95v
                  - 0.64v - 12.94v
                  - o.64v -12.94v
                  -0.01v - 0.000 (I hope that's the ground pin)
                  - 0.01v - 5.54v
                  - 0.00v - 5.54v
                  I'm not having hair dryer, so I try tomorrow to think of a way to safely heat it.
                  The backlight should stay on with the main board disconnected, right? My model is not some exception?
                  Thanks for the suggestions so far guys, keep them coming .
                  Edit: Video I recorded of the weird behavior when voltage of the backligh is measured https://youtu.be/2nxef4nPk4w
                  Last edited by DarkGT; 12-30-2022, 01:26 PM. Reason: Info being added that would help resolving the issue.
                  • nomoresonys
                    • 12305
                    • U.S.
                    can you list all 14 pins according to the map beside it, like power-on, A5, gnd etc, need to know all of them since I have no picture.
                    • nomoresonys
                      • 12305
                      • U.S.
                      also basic checks, check all diodes and resistors on top of board for starters, google is your friend if needed.
                      • Rajnhl
                        • Oct 2018
                        • 94
                        • India
                        try changing capacitors in backlight section, even if they appear good , they become weak over time.
                        • DarkGT
                          • Dec 2022
                          • 9
                          Thanks CapLeaker Davi.p nomoresonys Rajnhl for the help troubleshooting so far. I think Davi was closest to the actual cause of the problem which is : (dramatic pause)....
                          Bad led chips on the backlight strips, 3 on the left side and 4 of the right bar side. I have dissemble the panel and beat that glue, super thigh screws etc.etc, and got to two led strips model 2011SVS32 _456K _H1 _1CH. When turn on the backlight would flash the left completely (or at least that how it looked), and only half of the right bar. When tested in diode mode with my multimeter as I wrote - 7 in total are the bad light chips.
                          I guess that would explain this odd behavior? Maybe the power supply sense a short or too high resistance and would briefly try to power them on, sense problem and turn them off ?
                          I would take more that a month for a replacements to arrive (if at all those chinese sites aren't reliable). Is there any way to bypass the bad led chips like with resistor to fix the flow of electricity, yes I know it's stupid, but will be temp fix until I get replacements.
                          • nomoresonys
                            • 12305
                            • U.S.
                            ok, yep thats what usually goes wrong, after installing new backlights be sure to turn them down if you can, to as low as you can stand, makes them last much much longer. They lasted 11 whole years, that's a pretty good run.
                            • DarkGT
                              • Dec 2022
                              • 9
                              I will, the replacement will likely not be an OEM, so better safe...
                              Also I found a repair video on my model that does a resistor modification by adding another one in series to the existing one, the repairman does that to reduce the power to the leds, right? https://www.youtube.com/watch?v=zOTDUOh_3e0 , could I do the same or there is no point doing it?
                              Also I'm wishing a Happy new year to everyone reading this
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                9 out of 10 tvs i have for repair lately are led issues pity china is taking so long to ship replacements to the uk
                                • nomoresonys
                                  • 12305
                                  • U.S.
                                  yes, great mod and not very hard, just need to make sure you deal with the right resistor/s.
                                  • nomoresonys
                                    • 12305
                                    • U.S.
                                    this smart youtuber does a lot of them: https://www.youtube.com/watch?v=dPu_BeKVONI
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4498
                                      • Italy - Milan
                                      If i understand well right bar is connected in series with left one and holds a single faulty led, it works 50% so this tricks the protection, modifying the resistors is not useful when replacing all leds, neither refuncing much the brightness, i think.. leds faults are due to spikes..
                                      • nomoresonys
                                        • 12305
                                        • U.S.
                                        ^^^I disagree and so do many others, a lot of led early death is caused by being over-driven, which the mod addresses, people are NOT doing it just for fun. TomTechTod is a pro and knows exactly WHAT AND WHY he's doing it, the end.
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • kotel studios
                                          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                          by kotel studios
                                          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                          08-06-2025, 02:07 AM
