vizio M3D550KDE Black & white picture
  • yankys
    yanky
    • Feb 2012
    • 139
    HI everyone Pick up this 55" VIZIO tv that only plays in black and white picture doesn't matter what inputs HDMI or apps, but all the menus are in color, if you're on Netflix everything in color until you play any show. I'm thinking main board if so, can the board be reflowed to try and correct this?
  • yankys
    yanky
    • Feb 2012
    • 139
    Re: vizio M3D550KDE Black & white picture
    Here some pictures of how it's doing.
    • CapLeaker
      Leaking Member
      • 8177
      First I’d do a factory reset and see if the latest firmware is flashed.
      • yankys
        yanky
        • Feb 2012
        • 139
        Ok let me check in on how to do this and I'll post my results.
        • yankys
          yanky
          • Feb 2012
          • 139
          I did the factory reset and still no difference not seeing a way to check for update or a way to do a update on this model.
          • diif
            • Feb 2014
            • 6978
            • England
            A faulty HDMI IC maybe ?
            • yankys
              yanky
              • Feb 2012
              • 139
              So replacement of the main may fix it?
                • 12201
                • U.S.
                I think so, seems like a mainboard issue, not sure exactly where on board tho.
                • CapLeaker
                  Leaking Member
                  • 8177
                  hmm... press the picture mode button on the TV remote and go through all of them settings. Some report having luck just by flashing the latest firmware on it and fixing the issue. check the hdmi ports on the main board.
                  • yankys
                    yanky
                    • Feb 2012
                    • 139
                    I've went through all the picture menus no change, I would like to try to flash the latest firmware but I’m not sure where to find it or how to flash it to this TV. as I’m not seeing a firmware update Area anywhere in the menu any help on this will be greatly appreciated it
                      • 12201
                      • U.S.
                      see if that helps, guess they want you to put your serial # in there: https://support.vizio.com/s/firmware...language=en_US
                      • yankys
                        yanky
                        • Feb 2012
                        • 139
                        I'll give this a try and post my findings thank you
                        • KYBOSH
                          • Oct 2011
                          • 581
                          • Unknown
                          Would an HDMI IC affect in-app video playback as well?
                          OP says it doesn't matter what the source is.
                          At first glance I figured its the BGA IC on the mainboard. Ive read somewhere how a visible degradation of picture quality when it comes to to perform high resolution video playback is one symptom that the BGA IC is having issues.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            It's a known issue, it's unlikely to be the same BGA ball(s) cracking every time, leaving the menus in colour but the video in B&W.
                            With a minimal description of testing and no photo of the mainboard it was an educated guess. If Netflix is through the app and not HDMI then I guess it isn't the HDMI IC.
                            • yankys
                              yanky
                              • Feb 2012
                              • 139
                              Yes Netflix thru the app and any app on the TV is in color you can scroll through the menu apps in color but as soon as you play a program it turns to black and white
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • sgcampion
                                Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
                                by sgcampion
                                My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
                                In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
                                10-24-2023, 09:39 AM
                              • csmith
                                Vizio D50u-D1 Powers up no picture
                                by csmith
                                I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                issue. Set will power up with remote but not power off....
                                07-11-2025, 11:52 AM
                              • ca2014mp2
                                Vizio M3d550kde Black and White screen menu has color
                                by ca2014mp2
                                So I have a Vizio M3d550kde around 2011 per date on a sub board. The tv works well except that the input on HDMI inputs 1-4 are all displayed in black and white - (other inputs not tested and unknown if they are good or not.) -where the menu selection and initiation screen show full fine color. I was thinking ok fine Main board replacement, but then I thought wait a minute, the menu display comes from the Main board. Any thoughts or suggestion for repair?
                                I did a factory reset just to make sure someone didn't change a setting that would allow this weird behavior from the tv.
                                05-06-2019, 04:07 PM
                              • hcinne
                                Dell G15 ryzen edition black screen 2 amber 1 white
                                by hcinne
                                I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                07-23-2024, 07:56 AM
