Samsung un70nu6900 power supply issue
  • yankys
    yanky
    • Feb 2012
    • 139
    Re: Samsung un70nu6900 power supply issue
    let me check into this and i will let you know.
    • lotas
      • Jan 2016
      • 4621
      • Russia
      Ok.
      • yankys
        yanky
        • Feb 2012
        • 139
        let me do these steps and ill post my results.
        • yankys
          yanky
          • Feb 2012
          • 139
          I haven't tried the tape as of yet, but I unplugged the main ribbon cables one at a time again. And tv stay on with blue screen but no picture or sound no matter which ribbon cables undone.
          • yankys
            yanky
            • Feb 2012
            • 139
            I unplugged the top ribbon cable from the main board turn the tv on, I plugged the ribbon cable back in while the tv was on now it works like it should. have not tried turning off and back on, what do you think the problem could be giving the Fack that its working like new with what I did?
            • CapLeaker
              Leaking Member
              • 8190
              Use a WHITE eraser and clean the contacts on the ribbon cables.
              • yankys
                yanky
                • Feb 2012
                • 139
                #27
                I’ll try this thank you.
                • yankys
                  yanky
                  • Feb 2012
                  • 139
                  #28
                  I tried to White eraser no luck I replace the ribbon cables with other cables I had for Samsung TV and I get the same results, off on off on but if I replicate what I did I let the TV boot up then plugging in the top ribbon cable I get a picture with no problem. If I turn the TV off and try to just turn it back on it goes back to the off on off Any ideas what I can do to try to fix this.
                  • yankys
                    yanky
                    • Feb 2012
                    • 139
                    #29
                    Thank you Lotas and Capleaker for the help still having the problem described above. If the was panel was bad I wouldn’t think the picture would be perfect when I get to work.
                    • yankys
                      yanky
                      • Feb 2012
                      • 139
                      #30
                      It stay on with no picture when disconnecting one cable at a time if I leave top cable undone until it completely on then put it back I get the picture with no problems. Can leave on all day it doesn't turn off, when I turn it off I have to redo the cable again but will go right back to working.
                      • CapLeaker
                        Leaking Member
                        • 8190
                        Well... well... well... I guess she is trying to be a lil b*tch! You probably going to need a 100mhz oscilloscope and a DMM. You can check the LVDS pairs on the main board with the oscilloscope and flick the menu on and off and look for changes on the o-scope screen. Make sure that the main board sends all the appropriate voltages and signals. Then I would check the long skinny board on the bottom of the TV and check for voltages there. You have to figure out which of them 2 boards causing the problem. Note everything down on paper working vs non working. Go from there.
                        It seems like the TV recovers if you use a specific ribbon. That should tell you on which side of the panel the problem is.
                        I don't think that it is a panel itself. Maybe take the long skinny board with the tab bonds out in a way so you can inspect it. But be real careful not to damage or rip the tabs.
                        A main board is no problem to get, but the long skinny board with the tab bonds only comes with the panel
                        • lotas
                          • Jan 2016
                          • 4621
                          • Russia
                          #32
                          https://www.youtube.com/watch?v=E6gkuTP7Lt0
                          • yankys
                            yanky
                            • Feb 2012
                            • 139
                            #33
                            I just seen your post I have to out but as I’m back I’ll look at what you sent thank you
                            • yankys
                              yanky
                              • Feb 2012
                              • 139
                              #34
                              I did the tape on the ribbon cable got it to come on with the remote but the color on the left side is washed out. If I unplug the ribbon cable and plug it back in without the tape I’ll get a full colorful picture no problems as long as the TV is powered up prior to hooking up the top ribbon cable.
                              • yankys
                                yanky
                                • Feb 2012
                                • 139
                                #35
                                I want to thank everyone for help with this, I have came to The resolution that is the chip in the LCD board as I previously posted TV works perfect when I unhook the cable and plug it just before the TV boot up. I had a TV with a cracked screen same model Changed all the boards and cables just to see it had the same results.
                                • lotas
                                  • Jan 2016
                                  • 4621
                                  • Russia
                                  #36
                                  Yes, Samsung has recently had a lot of defective panels, they die very often, as well as backlight problems.
                                  • Cookybaby
                                    Samsung UN60ES6500FXZA Power Supply Issue
                                    by Cookybaby
                                    Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                    I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                    Make: Samsung
                                    Model: UN60ES6500FXZA
                                    Power Supply P/N: BN44-00525A
                                    Symptoms: The TV was...
                                    08-20-2023, 12:26 PM
                                  • lp20th
                                    Samsung Plasma TV Power Supply Issue
                                    by lp20th
                                    I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                    11-28-2023, 10:28 AM
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                    by sam_sam_sam
                                    07-01-2024, 06:34 AM
