PC Restarting/ Shutting off abruptly.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: PC Restarting/ Shutting off abruptly.
    Who = how
    Sorry I'm defrosting the fridge between posts..
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Originally posted by Oklahoma Wolf
      Sorry, but this is not correct. They both do. I don't test for PF, but that doesn't mean I can't
      The units that can actually fool them are few and far between. I've had only two in three years I think. Usually when the efficiency numbers are off in comparison to the 80 Plus test results, it means I have a test equipment failure to go find.
      Had it happen not long ago when the Diablotek "1050W" unit blew out on the primary side. It fried the current measuring shunt resistor inside the Brand. From there on out, everything read light until I replaced the resistor. The KAW was ok... it has a beefier shunt.
      That said, these aren't the most accurate meters in creation (5% for the KAW, 2% for the Brand), which is why I'm upgrading soon. The Brand is currently more accurate than ever, but it's still not quite the caliber of test equipment I need. Especially now that I'm using the Tektronix scope.
      Nope
      4-1850 has an "N/A" under Power Factor.
      http://www.energytools.com/PwrMeterSpecs.htm
      Kill-A-Watt doesn't measure PF it calculates it which means it assumes standard phase angles and PFC will spoof it.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Originally posted by 370forlife
        Show me the example of when I did that. I want to see this.
        I already did. - Twice I think.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Originally posted by mur
          New PSUs WITH APFC nowadays go up to 90% efficiency.
          No.
          They -measure- that much because APFC spoofs the watt-meter on the input.
          The "A" in APFC = "Active" which means they are constantly changing the phase angles.
          - Changing phase angles is beyond the measuring capacity of those basic watt-meters people are using to claim efficiency and draw curves.
          - Flat efficiency curves are bull shit.
          - Dr Seuss
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            Alright, believe whatever crackpot theories you want to that an entire industry standard certification is wrong. I'll just believe the right thing.
            Oh, and for the last time, APFC does not change the phase angles. It reduces or almost eliminates the harmonics, so voltage looks more like a sinewave. I.E more like a resistive load.
            • mur
              • 21
              #86
              Originally posted by PCBONEZ
              No.
              Ok. Maybe the real efficiency is 89%, but not as low as you think.
              Let's take this example.
              you have a power supply outputing (at the output, into the computer) 150W of power. It's 75% efficient, therefore consuming 200W of power, correct? Now lets say it has a PF of .65. This means the 200W that it is actually consuming (active power,) is only 65% of what the power supply is drawing from the wall total. The total apparent power the psu is drawing from the wall is 330W.
              So you have a non-PFC psu that is consuming 200W of active power. Apparent power is 330W. PSU is dissipating 50W of heat, while additional 130W of heat is dissipated in mains wires coming to your house and into the PSU.
              You say if you add APFC to this PSU apparent power will be converted into active power so not the electric company, but customer pays for it.
              That would mean another 130W of heat would be dissipated inside the psu! Whole PSU would be dissipating 180W of heat! Does that sounds realistic to you? That would be hell of noticable if not by power meter, by your hand if you put it in front of exhaust fan grille!
              • Oklahoma Wolf
                • Dec 2005
                • 353
                #87
                Nope
                That's because it has no display for it. It does take it into account. See the actual Brand specs here:
                I've had it remain accurate when the KAW wasn't. It's not infallible, but until I start encountering the spoofers every week it's just not something I worry about. Two in three years is not a problem. When I start getting 100% efficiency every week, I'll know something's up.
                At any rate, this is not a big enough deal for me to be willing to argue over it. Don't have the time. The IDRC CP-350 should be here by end of month... I doubt I'll find a unit that can fool that one.
                • Newbie2
                  • Sep 2005
                  • 885
                  I agree with this gentleman.
                  My gaming PC:
                  AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                  ASUS M4A77TD AMD 770 AM3 Motherboard
                  PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                  G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                  TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                  WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                  ASUS Xonar DG 5.1 Channel PCI sound card
                  Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                  Antec Three Hundred Mid-Tower Case
                  Microsoft Windows 10 Pro 64-bit
                  Microsoft Windows 7 Ultimate SP1 64-bit
                  • mur
                    • 21
                    #89
                    Thinking of what I said before, what would even be the amount of heat dissipated in kilowatt PSUs! Put one computer that needs a kilowatt PSU in each room in your house and you don't need your central heating anymore! Oh, and make sure every PSU has APFC.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Which it accomplishes by putting harmonics into the Phase Angles.
                      Making the angles dynamic instead of static.
                      The only way to 'move' a harmonic to clean up a sine wave is to shift it's phase angel.
                      Watt meters can't parse dynamic phase angles.
                      It makes them read wrong.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        If you took 1000 or so PSU's all with the same load and connected them all to a diesel generator with a watt-meter on the output...
                        A UK type watt-meter would read different than a typical US type watt-meter.
                        If you do the same thing with two set-ups being equal except that one has PFC PSUs and the other has identical PSUs without PFC ...
                        ... The set-up without PFC will use less fuel.
                        UK watt-meters would read more in the PFC set-up partially because PFC spoofs the meters in the power company's favor [the whole reason the UK made PFC Law] and partly because they waste more energy.
                        I don't know where that would balance out with US type watt-meters, but regardless, the generator for the PFC set-up will use more fuel.
                        PFC is NOT GREEN.
                        It exists because UK power companies have UK politicians in their pockets.
                        All the advertising HYPE about it being green is to convince you it's a benefit to you,, and it isn't..
                        - Dr Seuss
                        • Behemot
                          • 4845
                          • CZ
                          #92
                          I must be insane then.
                          I'm a retired nuc plant operator.
                          Also been an electric plant operator on a 2 Gigawatt 4160v grid.
                          Good to know. By the way, I am beginning my study for the same position next school year But still, our electrical grid is terrible (maybe not so much to have 6 hours black-outs every day, but the wind and solar power plants are bringing us to this position). So I still believe not only energetic companies profit from PFC's. I did not ever believe it is so green (damn, to be honest, I fuck on everything green, the more they talk about it the more I act otherwise), but I knew it is good for electrical grid because there is less load to it. That's the purpose if this regulation in the first place.
                          So what's your purpose on this? You're trying to convince us wattmeters read wrong, everybody lie us and real efficiency is 60 %? So how is that most 80 Plus PSU's have small heatsinks and 12cm fans spinning up to some 1000 RPM when they have so small efficiency?
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Here in AZ [I'm in one of the hot parts] all I do to heat the house in the winter is kick-on a few extra PC's.
                            - Dr Seuss
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Can't compare old designs with new. They are too different.
                              People think efficiency begins and ends at the PSU which is a load of rot. A large reason it's a load of rot is that PFC jerks with the watt-meter they determine PSU efficiency with while reducing the actual efficiency of the complete system - which goes all the way back to the power plant.
                              It's called "the big picture" [you will soon here that a lot if you are going into power plants]. - - The people flippin' me crap can't get past the little picture. That's pretty normal when the biggest system they work on fits on a desk and it's always the same basic thing.
                              - Dr Seuss
                              • Behemot
                                • 4845
                                • CZ
                                #95
                                I see.
                                I think everybody more educated know that only by measuring you're actually changing the experiment, so of course the PSU has impact on wattmeter and otherwise, together with all components inside case affect PSU and otherwise. But still I think it's still just small change under the known measurement error, so few %. On the other hand you talk as this was error in terms of tens %.
                                • mur
                                  • 21
                                  #96
                                  Well, you say that the reason why new PSUs have 90% efficiency in reviews is because APFC spoofs wattmeters. But if it spoofs them that way so they show less power than they really use, power companies are on loss not profit as you said in another post.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    ->UK<- power meters read more.
                                    ->UK<- power companies forced PFC into law.
                                    Modern PSU's are more efficient .. but..
                                    They are not more efficient -> due to PFC.
                                    - They are more efficient due to -> OTHER improvements.
                                    A flat efficiency curve IS BOGUS.
                                    - It's flat due to PFC spoofing the meter dynamically.
                                    I've repeated that same thing about 5 times now.
                                    Try reading things in context next time.
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      I see.
                                      It was enough for UK power companies to force PFC into Law.
                                      Anyone that says PFC is a benefit to YOU is a liar.
                                      Yet, that's what the ads claim, isn't it...
                                      - Dr Seuss
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        #99
                                        The stuff you see in ads is bull shit.
                                        You see it so many times you believe it.
                                        Guess what.
                                        SATA 3.0 doesn't any faster than SATA 1.5.
                                        [Except for maybe the first 4-5 milliseconds.]
                                        Same thing.
                                        I'm sure you are going to play away this graph I post below by saying something like "The software Anandtech uses is incorrect, SATA 6 is only faster the first few milliseconds because I said so"
                                        <snip>
                                        Originally posted by Anandtech
                                        Pair the C300 with a 6Gbps controller and it has a clear advantage - you get a 20% increase in sequential read speed from the C300.
                                        Source; http://www.anandtech.com/show/3812/t...realssd-c300/3
                                        • bhvm
                                          • Mar 2010
                                          • 52
                                          • India
                                          #100
                                          Folks, Come over here to my place....
                                          The electricity board employees themselves admit that meters are set about 30% faster than real value.
                                          After, The rule is simple.. to eradicate the bad.. Punish the good.
                                          Sure, Electricity losses and theft is a major problems here, and government wants to recover the losses by overcharging the genuine payers with 30% extra.
                                          Enjoy your taxes, they're being used to formulate 'These' policies.
                                          • rumpumpel1
                                            ThinkPad T460p keeps restarting instead of shutting down
                                            by rumpumpel1
                                            I have a ThinkPad T460p that keeps restarting instead of shutting down. The culprit is the LAN: if it is disabled in the BIOS, the problem is solved. I have already replaced the LAN chip (WGI219LM) twice, done CleanME, flashed another BIOS. Unfortunately all without success. What else can I check?
                                            04-28-2024, 12:26 PM
                                          • Maniackk
                                            Yoga 530-14ARR NM-B781 Ryzen 3 2200 – overheating and shutting down under load
                                            by Maniackk
                                            I’ve got a stubborn patient here. The laptop powers on and works, all components like the screen, keyboard, touchpad, etc. are functional. The issue is that it heats up very quickly under load (within a few minutes up to 95°C) and then shuts down shortly after. Subsequent attempts to turn it back on right after a “hot shutdown” result in it shutting off within a few seconds. Interestingly, if I enter the BIOS, it can stay there for 2 days without shutting down (most likely due to low CPU load and low temperatures).
                                            The cooling system has been cleaned, thermal...
                                            09-03-2025, 09:32 AM
                                          • dkneyle
                                            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                            by dkneyle
                                            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                            02-01-2022, 02:08 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • abhishekkumar1902
                                            Huntkey HK340-72FP SMPS shut on load above 2 amps
                                            by abhishekkumar1902
                                            I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                                            I have checked the following:
                                            1. All output caps are OK, and all output rails read correct voltages at no load
                                            2. All output diodes are OK
                                            3. NTC is ok
                                            4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                                            5. No short in main switching MOSFET
                                            6. All other components...
                                            12-18-2022, 09:52 AM
