ThinkPad T460p keeps restarting instead of shutting down
  • rumpumpel1
    • Jul 2019
    • 155
    • germany
    I have a ThinkPad T460p that keeps restarting instead of shutting down. The culprit is the LAN: if it is disabled in the BIOS, the problem is solved. I have already replaced the LAN chip (WGI219LM) twice, done CleanME, flashed another BIOS. Unfortunately all without success. What else can I check?
  • mon2
    • 14332
    Check the voltage to ground of LANWAKE#. Confirm the pull-up resistor @ R243 is present and is ~4k7 ohms. Confirm there is a 3v3 (VCC3M) on pin 2 of this resistor.
    If LANWAKE# = 0 volts, then the logic board will 'wake up' since this is an active low signal which is denoted by the '#' suffix in the netname.
    • rumpumpel1
      • Jul 2019
      • 155
      • germany
      the resistance of RL5118 (pull-up resistor of LAN_WAKE#) is 3,7 kOhm (measured in place). VCC3M is present and LAN_WAKE# never drops to 0.
      In BIOS the option WAKE by LAN is disabled.
      • mon2
        • 14332
        Confirm the same setting within Windows.
        How to enable Wake on LAN - ThinkCentre (M Series) and ThinkStation (P Series) - Lenovo Support US
        • rumpumpel1
          • Jul 2019
          • 155
          • germany
          The measurement of the LAN_WAKE# signal was taken in Windows. During the whole shutdown and during the following startup the Signal was always 3,3V.
          I do not want to use the wake on LAN feature. It is disabled in BIOS intentionally.
          • rumpumpel1
            • Jul 2019
            • 155
            • germany
            I changed the GbE chip and now everything works as expected.
            • mon2
              • 14332
              So the WGI219LM LAN controller was replaced for a 3rd time and now it is working? Did you source the part from a different vendor this time? Perhaps the previous ones were fakes?
                Lenovo ThinkPad T460p Notebook T Specification for Upgrade or Repair
                This specification for the Lenovo ThinkPad T460p Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460p boardview and T460p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                09-06-2024, 06:24 AM
                09-06-2024, 05:54 AM
                09-06-2024, 05:40 AM
              • Simplebeans
                MacBook Pro A2338 keeps restarting when attempting to install macOS
                by Simplebeans
                I have just got in a MacBook Pro A2338 which was initially displaying the Apple logo followed by an explanation mark in a circle as described here:- https://support.apple.com/en-gb/102164.
                After some error messages attempting to revive and restore the machine via DFU mode i have finally got the machine revived however now the issue seems to be when attempting to install macOS Sequoia via a bootable USB installer or via macOS recovery the machine just keeps freezing and restarting before the installation is complete, usually the installation has just started or is mid way trough before...
                08-10-2025, 11:04 AM
