Ryobi 18v BCL14181H MY2015 charger dead
  • SKP
    • Jan 2022
    • 18
    • Finland
    I have this EU-version of Ryobi charger which doesn't show any lights when plugged in, but the green led blinks after disconnecting it from the wall socket.
    I started troubleshooting by reading this thread https://www.badcaps.net/forum/showth...ighlight=ryobi but I guess it is for an older model.
    I found couple of SOT-23 mosfets/transistors which look pretty bad (Q5, Q3). Cannot see any markings on them, does anyone know what they are and could these be the reason why the charger doesn't work? Similar components can be found on the PCB with markings 1AM and 702…
    No voltage on BAT+/BAT-, but main cap has 330ish volts and 50V 470uF cap on the secondary side has 30V after unplugging so at least something is getting from primary side to secondary side?
    I'll clean the board tomorrow with IPA and start measuring diodes, resistors, caps etc but can someone give me some guidance what to measure and what to look for?
    Thanks!
    • 31067
    Re: Ryobi 18v BCL14181H MY2015 charger dead
    start by resoldering the main transformer and r9
    they have bad joints
      Is the fuse (red body) F2 (right next to ZD4) OK?
      It is an always on power supply that is why you are getting 30V on the cold side.
      • SKP
        • Jan 2022
        • 18
        • Finland
        Thanks guys, I'll check the joints. Fuses are ok, forgot to mention it..
        • SKP
          • Jan 2022
          • 18
          • Finland
          The markings on Q3 and Q5 are now visible, both are 1AM. And they look ok.
          While resoldering I managed to burn one of the pads on the EC2 near R9… now it has a very dodgy looking repair, but it works. Maybe my ThermoPasty flux gel wasn't the correct option and that's why the pad got burned, don't know.
            • 31067
            why you using flux?
            you only need flux for hot air reflow
            • SKP
              • Jan 2022
              • 18
              • Finland
              I probed around on another functioning board and found two SMD caps on faulty board, C10 and C19, which were measuring different values compared to the functioning one.
              140-160uF on the faulty and 300-330uF on the functioning board.
              Maybe I’ll change them when my spare parts arrive.
              All the other components, except IC2 and IC3 which I didn’t measure, gave similar values between the two boards.
              With flux, I basically tried to cut corners and get the old solder to flow easily to the pad… bad idea.
              • SKP
                • Jan 2022
                • 18
                • Finland
                And of course nF, not uF..
                • SKP
                  • Jan 2022
                  • 18
                  • Finland
                  Does anyone have any ideas on this?
                  I guess the caps are not the problem.
                  • R_J
                    • 9551
                    Do you have any voltage across the filter cap in the secondary? On the bottom view there is a chip cap marked C9 which is also across that cap.
                    You won't have any voltage across the battery terminals unless a good battery is connected.
                    • SKP
                      • Jan 2022
                      • 18
                      • Finland
                      Thanks for your reply.
                      Before I noticed your message, I measured the board live and noticed pulsating voltage on EC2 near D2, it was 9-13ish volts. And on the working charger there's steady 19.9 volts. Something to do with defective IC1 or what else could make it pulse like that?
                      C9 had 7.41v if I remember correctly, and on a working board it was 15.4v. I guess that filter cap had the same 7.41v.
                      • R_J
                        • 9551
                        There is a small electrolytic beside D2 in the primary, I would replace it. And another small one in the secondary marked ECP?
                        It seems like the power supply is in burst mode, A low vcc to the primary switching ic could cause this.
                        Check and post the voltage ACROSS the elec. cap. next to D2, this should tell us what the state of the ic is in.
                        • SKP
                          • Jan 2022
                          • 18
                          • Finland
                          Unfortunately I’m not able to test it for couple of weeks.. but I’ll order some parts and hopefully they have arrived once I get back. Then I’ll get back on ”fixing” this thing.
                          Next to D2 is EC2 which was pulsating 9-13ish volts.
                          • R_J
                            • 9551
                            The primary pwm controller will shut down at 10v on the VDD (VCC) pin, I would replace EC2 first and see what happens.
                            • SKP
                              • Jan 2022
                              • 18
                              • Finland
                              Ok, thanks for the help!
                              • SKP
                                • Jan 2022
                                • 18
                                • Finland
                                At last I had a chance to get back to this!
                                Spare parts had arrived as well so I replaced some parts, including IC1, Q1 and EC2.
                                After plugging in green and red LEDs blinks, so I didn't fix it yet. Measured EC2 and it's still 10-14ish volts...
                                Next step replacing the small EC6 in the secondary?
                                  • 31067
                                  you should have just changed all the electrolytics in one go.
                                  atleast you have a newer board that doesnt have the diode problem.
                                  • SKP
                                    • Jan 2022
                                    • 18
                                    • Finland
                                    I was just about to do that, but they forgot to send me the replacement for EC6 1uf/50V. Great…
                                    • SKP
                                      • Jan 2022
                                      • 18
                                      • Finland
                                      Changed all the caps. Borrowed the replacement EC6 from another charger.
                                      But still the LEDs blink.
                                        • 31067
                                        what do the leds usually do if you have no battery connected?
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
