Ryobi 18v BCL14181H MY2015 charger dead
  • SKP
    • Jan 2022
    • 18
    • Finland
    Re: Ryobi 18v BCL14181H MY2015 charger dead
    If I remember correctly, they both blink once after the charger is plugged in and then the red led stays on.
    Now they are just blinking.
      • 31246
      i asked because i have some radio chargers that alternate really fast between red & green when the radio is not connected.
        • Jul 2011
        • 6069
        You are correct about what is suppose to happen when you first plug it into the outlet I have one that is doing this and I have not figured out what is causing this issue
        • SKP
          • Jan 2022
          • 18
          • Finland
          I guess you have replaced almost every component on that charger...?
            • Jul 2011
            • 6069
            The only real issue you might have is if the micro controller ic chip goes bad buy a new charger
            • SKP
              • Jan 2022
              • 18
              • Finland
              #26
              Yea, I have another charger.
              But I'd like to have this one fixed. New charger costs less than what I've spent on spare parts... d'oh.
              • BTubbs200
                Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                by BTubbs200
                Dell Latitude 5420 P137G
                Board: LA-K491P REV A01
                I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                Board seems to have no shorts, all power rails are fine and show high resistance.
                When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                01-24-2025, 08:15 PM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
              • flat-earther
                how to prevent a connected charger from draining battery when not charging?
                by flat-earther
                I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                So the battery is backfeeding the charger and being drained.
                How can I prevent...
                08-07-2025, 01:04 PM
              • flat-earther
                ASUS X54H laptop thinks it's always charging even with charger unplugged
                by flat-earther
                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                Windows also shows ''Plugged in'' when charger is not connected.
                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                If I let battery run out and say it has 3% Windows will...
                06-24-2025, 09:32 AM
              • Johndill
                Dell Inspiron 7567 LA-D993P odd charger issue
                by Johndill
                Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                Here are the tested scenarios:
                1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                2. With the laptop off, plug in charger (LED says on) & the front charging...
                11-16-2022, 10:55 PM
