Input filter capacitor replacement 560uF
  • chud
    • Jan 2010
    • 20
    I am recapping my fanless Thermaltake 350W PSU and am having some trouble with replacement of 2 x input filter capacitors. (have recapped rest of it with mostly Panasonic FM)
    The original ones are 200v 560uF TEAPO ones 25mm wide, 30mm high and 10mm hole spacing.
    I was intending to replace with these, (same size except 40mm high) ;
    PANASONIC - EETED2E561CA - CAPACITOR, 560uF, 250V -
    AC Ripple 2.14A, ESR 266 - problem is Farnell are out of stock for months (UK).
    only other thing I could find are;
    PANASONIC - EETHC2E681CA - CAPACITOR, 680uF, 250V - these are in stock in Farnell, the ESR is LOWER at 244, but the AC ripple is also LOWER at 1.7A
    Could anyone advise if these would be suitable, I am worried as the uF rating is about 20% higher but I admit to not knowing enough to make a judgement on if this is ok or not? (I cant seem to find any 200v 560uF ones anyway)
    Any help much appreciated!
    Rich
    • 31283
    Re: Input filter capacitor replacement 560uF
    ripple is the important thing on the input.
    can you get a bigger one - 680uf maybe?
    • Khron
      • Sep 2006
      • 1350
      • Finland
      THIS looks like it could fit the bill (AV ripple rated at 2.77A). A bit of extra primary filtering can't hurt Not to mention they still have a few in UK stock.
      Alternately, THIS could work as well ("just" 2.5A ripple in the specs). These seem to be in stock as well.
      Not to mention they're both cheaper than the EETHC2E681CA you mentioned
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • chud
        • Jan 2010
        • 20
        Khron, thanks for your reply, unfortunately they are both 85C ones and as the PSU is fanless it gets somewhat hot under normal operation, so feel they should really be 105C ones (and one of them is almost butt-up against one of the heatsinks. Do you know if 680uF ones are acceptable replacements for 560uF? Thanks for any advice.
        • Khron
          • Sep 2006
          • 1350
          • Finland
          If 105C is a must, then i seem to have found THIS as a suitable replacement. 1.7A ripple, but i doubt that's too big a concern on the primary smoothing side.
            • 31283
            when your smoothing the mains, a higher uf is better - as long as you have space to fit it.
            i'v seen cheap junk use 330uf and some high end stuff use 820 or higher.
            • chud
              • Jan 2010
              • 20
              stj: ok thanks for that, I guess ill go for 680uF then - will need to Dremel abit of heatsink fin off, the existing Teapo are 30mm high, I think there is about 35mm of space, and everything I can find is 40mm high. The width has no room to manouver and is 25mm.
              BTW my PSU is the Passive PFC version (W0050 ) of this review "Thermaltake Silent PurePower 350W Fanless Power Supply" - ;
              http://www.neoseeker.com/Articles/Ha...ake350fanless/
              There are lots of pics at end of the review - mine has a primary transformer part where there is empty space in this reviewed one, in the rear corner behind the copper fins.
              • chud
                • Jan 2010
                • 20
                seems Farnell don't have anything in the ''TSED'' Series (high ripple) less than 1000uF @ 200v in stock.
                So I am proposing to get the EETED2D102CA's
                http://uk.farnell.com/panasonic/eete...t=EETED2D102CA
                Voltage Rating:200V dc
                Effective Series Resistance:149mohm
                Series:TSED
                Height:45mm
                Outside Diameter:25mm
                Capacitor Case Style:Radial
                Mounting Type:Snap-In
                Lead Spacing:10mm
                Operating Temperature Range:-40°C to +105°C
                SVHC:No SVHC
                AC Ripple Current:2.84A
                AC Ripple Current @ 120Hz:2.84A
                Could anyone say stop if this is going to cause a problem ( I appreciate its going to involve more Dremel action due to huge height) ? many thanks
                • sofTest
                  • Aug 2008
                  • 361
                  Unless Farnell is a requirement, I think this would be what you are looking for.
                  Be a mensch
                    • 31283
                    i also use rapid for parts.
                    http://www.rapidonline.com/
                    • chud
                      • Jan 2010
                      • 20
                      softTest: thanks but shipping is £12 extra! Farnell is free shipping (and I allready ordered what is out of stock, before finding out its going to be months before they have any, so easiest to just change it)
                      stj: they only seem to sell SAMWHA caps which I thought were proper badcaps ?
                        • 31283
                        i'v not had problems with big mains smoothers.
                        they arent suitable for high frequency stuff - so they shouldnt even be mentioned normally.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          do yourself a favor in the future, screw fanless. fanless is just asking for trouble. a good deal of them are pretty crappy too.
                          oh, and change your location setting in the user cp, it was not obvious that you are a brit until your last post
                          sigpic
                          (Insert witty quote here)
                          • weirdlookinguy
                            • Sep 2007
                            • 1638
                            Why screw fanless? Some people like a quiet PC even if it comes at the cost of a recap or PSU replacement every few years.
                            It's a tradeoff. Silence is golden for some.
                            • shadow
                              • Feb 2007
                              • 732
                              I completely agree that silence is a great desire for some people.
                              I really like a quiet PC and do appreciate and enjoy the benefits of quiet PC's.
                              Having said this, my PC's are not that incredibly quiet. However they are not as loud as some of friends PC's. I live with a bit of noise and use headphones a fair bit.
                                • 31283
                                i couldnt take a quiet pc, i'd be constantly checking it was on!
                                i love my Hovercraft - 3 x 120mm 84cfm fans on the front blasting air over the drives & mobo 24/7
                                it's the woooooshing sound of reliability!
                                • MXM
                                  • 430
                                  • Unknown
                                  hey id like to know a good replacement for a 560uf-4v cap?.... i have found very hard to find those.... is for a p4sd mobo.
                                  thanks
                                  We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
                                  • paul_h
                                    • Oct 2007
                                    • 86
                                    If there's a display on the monitor and it's accepting the characters you type, it's on!
                                    The last stock PC I had was back in 2000, everything since custom cooled and passive if possible (and if fan forced the quietest available).
                                    I'm amazed at the stock system screamers I hear at other peoples houses. They are so bad I couldn't live with them myself. My PC is on 24/7, I work on it, watch vids on it, and relax in front of it. I don't want no screaming 60mm fan in it, most things are 120mm and flow the same air as those 60/80mm fans and are low noise 120mm fans.
                                    The loudest thing on my PC is when I put a disc in the ODD
                                    • MORETTIGIAN
                                      by MORETTIGIAN
                                      Title:
                                      Description:
                                      Procedure performed:
                                      - Removed backplate
                                      - Reapplied thermal compound
                                      - Reassembled card
                                      09-18-2025, 12:14 PM
                                    • chth96
                                      Is it no harm to replace with capacitor without ripple current rating?
                                      by chth96
                                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                      Rubycon YK DataSheet (b...
                                      04-19-2024, 05:19 AM
                                    • artvandalai
                                      Where can I get compatible capacitor for replacement?
                                      by artvandalai
                                      Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
                                      12-28-2024, 10:15 AM
                                    • Agent24
                                      Dick Smith Q-1760 linear power supply filter capacitor question
                                      by Agent24
                                      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                      It has at least one problem.
                                      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                      I have already ordered a replacement potentiometer, so that's not an issue.
                                      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                      All are CapXon...
                                      10-21-2025, 05:39 PM
                                    • samoelec
                                      Trying to understand how to find best replacement cap for old parts.
                                      by samoelec
                                      Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
                                      Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
                                      The power supply board is exactly the same from this post so I'll just steal it for now.
                                      I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
                                      04-01-2024, 03:39 AM
