Re: the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
Maybe it's for the 5vSB rail? That might get away without a heatsink."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
OFC it is SB rail…there is no booster so the switchers will be far on left.
This is absolutelly normal.Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Haha! At first, I didn't even notice anything wrong there. It wasn't until I read all of the replies after this that I realized what was wrong.Shame on you, Solytech...
This thing managed to power a computer for 2 years and never failed. Pretty surprising!
https://www.badcaps.net/forum/attach...1&d=1449294660
Wow, that is... shocking? ...or amazing?
Even though this IS for the 5VSB rail, I am surprised that it didn't fail within minutes. The older Deer/Allied/L&C PSUs tend to generate a lot of heat in soft-OFF/standby mode. I guess Solytech must have improved their 5VSB designs a little. My Deer DR-250ATX keeps the whole primary heatsink nice and warm (about 40-50C) in soft-OFF mode. So I would guess that transistor is dissipating no less than 1 Watt. If this was the case here with this PSU, the PCB underneath that transistor would definitely have become crispy, especially around the Collector pin. Then again, it's hard to tell with a PCB painted black.Last edited by momaka; 12-06-2015, 03:10 PM.Comment
Possibly there is already some PWM driver, if the unit is only few years old. EU regulations in this area already work for some time…and manufacturers tend to have single paltform for all markets.Less jewellery, more gold into electrotech industry!
Dell H240AS-00
I posted pics of this PSU before, and I seem to recall someone saying to replace a ceramic cap, but I looked and couldn't find that post.
Well .... you were right. I think it finally failed.
That computer was brought back to me, and had no power. No 5v stby
The picture tells it all! :P
She blowed up real good!
Notice the soot around the fuse! Holy moses! Somethin done gone bang for sure!
.. Looks like I have a power supply to fix
-BenMuh-soggy-kneeComment
Looks like that ceramic cap is across Drain and Source on the FET behind it. Also note the small hole in the resistor too! Judging by the resistance value of that resistor, it is probably used as a Source resistor for the FET - and if it is, you might want to check the FET too. I see a 420V primary cap behind. APFC PSU? If yes, I bet that's all that is wrong with it.
Mmm-hmmmOriginally posted by ben7.. Looks like I have a power supply to fix
Yes I am just about the check the FET and other primary side power devices.Looks like that ceramic cap is across Drain and Source on the FET behind it. Also note the small hole in the resistor too! Judging by the resistance value of that resistor, it is probably used as a Source resistor for the FET - and if it is, you might want to check the FET too. I see a 420V primary cap behind. APFC PSU? If yes, I bet that's all that is wrong with it.
And yes it has APFC! Somewhat surprising for a 240W PSU.
[Quick update]
(Will make new thread if I need to, but I don't at the moment. Don't want to hijack lol)
The main switching FET is shorted, the APFC FET is shorted, and the APFC diode seems unhealthy. (Measures 200 ohms both ways, and this is in circuit.)
The APFC FET shorted badly, I get 0.4 ohms on the + and - of the bridge rectifier. (All 4 bridge rect diodes test fine though, forward voltage wise.)
It's REALLY gone pop!...
No wonder why the fuse blew so hard!
An SMD diode and resistor have blown as well.
Edit: Holy crap! Gee, a switching controller chip on a daughterboard is burnt as well!...
-BenLast edited by ben7; 12-07-2015, 07:45 PM.Muh-soggy-kneeComment
As PhotonicInduction would say:
Awwwww. We POPed it!
I'd still try to repair it, though, just for fun. If you do that, then yeah, make a thread for it (and with more pictures of the carnage!)Comment
I guess the ceramic capacitor shorted out (maybe voltage rating too low/bad quality?) and caused everything else to fail.
I can't imagine how the capacitor would fail if the FET blew first."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Well Ben, I sent you this PM on November 28, how is that memory going? :P
EDIT: Saw your new thread now, here is is for others that want to followOriginally posted by ben7Ah, well, I don't have that supply any more.... :/Originally posted by Per HanssonHi, re your Dell PSU here: https://www.badcaps.net/forum/showpo...postcount=2314
Do read this thread, might be a good idea to replace that ceramic cap before it fails!
https://www.badcaps.net/forum/showthread.php?t=40726
-Ben
https://www.badcaps.net/forum/showthread.php?t=50864Last edited by Per Hansson; 12-13-2015, 05:04 AM."The one who says it cannot be done should never interrupt the one who is doing it."Comment
*Atomic Facepalm*Well Ben, I sent you this PM on November 28, how is that memory going? :P
No wonder why I couldn't find it ... it wasn't a post, it was a PM!
Gosh, I'm getting old!
My brain belongs in this hall of shame.
-BenLast edited by ben7; 12-13-2015, 09:08 AM.Muh-soggy-kneeComment
Hello everyone i haven't posted in a while and i thought now is the best time to do so.
So i purchased today a slim ITX case with an HEC psu (that i found at a local retailer of electronics which is closing it's last remaining store permanently , in FL) i saw it was in excellent condition but they were asking several months ago 75 dollars for it, i waited until today which the price was reduced to 15 dollars for everything and the case includes a 8x slim DVD combo drive.
Well now that the story is out of the way i was thinking is the HEC psu worth it as it's maximum power output is 200 watts.Active PFC (as the area where the voltage selector switch is covered with a sticker) It has 14 amps in the 12+ side. It has a bridge rectifier, 8 amp not heatsinked, Primary capxon(or should i say Crapxon, but it's the primary) cap all other caps are teapo with exception of some sus'con caps on some daughterboards which are tiny caps. Should i toss it? can i actually use this PSU or switch to another brand?
thanksLast edited by coreAngel; 12-14-2015, 08:38 PM.Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboardComment
This one really surprised me this is a notebook power brick which i bought off ebay for a bit less than an original hp adapter. The components are not all secured, questionable caps, the components which are crucial can only output 12 volts not the 19 v needed to work properly no wonder the brick got so hot i became worried and unplugged it.
Qinfen primary cap, and oxxa caps on the rest... yes they are using the logo from oxxo good grips kitchen utensils to put oxxa for some type of fake cap....
My laser thermometer read the case of the power brick under moderate use at almost 88 C either somethings wrong with it or it must be the worst design ever...
This really belongs as crap
And yes i bought a genuine HP power adaptor after thisLast edited by coreAngel; 12-14-2015, 08:49 PM.Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboardComment
The pic of that HEC unit are terrible man.
Well, some of the chinese bricks are somewhat decent, just with cheap caps. But this is terrible. Primary and secondary connected by common heatsink? OMG! And that primary switcher is not even screwed to it, it is flying apart!Less jewellery, more gold into electrotech industry!
Should the HP f1905 PSU be a candidate for this list?
After some time with no signal (but the power light was on), it would display black with a snowy white border (but was OK when a signal source was applied) - when I opened it up, I found that the 450V 150uF Elite PW Series unit was leaking at one of its pins.
Most of the other electrolytics were Elite EL, with two unknown brand units, and near each of the two backlight inverters was one Chemi-Con KY unit.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Elite, that's quite common. It can go as far as the electrode completelly rotting off.Less jewellery, more gold into electrotech industry!
I will try to take pics of the HEC again so it's more clear but it's a really tight space so i don't know if it will all come outYes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboardComment
It looks good to me. I dunno if it can do 200W, but the quality looks good from what I can tell. Except for the cheap caps of course.
It's hard to tell how well it might work. Just because the heatsinks may be smaller than usual, doesn't mean that the power supply is improperly designed. If efficient enough, it doesn't need huge heatsinks.
Doesn't surprise me! :PThis one really surprised me this is a notebook power brick which i bought off ebay for a bit less than an original hp adapter. The components are not all secured, questionable caps, the components which are crucial can only output 12 volts not the 19 v needed to work properly no wonder the brick got so hot i became worried and unplugged it.
You might be able to modify the feedback so that the output voltage is correct, at 19V.
Also, the cable going to the laptop itself might be poor quality - as in, too fine of a gauge of wire - there might be voltage drop there as well. But a 7V drop seems a bit too much even with fine wire ... it might be the power supply itself that is set for 12V out.
In regards to the extreme heating ... It might be a poor design, or maybe they might have picked cheap parts for the switching transistor and the output rectifier. Also I know those transformers can run quite hot too. Perhaps the switching frequency isn't optimal, so the losses are higher ... who knows
(( Could you read us the part numbers for the switching transistor and the output rectifier? ))
But ... 88C on the outside case is not acceptable! You might not be able to boil water on it under regular conditions, but you still could get a slight burn from it! Wow!
Also note how the heatsink is extruded! Interesting, they went to the effort to do that instead of doing what is usually done, using a [folded] bar of metal (This is done in the genuine PSUs as well, so it's not exactly poor practice)
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by eccerr0rIntroducing... the POS-124Z which really is a POS:
Yep it's a POS allright.
I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
So I had to take a peek:
EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?... -
by tamerelaputeHi,
I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
Except the cpu, I cant feel anything getting warmer.
I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
I believe that if the cpu was fried,... -
by x_orange90_xI was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
by LapsmithWhile installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
- Loading...
