DELL OEM H240AS-00 (HIPRO) ~ major blow up!
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    DELL H240AS-00
    240W
    Made by HIPRO
    This is a decent PSU, with APFC. It's in some sort of small form factor case, not sure which type. But it's long and fairly skinny.
    I recall someone saying to replace a ceramic cap, after I posted pics on the forums of the build quality.
    Well, by then, I had already given the computer back to the owner!!! (It was de-virused)
    It turns out, it finally blew! So far, it took out:
    -STW12NK90Z (Main switching FET)
    -680pF 1kV ceramic cap (This is the one that went bad)
    -SPW16N50C3 (APFC FET)
    -A 0.27 ohm resistor (2W rated I think)
    -The control IC (more on this later)
    -And various other parts (a few SMD resistors, a transistor, and a diode)
    -Oh, and don't forget the fuse! It really took out the fuse in spectacular fashion!
    The APFC current sense resistor, a 50milliohm resistor, measures as good. (Well, as far as I can tell. It measures pretty much 0 ohms on my meter, which can't do that low of a resistance)
    The APFC diode, a BYV29X-600, surprisingly tests good, along with the thermistor.
    The APFC IC is a UCC28019.
    It doesn't look burnt, but I might replace it just in case, because the APFC fet was blown.
    The bridge rectifier - a GBU606 - tests good as well.
    Caps are Elite (APFC filter cap), Ltec and two Rubycon. None are bulging, but I might replace the crapcaps just for good measure ... if I fix this thing, that is!
    The date codes on them appear to suggest that they were made in 2012.
    The main PWM IC is ... I don't know!
    I tried searching for it but couldn't find anything.
    It looks like it might have been made by .. ON semiconductor? I dunno, the package marking is familiar though, I've seen multiple PSUs using a similar looking IC. It has a stripe on the end where pins 1 and 8 are.
    The markings are:
    CPx12A
    PLWW
    The "x" is where the IC burnt, I think it might either be a 6 or an 8. It's also possible that the 1 is actually an "L" or an "I".
    It doesn't have a manufacturer's logo or name on it.
    It looks almost like a UC3842 though, with a 10uF 50V cap across pins 5 (-) and 7 (+)!
    The burnt pin - pin 6 - is the gate drive pin on a UC3842, which would explain why it is burnt ... because the main switching FET shorted out.
    ~~~ Now for the pics! ~~~
    The badly burnt and blown fuse.
    Overall visible carnage.
    Cracked ceramic cap, and blown resistor.
    The ceramic cap came out in two halves!
    (Note this cap was across the STW12NK90Z's D and S pins. No wonder it did so much damage when it shorted out.)
    D53 and R55 are blown.
    D53 appears to have "D1" on it, which appears to be a 1N4148W
    R55 looks to me like it was a 22 ohm resistor "22R0"
    (Note the markings "Hi Volt FET" .. this is the STW12NK90Z for the main switching converter (a forward converter I think?))
    IC301 is the mystery IC, you can see that pin 6 has soot marks around it, and the plastic/resin is bubbled.
    R304 is blown, it looks to me like it is a 2K2 resistor "2201"
    Q301 tests quite a low resistance. It's marked "1P" which appears to be a 2222A NPN transistor.
    IC302 - a TI UCC28019 - doesn't appear to be blown, but it might be.
    P.S. Sorry if the pics are too large, but I downsized them twice already XD
    I know how some of us like to see the carnage though!..
    P.S.2. The fan is a "Magic" fan by Protechnic.
    Rated 170mA at 12V (it's a 60mm fan, 25mm thickness).
    P/N MGA6012HS-A25
    -Ben
    Muh-soggy-knee
    Re: DELL OEM H240AS-00 (HIPRO) ~ major blow up!
    Can we see the pictures of the whole board top and bottom side?
    R55 (22 Ohms is about right)/D53 (1N4148 will be fine) is the RD Gate drive network, so the IC that drive the Gate of that MOSFET is more likely to be damaged, yes, I would change it for sure.
    The burnt ceramic cap C52 is the snubber cap, the 0.27 Ohms resistor is for the Source of the MOSFET.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      The IC that drives that FET is IC301 ... the mystery IC.
      -Ben
      Muh-soggy-knee
        • 31267
        lol
        notes for the sub-board.
        r301 - 513 / 51k
        r302 - 123 / 12k
        r303 - 512 / 5k1
        r304 - 2201 / 2k2
        r305 - 100 / 10r
        r306 - 0
        r307 - not fitted
        r308 - not fitted
        r309 - 914 / 910k
        r310 - 223 / 22k
        r311 - 821 / 820r
        r312 - 623 / 62k
        r313 - 392 / 3k9
        r314 - 18d / 150k
        r315 - 2200 / 220r
        r316 - 333 / 33k
        r318 - not fitted
        r327 - 221 / 220r
        r328 - 471 / 470r
        r329 - 432 / 4k3
        d301 - 1n4148
        d302 - 1n4148
        d303 - 1n4148
        dxxx - 1n4148
        z301 - ?
        z302 - ?
        q301 - mmbt2222a
        q304 - ksp2222a
        q305 - mps751
        ic301 - cp012a
        ic302 - ucc28019a (ti)
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Originally posted by stj
          lol
          r301 - 513 / 51k
          r302 - 123 / 12k
          r303 - 512 / 5k1
          r304 - 2201 / 2k2
          r305 - 100 / 10r
          r306 - 0
          r307 - not fitted
          r308 - not fitted
          r309 - 914 / 910k
          r310 - 223 / 22k
          r311 - 821 / 820r
          r312 - 623 / 62k
          r313 - 392 / 3k9
          r314 - 18d / 150k
          r315 - 2200 / 220r
          r316 - 333 / 33k
          r318 - not fitted
          r327 - 221 / 220r
          r328 - 471 / 470r
          r329 - 432 / 4k3
          d301 - 1n4148
          d302 - 1n4148
          d303 - 1n4148
          dxxx - 1n4148
          z301 - ?
          z302 - ?
          q301 - mmbt2222a
          q304 - ksp2222a
          q305 - mps751
          ic301 - cp012a
          Thanks for the info, but I think I'm screwed over on repairing this POS XD
          1. The mystery IC is an unobtanium part ... after a LONG search, I found that it cross references to SCY99087 ... which is just sold by 3rd party, chinese vendors.
          2. Looking online, it appears other people have had the same PSU fail, repeatedly (after being replaced). Even cases of arcing and smoking while continuing to work!
          I think I'll probably end up getting a different PSU and modding the connectors to fit this computer.
          I didn't even think of it to check, but I found this thread:
          https://www.badcaps.net/forum/showthread.php?t=40726
          STJ, you said in that thread to replace the cap with a 2 or 3kV cap ... but why? Why, if the FET is only rated for 900V? Do the higher voltage caps dissipate the heat better due to their bigger size?
          Either way, I'd still need to get a replacement CP012A chip ...
          -Ben
          Muh-soggy-knee
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Fix it! (okay, only if you have nothing better to do or just as a challenge, that is)
            I suggest to not bother with fixing the APFC circuit - not now, at least.
            As for the mystery IC: see how it is connected on that daughterboard. Maybe you can successfully substitute a UC3842/3/5. Or perhaps do so with some modding. A simple UC3842 drive circuit isn't that complex, actually.
            For the main FET, you can use whatever you got in your junk bin, as long as it has the same Vds voltage rating. This is for testing purposes, of course. Once the PSU is fixed, use same or equivalent parts to the originals.
            And, of course, use the series incandescent bulb trick for all live testing. Unless you like to start New Year's fireworks show early .
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Yeah, in fact I have a good STW12NK90Z FET in my transistor box! :P
              I'm going to look in a few places to see if I have a CP012A chip ... I doubt it, but I might as well look...
              Heh, in the end, I may end up going as far as reinventing the daughterboard using parts that can be bought everywhere (like a UC3842, etc...).
              XD
              -Ben
              Muh-soggy-knee
                • 31267
                they arent exactly unobtainium, i charged up the lithiums in my light-sabre, and went to the starwars bar AKA aliexpress and picked up a strip of 10 from some alien scum.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Yeah, I've seen those listings, but I have near zero trust for 3rd party vendors XD
                  Muh-soggy-knee
                    • 31267
                    http://www.datasheetdir.com/CP012A+PWM-Controllers
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Yes I already saw that page, that is where I found the reference to the SCY99087, but it seems they still are hard to obtain (excluding 3rd party sellers, that is)
                      Interestingly, the page for that chip is blank. Well, it seems to connect to the server just fine, but there is no content on the page, just a white background...
                      http://www.datasheetdir.com/SCY99087+PWM-Controllers
                      -Ben
                      Muh-soggy-knee
                        • 31267
                        go to on-semi and put SCY99087 into the search box and the autocompletion system puts the rest of the code in - so it's theirs.
                        unfortunatly it then pretends they never heard of it!!
                        as for your cap question, the cap is hammered by reverse pulse every time the fet shuts off.
                        higher voltage caps are stronger in general and usually have a lower esr.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Yeah, it's strange that they have covered it up. Mouser does the same thing! Search for the exact part, and you get it (they have no info and no stock on it of course!), but search for the 99087 itself, and you don't get it in the results!
                          It's as if they are hiding it!
                          EDIT: Perhaps they don't typically list it, because it isn't assigned a Mouser P/N.
                          Maybe HIPRO has some special deal with ON semi ... who knows!
                          This is a ceramic cap, so it shouldn't complain about reverse polarity, right?
                          Is the pulse just too high dV/dt?? (Too fast for the cap, because of ESR and/or inductance?)
                          -Ben
                          Muh-soggy-knee
                            • 31267
                            i think it's just a disipation issue.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              I'm thinking that would actually be the easier route if you can't easily obtain a CP012A / SCY99087 PWM IC. Just grab any PSU with single-transistor forward and UC3842/3/5 PWM IC and copy the design of its primary side. And APFC - just forget about it altogether .
                                • 31267
                                btw, have done another since.
                                i now know what the zeners are:
                                z301 - 18v 500mw zener
                                z302 - 5v1 500mw zener
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Ahh, okay, thanks for the info!
                                  I've since fixed the computer. Sorry for not giving an update until now...
                                  I bought a replacement PSU. I actually opened that up (I know, tsk tsk tsk).
                                  It is different inside. MUCH nicer build quality, it was amazing! Single 12V rail design, with DC-DC converters for the minor voltages.
                                  I'm not sure who built it, as it wasn't obvious.
                                  But it did use good capacitors as well. There were a few CapXons in there, but eh, I think they are fine now. They may be cheap and chinese, but they've obviously changed electrolytes now so they won't go bad as often ...
                                  (A few of the CapXons were polymers, BTW)
                                  (It also used a double sided PCB for the main board, something which I haven't seen very much in computer PSUs.)
                                  I've since salvaged parts that were undamaged from the old PSU. Got a bunch of rectifiers, I think they were something like 3045CT or something similar .. idk, I can't remember XD
                                  Oh and there was a FET on the secondary heatsink of the old PSU. I dunno what it was for, but maybe I can take a look at the PCB again and see if I can figure that out.
                                  -Ben
                                  Muh-soggy-knee
                                  • Wester547
                                    • Nov 2011
                                    • 1268
                                    • USA.
                                    How do you know that? The polymers may be fine. But CapXon will always be CrapXon, I wouldn't count on them to um, "rectify" anything about their manufacturing process. On the other hand, at least you have a PSU that doesn't harbor the same problem as the last.
                                    EDIT: The "capacitor" plague has only gone away on motherboards. It still exists everywhere else. Extra cheap brands like CrapXon don't bother with proper (or any) QC testing or high purity and quality materials, so they will always be inconsistent and unreliable, unless they somehow come under new and better management (which I doubt).
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Well the more modern CapXon capacitors have been fine in devices like PSUs and such ... it was just those from the bad cap plague era that were a problem.
                                      Then again, yes, I still don't fully trust cheap capacitors! :P
                                      -Ben
                                      Muh-soggy-knee
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Not necessarily, IMO.
                                        I have plenty of CapXon KM from the "bad cap" era, and they are all fine. Even used more than a few of them in temporary fixes while waiting for new caps, and they held in fine. I still (re)use them, too.
                                        That's not to say CapXon is good. My junk/blown caps bin is dominated by failed CapXon, Sacon, Chemicon KZG, and Teapo (in order from worst to least worst). Even all of the PSUs I've found with Fuhjyyus have a better track record.
                                          MEDION ERAZER Major X20 Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION ERAZER Major X20 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Major X20 boardview and Major X20 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                          09-07-2024, 06:31 AM
                                          MEDION ERAZER Major X10 Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION ERAZER Major X10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Major X10 boardview and Major X10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                          09-07-2024, 06:11 AM
