the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Behemot
    • 4845
    • CZ
    #961
    Re: the gutless, bloated, and fried power supply hall of shame
    Usually ppl just stick something in, for the good feeling you can scope it if it is not oscillating.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      #962
      The pi filter coils have too low inductance to play a part in the feedback loop.
      A working TV? How boring!
      • Behemot
        • 4845
        • CZ
        #963
        They can have too high for example for -12 V, I sucesfully brought one PoS to oscillation by sticking some inductor instead of wire…changed it for resistor-size inductor than.
        • PeteS in CA
          • Aug 2005
          • 3578
          • USA, Unsure of Planet
          #964
          Yeah, with those wimpy input rectifers, heatsinks, input lytics and main transformer, 250W might be optimistic. But for 200W should be OK. Since you'll be changing them anyway, upping the input lytics to 470uF or even 680uF would be good. And if you can find some 4A or 5A axial standard recovery rectifiers that would fit, replacing those would be good. Do both changes and 250W might be credible.
          PeteS in CA
          • nasuga
            • Mar 2014
            • 5
            A couple of weeks ago I've had a cheap powersupply die on me. I can't remember the model but it was a codegen and it came included with codegens 4063 case and was rated for 500W. I left my computer running one night (I tend to leave it running) and when I came back it was dead. I thought maybe a capacitor had blown but I was wrong. What it looks like is that the transformer melted and burnt inside the powersupply. Nobody heard anything when the computer died. The underside of the board was black from the intense heat. I should of taken more pictures and written down the details but it was before I found out about this board and after I've thrown it out. I guess I missed the power supply with the compressor last time I cleaned . I'm glad there was a soldered fuse or else it would of taken my motherboard and possibly my videocard.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4926
              • New Zealand
              #966
              If nothing else was burnt, then maybe that choke shorted by itself or there was some power line disturbance which blew it. Seems odd
              -David VanHorn
              • nasuga
                • Mar 2014
                • 5
                Agreed. My brother (who studied as an electrical engineer) told me that it's possible that the varnish or coating on the windings dried/melted and it started shorting. I don't think there was a power line disturbance because I was home at the time and I didn't notice any problems with other electronics or with the lights. Also, the power supply was plugged into a surge protector.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Looks like the input filtering coil. That's very unusual. I've never seen an input filtering coil burn up like that.
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    #969
                    looks underrated to me....
                    Follow the white rabbit.
                    • nasuga
                      • Mar 2014
                      • 5
                      I replaced it with a brand new Corsair RM550. Rumor is that they used CapXon caps inside but with a flash light I was able to spot a large chemicon but I couldn't identify the rest. I'm just glad there was a fuse that protected my motherboard even though it's riddled with KT and WX caps.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        The large PFC cap in those is indeed a Chemi-Con. But the rest of them will be capxon, and will probably fail within 3 years.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4926
                          • New Zealand
                          #972
                          Going by this: http://www.pcper.com/reviews/Cases-a.../Detailed-Look it should have UCC KY which are good. (Can see one there anyway, not sure what is buried under the wiring though)
                          Wouldn't be surprised if some use\used CapXon though, I saw a Corsair CX400, it was full of Su'scon and OST, which are pretty mediocre.
                          -David VanHorn
                          • nasuga
                            • Mar 2014
                            • 5
                            The PSU has a 5 year warranty if it fails. I figured it outweighed the fact that it was built with bad caps. Chances are though that it will fail right after the warranty expires now come to think of it.
                              master hoarder
                              • May 2008
                              • 12168
                              #974
                              Yes.
                              This is one reason I don't like to see input filtering of ANY kind BEFORE the fuse (except maybe large PPFC chokes). If your breaker doesn't trip, you could be in big trouble.
                              • Behemot
                                • 4845
                                • CZ
                                #975
                                If no breaker trips (there should be at least two of them - the main one and than special ones for phases or even outlets/ligths etc.), why are yo ucertain fuse will burn? There are always slow fuses for high currents, like 5+ A for PSU which wil never draw more than 2 A.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  A possible cause for the filter coil to burn like that is, of course, a shorted turn or two.
                                  Another is, the power supply could have gone unstable and caused excessive high frequency ripple on the primary side, which could burn out the choke (which filters out the high frequency, preventing it from going back into the mains wiring).
                                  Muh-soggy-knee
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4926
                                    • New Zealand
                                    #977
                                    Interesting, haven't heard of that one before. What causes that?
                                    -David VanHorn
                                      master hoarder
                                      • May 2008
                                      • 12168
                                      #978
                                      ^Me neither. I think the primary transistors should fail way before that happens, though. Would be an interesting experiment to try to see what it takes to cook one of those input chokes, though (besides too much current). More specifically, how much RF/noise would be needed.
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        #979
                                        http://translate.google.com/translat...l-350-W/1885/1
                                        nice fireworks btw:
                                        http://www.clubedohardware.com.br/ar...l-350-W/1885/8
                                          master hoarder
                                          • May 2008
                                          • 12168
                                          #980
                                          ^Very interesting. I wish they (clubedohardware) would have done a deconstruction of the coil to see why it burned... i.e. too thin of a wire, improper wire, or what exactly. Would also have been cool to bypass the PPFC and filtering and try to run the PSU again to see how far it would go. The heatsinks look decent. I bet it could hit 300W of raw power (that is, ripple probably won't be in spec on output).
                                          So I guess the conclusion is that now we can't trust input filtering coils in cheap PSUs either.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
