the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • kleung
    • Jun 2012
    • 72
    Re: the gutless, bloated, and fried power supply hall of shame
    So, I have had 3 devices fail from bad capacitors in 1 week. A netgear switch, an antec neo he430 psu (failing) and the obvious
    Bestec 250-12z PSU - failed ; not starting pc
    came from a HP/compaq core2duo system.
    just wouldn't start one day.
    disaseembly shows bulging caps,
    totally not surprising. at least the 12z didn't fry the motherboard.
    The 12E version DID fry another system I used to have. Repaired that psu but this one; I'm just going to trash as time has gone by and there are much better psu's worth refurbishing than this one.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I wouldn't expect anything less from CrapXon. It should fire right back up after a recap, if not I'd check the primary IC. These PSU's are great after a recap. And, yours has the white glue instead of the dreaded brown conductive-over-time glue. Nice!
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        #923
        ^ Those aren't CapXon, those are Teapo.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Oh geez, they are! so used to seeing CapXon in that model!
          • c_hegge
            • Sep 2009
            • 5219
            That's a first. I've never seen Bestec use anything but Jamicon, CapXon or OST.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Same. One I had though had Rubycon CE on the voltage doubler. That was it though....usually it's Jamicon GP caps
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Azza Dynamo 850W. Paid $20 for it, sweet deal! Obviously Super Flower made. It would boot up for about 3 seconds and then shut down. I figured, hey, those bulged caps might have something to do with it
                I recapped it, removed all the glue, fixed bad joints, oiled the fan, and it's good to go The thing is an amazingly designed half bridge unit. They sure put some thought and engineering into it.
                Look at those beefy CapXon! They measured 1200uF too, good job CapXon! They're heavy too. 15A bridge on a heatsink
                I was extremely surprised that the caps that went bad were on the 5V and 3.3V rail. ALL of the bulged JPCE-TUR 3300uF 10V caps measured in the range of 1500-1600uF and in the ESR range of 1.3-1.65Ω
                12V uses 40A schottky's in parallel.
                • Behemot
                  • 4845
                  • CZ
                  #928
                  Seems good for 550 W combined, with some luck 500 W on +12 V itself.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    SuperFlower were one of the few who could come up with a good half bridge design. That PSU would be a little inefficient, but it would have good output performance.
                    • TELVM
                      • Oct 2012
                      • 547
                      • Spain
                      #930
                      Originally posted by Pentium4
                      Azza Dynamo 850W. Paid $20 for it ...
                      That PSU is built like a tank, look at the thickness of the heatsinks and the size of the PI coils.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Wooooooooow!!!! That's an awesome PSU.
                        Even the 5V_STBY transformer looks a little bigger than in some cheap PSUs. It also has a chip right next to it, so it likely isn't the killer two transistor design.
                        Muh-soggy-knee
                        • Heihachi_73
                          • Jun 2012
                          • 713
                          The last Bestec I scrapped had JPCE-TUR caps, although it was a 2000 model ATX-1523F powering a Socket A Duron rather than anything more recent. The mains caps were Taicon.
                          • Behemot
                            • 4845
                            • CZ
                            #933
                            CEC International Holdings Ltd.
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              #934
                              inland ils-600r2
                              where to start on this overated POS!
                              appear to be fake nippon caps too.
                              dented and appearance of dirt under the wrap.measures +- 700uf and 2.7 esr!
                              secondary rectifiers are all 30a.claims 36a on +12.
                              it was dead when it came in so no testing.but everything screams JUNK!
                              inland is a micro center house brand.
                              i suspect cougar is too.
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                #935
                                more on the ils-600r2
                                FAKE caps
                                • PeteS in CA
                                  • Aug 2005
                                  • 3578
                                  • USA, Unsure of Planet
                                  #936
                                  600W ... do you want shrapnel with that? No matter, you're going to GET it anyway!
                                  So, wrong sleeve color, no temperature rating, and no date/lot code ... you got a problem with that?
                                  PeteS in CA
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #937
                                    Fakes for sure, KMGs are brown and I think don't have that top cover. I have some KMQs and they don't have anything over the vent.
                                    But the blue PCB is nice
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4924
                                      • New Zealand
                                      #938
                                      Inland PSU?
                                      Should be IN a LANDfill. Haha.
                                      -David VanHorn
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        Definitely a Leadman. For 600W, it sucks but it's not even close to worst thing in this thread At least the heatsinks are decent, the toroids are big and nicely wound. 30A (guessing shottky) isn't bad for the 12V. The 5VSB transistor with no heatsink though is pitiful, not sure why Leadman always does that. What kind of fan does it use?
                                          master hoarder
                                          • May 2008
                                          • 12164
                                          #940
                                          Agree.
                                          At the very least, it's a decent source of PSU parts to fix up other PSU (I say this because even if a Leadman PSU looks well-built, their designs usually perform badly).
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
