the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    #1001
    Re: the gutless, bloated, and fried power supply hall of shame
    is the case also a total pile of shit to match?
    • everell
      • Jan 2009
      • 1514
      Originally posted by SIDMX
      This is a classic LC with the "chip-of-the-year," yeah I know, there are enough LCs here but I feel the need to post it because this one came pre-installed in a NEW computer case (TrueBasix brand) so it SHOULD BE A NEW P/S right? ...maybe a crappy one, but NEW nonetheless, well...Not this time!
      It's not just old, it's used, awfully repaired, not even cleaned, corroded, and ALL caps have date codes from 2004.
      Does this thing actually work? Perhaps the seller removed a good power supply from the new case and replaced it with this one because he knew no one would want it!
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • SIDMX
        • Nov 2010
        • 165
        • Mexico
        #1003
        Originally posted by goodpsusearch
        This is their 2003 design! How did it end up being sold as a 2012/2013 product?
        Lack of ethics? Whoever TrueBasix's supplier is they know that TB can't verify each box (but I do), I wonder how many of these are out there actually powering a system.
        Not really, it's a cheapo uATX case but the quality is nowhere as bad as the P/S, these cases usually came with very low end KeyMouse units inside very similar to this one but this is the first one that I've seen with an LC.
        The box was sealed so my guess is the supplier is screwing TrueBasix from time to time, It "works" with no load and all voltages where good, but that's as far as I tested.
          master hoarder
          • May 2008
          • 12164
          #1004
          Originally posted by Pentium4
          Oh boy, what a shame with this one. It had potential! ... but my main gripe is probably easy to guess...the output filtering! Where is it?
          Yes, shame indeed. Those extruded and cut heatsinks are rather good. Probably could do 300W continuous no problem. The rectifiers are good too. Would easily power a modern low or mid-end PCl, because the 12V rail has potential (wait, that's a pun! ).
          That said, you could still easily make it a usable PSU again. Since there is only a single cap for the 12V and 5V rails, looks like you have a lot of space there. Maybe change those caps with 12.5 mm ones? That gives you the option to put a 3300 uF 16V cap on the 12V rail and a 3300 uF or 4700 uF on the 5V rail. The 3.3V, of course, should be more than happy with two 2200 uF caps (and if the PSU won't be powering a power-hungry motherboard, you could probably go as low as two 1500 uF caps).
          As behemoth suggested, though, I too wouldn't recommend you put big filter caps on the 12V rail where the fan connectors are. With the long traces going to those connectors, you may introduce undesirable noise in other nearby traces, and that may or may not cause problem.
          First time I have ever seen a 5VSB filter not have a coil!
          Those coils on the 5VSB probably don't make a overly-huge difference in suppressing output ripple anyways. But I'm sure it helps with the ripple current on the caps, though.
          Looks like you could install one. The jumper in position L4 (or is it J9?... or J10?) right next to the output caps could be replaced with a coil.
          ... or H.Q. (which does not stand for High Quality )
          More likely, it stands for Horrible Quality
          Looking at the solder side, it looks pretty darn good.
          Wow, that is clean work!
          • Behemot
            • 4845
            • CZ
            #1005
            Well, you can put 3300uF 16V caps in D10 there as well, the Samxon RS, soon also NCC KZN…in D12,5 I think you can get as high as 3900 or 4700 uF in 16 V.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Makes sense. I was mostly curious. I wonder if something like a 220uF 16V Rubycon ZLH would improve the ripple at all? It's a small cap but can still handle 540mA
              Still! Just shows how cheap they are.
              I have Panasonic FR 4700uF 16V D12.5mm but that might be too low for the PSU? ESR for that cap is 0.012Ω
              • Behemot
                • 4845
                • CZ
                #1007
                Just try. As there is no Pi filter, who knows, it can probably handle a lot…
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Coolmax CA-450
                  Fan seized in this thing, which was causing the computer to shut down. Man, this thing is pretty bad. Looks like it is made by ATNG? Those Y caps and X cap are safety approved. At least I'll get a few useful parts out of it The BR is 4A, NTC rated at 5A, 330uF Micon primary caps (They actually read 330uF too!) 13007 transistors, 33 transformer, 20A for 5V, 12A for 12V, 20A for 3.3V. Pretty lousy, no PI coil on 12V or 5V, Mostly GoldLink caps, some Micon in there too. Looking at the soldering side, how embarrassing. Maybe this thing was RMA'd and hand fixed? All those sloppy joints (one with a lifted pad) are on the 5VSB transformer. Not going to bother fixing this one, just going to take some parts and throw it away.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Re: Coolmax CA-450
                    HMMM, Wait, don't throw it away yet!
                    The other day I found a fake EMI filter inductor in my inductor box, and yours looks just like the one I found. It was quite lightweight, and when I unwound it, and took the plastic shells apart, there was no ferrite inside!!!!
                    Muh-soggy-knee
                    • Behemot
                      • 4845
                      • CZ
                      #1010
                      Definitelly not ATNG, some generic chinese crap, I've seen similar ones. ATNG uses different heatsinks for a start.
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Maybe it's Long Yi Electronics.
                        Thanks for the heads up! I wasn't going to reuse it, I have plenty of ferrite coils lying around. Care to post a picture though?
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Nothing really to see, since I didn't take a picture before I unwound it...
                          I was sorting things and did a double-take, I realized that choke was suspiciously lightweight... inspected it, then I unwound it...
                          FYI, the choke needs the ferrite to work as intended, it is a common mode choke.
                          Muh-soggy-knee
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Jin yuan 400z
                            Here's another junker. It's pretty terrible, but not the worst I've ever seen. If you add up all the rails' wattage on the label, it comes out to 275W Of course there's almost no input filtering to speak of, with the usual missing components and unapproved Y caps. The caps are 330uF branded "HTC" transistors are 13007. Transformer looks like 33, it's pretty small but it's silkscreened for an even smaller transformer!!! One of the few positives, it doesn't use a 2 transistor 5VSB. Looks like it uses that single toroid for all the rails, for mega group regulation. It seems that the 5V rail and 3.3V rail share the 30A shottky and the 40A FET just steps the 5V down for the 3.3V. 12V uses a 16A ultra fast. Soldering looks good, minus on some of the silicon. The only other pro for this thing is the fan. Can't find jack shit about it though. It's hooked straight to 12V, but it's actually very silent and moves a lot of air. Plenty oil in the bearing too, and it's actually oil, not grease.
                            • SIDMX
                              • Nov 2010
                              • 165
                              • Mexico
                              #1014
                              Yeah crappy indeed, specially the lack of output coils and/or place to install them, but, interesting in some ways like the 5VSB switcher, it has a weird numbering on it, resembling a Unisonic part but the "WY" logo is not from Unisonic, probably a knockoff, P/S controller chip it's the Silan's version of SG6105 but IIRC Silan already have one version, the SD6109 .
                              Samwei caps? never seen or heard that brand, seems like all caps are SGF series.
                              Main transformer doesn't look that bad, I mean, we all have seen smaller ones, if it weren't for the lack of output coils I could trust it to power a very low power system like those onboard atom/celeron/APU after a proper recap.
                              edit- I've posted all Samwei DS in the cap depot thread.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Wow you know what, I'm so used to seeing ChengX in that green/gold sleeve that I didn't even notice that they're SAMWEI Never seen them before either.
                                And here's a size comparison, that transformer is a lot smaller than the earlier pictures resemble.
                                • SIDMX
                                  • Nov 2010
                                  • 165
                                  • Mexico
                                  #1016
                                  Yeah at first sight I took them for ChengX too .
                                  Ah!... that winding is tiny! it is using like half the space available in that core, still could be enough for Atom boards, but it is definitely crappier than I thought.
                                  At least is not a real joke like this one that I found in an LC.
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    WHAT! That was a main transformer?! That's pitiful At least with these cheap heatsinks, I will be able to break them down into a few bridge rectifier heatsinks Also...I wonder if you could cut out just the 5VSB section with the 8 pin IC, and make an "everell style" 5VSB mod?
                                    • SIDMX
                                      • Nov 2010
                                      • 165
                                      • Mexico
                                      #1018
                                      Cutting the circuit shouldn't be a problem, but you'll need to ID that switcher and get the DS to understand what (if any) changes are needed to successfully "implant" it into another P/S, also note that the feedback for SB is done using one of the two built-in shunt regulators (TL431) in the SC6105 chip.
                                        master hoarder
                                        • May 2008
                                        • 12164
                                        #1019
                                        that's not a size "35" transformer! Heck, I'll say not even 33. Looks like a "28"-er. Probably good enough for 150W continuous. 200W would be kind of pushing it.
                                        Althoug that Jin Yuan has no space for PI coils on the secondary side, it looks like there is a lot of space next to the caps and the tracks for the rails on the solder side are wide enough, so they could technically be cut up and have a PI coil added.
                                        But meh... why bother with that. Just use the parts to fix up a better PSU .
                                        As the guy from Two Stupid Dogs would say
                                        -Aw, isn't that cute? But it's wrong!
                                        I never thought of this. Genius!
                                        Yes, should be possible.
                                        The easiest way would be to take the 5VSB transformer from this PSU as well, so that way you can transfer the entire 5VSB primary side on the new PSU. As for the feedback - almost all 5VSB circuits I've seen use a 431 shunt. Usually the compensation is a simple RC network and very similar between PSUs, so you may not have to change it all, unless the 5VSB has a hard time "keeping up" or overshooting with a load.
                                        • everell
                                          • Jan 2009
                                          • 1514
                                          :Yes, should be possible.
                                          Yes, I have done it several times. Much more fun to experiment, and sometimes watch it blow up, than to simply fix someone else's computer!
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
