the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
Re: the gutless, bloated, and fried power supply hall of shame
CapXon and Ltec would fail anyway... note the unbulged Taicon, those actually seem like OK caps, haven't seen any fail YET. It's less ambient temperature and more ripple current that kills crap caps.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I removed the caps today, and I got a photo with some better light. Now you can really see how bad the heat discolouration is
EDIT: I also took the failed fan apart, and I think there was more to this than just bad sleeve bearings. It looks like there was lots of rust around the magnet on the blade housing and on the motorAttached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by c_hegge; 09-07-2012, 12:45 AM.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Not nice, really. In some worse fans when sometimes the magnet tends to rub against motor I lubricate it with vaseline. Maybe if you will clean it you can as well use itfor conserving again corosion.Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
I probably won't worry. I have a few spare Yate Loon fans which are in much better condition, so I'll probably just replace it with one of them
EDIT: I probably should also add that the plastic washer which holds the blade housing to the motor crumbled when I took the fan apart.Last edited by c_hegge; 09-07-2012, 04:37 AM.I love putting bad caps and flat batteries in fire and watching them explode!!
I wonder if the rust is what jammed it?
Looks like you forgot to desolder the leads of C103?"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
That one really didn't want to come out (maybe due to the generous use of glue on that leg). The other leg broke was I was trying to bend and twist the cap out of there.Last edited by c_hegge; 09-07-2012, 04:20 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Pliers?Less jewellery, more gold into electrotech industry!
YesI love putting bad caps and flat batteries in fire and watching them explode!!
fried Apple power supply
There's me happily using my old Apple PowerBook 1400, then the next time I come to use it, nothing. So I open up the little brown brick (the official power supply) and was amazed to discover the destruction shown in the pik. I have no idea what caused it.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: fried Apple power supply
Looks like a diode and two resistors burned.Muh-soggy-kneeComment
Wow! That really is the most toasty, well-done PSU PCB I've seen. I'm surprised the output choke didn't burn.
Not good.
Although likely salvageable if you cared enough to fix it. I would - extra spare junk fans for the random project never hurt. Sandpaper and a bit of oil is really all you need. When I find a fan that has started to get rust on the stator, I just lube it with machine oil.Last edited by momaka; 09-09-2012, 05:05 PM.Comment
As I stated, I use vaseline, it is better I think. Oil just vaporizes or dries out due to absorption in dust. Vaseline is more durable I think and lubricates even full of dust.Less jewellery, more gold into electrotech industry!
I have a large box full of spare fans. I only ever keep really good fans nowadays.I love putting bad caps and flat batteries in fire and watching them explode!!
Here is an 8 years old Antec that was still running, though a bit unstable. Nice collection of toasted caps awaits:Attached Filesif you find these attachements useful please consider making a small donation to the site
www.kuzyatech.com My blog about things I make, break and fixComment
What model is that?? Looks like some very old topology.Less jewellery, more gold into electrotech industry!
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by eccerr0rIntroducing... the POS-124Z which really is a POS:
Yep it's a POS allright.
I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
So I had to take a peek:
EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?... -
by tamerelaputeHi,
I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
Except the cpu, I cant feel anything getting warmer.
I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
I believe that if the cpu was fried,... -
by x_orange90_xI was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
by LapsmithWhile installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
- Loading...
