the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • c_hegge
    • Sep 2009
    • 5219
    Re: the gutless, bloated, and fried power supply hall of shame
    The UL Number on the PCB (E171766) points to Fai Wong Electronic PCB Co, but they are just a PCB manufacturer, so that doesn't tell us much about who actually assembled the PSU (maybe that's supposed to be Fail Wong Electronics )
    The UL number on the case (E161870) returns no results at the UL database, so it's possibly forged.
    I must say, though, that green logo on the transformer looks familiar to me. I can't remember where I've seen it, though.
    • ttn328
      • Jan 2011
      • 12
      • Vietnam
      #382
      Originally posted by ttn328
      ... just jumbered...
      Sorry for misspelling ... jumpered
      Thanks for all your info. My friend paid 150000 vn dong (about 7 USD) for it, don't know how much power it could supply.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Looks like the transformer is so tiny, I bet it will saturate and blow the switching transistors before it reaches 450 watts xD
        Atleast the heatsinks are somewhat decent, not just thick hunks of metal.
        I wonder if those primary caps actually read 330uF, or if they read 220uF xD
        Any way, those are tiny for a 450 watter.
        Muh-soggy-knee
        • ttn328
          • Jan 2011
          • 12
          • Vietnam
          #384
          Yes, the transformer is very very small, it is smaller than the one of my Pen II Dell 200W PSU.
          • Behemot
            • 4845
            • CZ
            #385
            Well at least there is room enough for some airflow inside
            • mariushm
              • May 2011
              • 3799
              #386
              450w !? You're lucky if that psu goes over 200 watts ! )
              Those rectifiers on the secondary side are rated for 16A and 12A ... so it might do 3.3v @ 16a =53 w , 5v @ 16a = 80w , 12v @ 12a = 144w ... but the transformer itself is designed for 150-200 watts ..
              • c_hegge
                • Sep 2009
                • 5219
                I'd give it 200W without blowing up, but given how little output filtering it has, I doubt if it would be able to deliver anything at all with the ripple in spec.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Yeah, I inferred the 450W from the label. Ofc, they always lie about the wattage rating
                  Muh-soggy-knee
                    master hoarder
                    • May 2008
                    • 12175
                    #389
                    Originally posted by Pentium4
                    They definitely are getting better. They need to at least put a ball bearing fan in there though. And fix the fan controller.
                    Fix the fan controller? What fan controller?
                    These things are designed to run the fan on 12V all the time so they don't overheat. That's why the sleeve bearing fans in cheap power supplies die so quickly. Most of the time there's nothing wrong with the cheap sleeve bearing fans. A ball bearing fan will sure last longer but then the PSU will get filled with dust quickly and it will eventually overheat anyways. It's really best for them to have put bigger heat sinks and bigger parts - then the fan can be slowed down... But that costs extra $$.
                    VENR (fake ?) 450S-ATX
                    Exactly! Who cares about raw output power if the PSU's ripple is in spec only for a fraction of the wattage it can do.
                    With those tiny caps and inductors on the secondary, I'd say about 50W is the MAX usable power you can get out of it before ripple and noise go out of spec. I had a cheap L&C with a similar cap configuration on the secondary and it couldn't even power a 400 MHz Pentium II (24W TDP, 33W max) PC under full load! And all that computer had was a low-wattage S3 Savage 4 8MB video card and a single low-power Seagate HDD.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Check out this "Newegg special" piece of shit....When I opened the case I got a strong smell of burnt silicon and the classic smell of overworked electronics. It was powering a Core 2 Quad 2.33GHz, 4 sticks of RAM, 1 HDD and a 7600 GS. Pretty low load to be honest. Primary caps are Fuhjyyu and the rest are BH. At least they used Late Yoon fans, but the thing was annoyingly loud. Only two 1000uF 16V caps for 12V filtering
                      • mockingbird
                        • Dec 2008
                        • 5488
                        #391
                        The chassis is black, that has to count for something...
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          It just turned black from getting so hot due to 30% efficiency
                          • Behemot
                            • 4845
                            • CZ
                            #393
                            ERL-35 transformer, isn't it about 350 W continuous/400 W peak?
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              I think that's the only good thing on it. I might take the switchers though, it has two 13007's and a SW2N60
                              Uploaded a pic of the secondary. Look at those gross caps...Output rectifiers from left to right 30A, 20A, 30A
                              • Behemot
                                • 4845
                                • CZ
                                #395
                                I keep almost everything. Bit like ant, dissect it into small pieces every time You can use input caps for 250W PSUs, NTC when it blows somewhere, toroids at least for cores to make replacement (if you posess inductance meter). Resistors and stuff are also a need from time to time
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  #396
                                  ^ Crappy caps / lack of output filtering aside, that Logysis is not that bad. My friend has the "480W" version at his repair shop - now that one is a big piece of shit. It cross-loads very easily and even hisses/squeals if the load is slightly unbalanced or too heavy. And the heat sinks are paper-thin - pretty much you see in the lowest of the lowest-end PowMax and SunPro.
                                    What is that? Glue... snot... dried electrolyte... a combination of all three...?
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      I will still call this thing crap got pics of the 480W?
                                      Probably all 3 you can't see really in the pics but that diode on the 5VSB circuit is very dark around it
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        I've seen that a few times in Keerda/Logisus PSUs, and it always dries out the two caps.
                                        • Pentium4
                                          CapXon Be Gone
                                          • Sep 2011
                                          • 3741
                                          Yeah this one says Keerda Electronics on it. Is that their main OEM?
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • x_orange90_x
                                            Samsung UN65AU8000FF fried by water
                                            by x_orange90_x
                                            I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                                            10-16-2025, 08:40 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
