replacing schottky diodes on a AV power supply
  • CapLeaker
    Leaking Member
    • 8148
    Re: replacing schottky diodes on a AV power supply
    Originally posted by DjKrish
    SR340 - 5v plus
    SR320 - 12v plus
    B31V present
    this doesn't make any sense. Did you install the other schottky backwards?
      • 31015
      maybe the 340's are bad
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Agreed.
        Either the SB340's were bad ad STJ suggested or connected backwards.
        -OR MAYBE-
        PSU had a hickup by coincidence when the SB340's were installed and somehow voltages were off only then.
        Best way to know is to repeat the experiment. Better yet, test the SB340 diodes outside first - not just with a multimeter, but rather pass 12V DC through one and feed a dummy load. Then reverse the diode and try again. In the reverse direction, the diode should be blocking any current from flowing. If it's partially shorted (i.e. shorted with high resistance), it will pass current in both directions.
          Bad or faked SR340?
          • DjKrish
            • Oct 2012
            • 354
            • SG
            Fake? That i could suspect. The supplier said its a chinese company made. Sighs. Looks like i need to reorder a good quality ones again
              Do you have any broken boards that you can find some similar diodes that you can try?
                • 31015
                just check any scrap psu's you have for a TO220 package schottky.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #28
                  Why not test those SB340 diodes with power? IMO, no need to waste time and money looking for new diodes if you can't confirm the old one(s) is bad.
                  Take a 20V laptop adapter and something with a heating element that has about 10 Ohms resistance and connect it as a load on the laptop adapter through the diode. Then measure to see if the diode has proper voltage drop in the forward direction. After that, reverse the diode and test again. It should block current from going to the heating element. If you can confirm this, then your SB340 diode(s) are not bad and maybe there was another anomaly that happened at the time when you tested the PSU.
                  • DjKrish
                    • Oct 2012
                    • 354
                    • SG
                    #29
                    Thanks guys for the inputs. Ive been away for quite a while now. And the parts arrived as well. Fitted in 2 pieces of sr320. Works perfectly. Wonder why the rest didnt work? Hmmmm
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #30
                      Well, if you want to get an answer for that, or at least get a clue, do the test I suggested above with the old rectifiers and the power adapter. If they test bad, then we know. And if they don't, then they weren't the issue and probably something else happened that you didn't realize was happening.
                      • DjKrish
                        • Oct 2012
                        • 354
                        • SG
                        #31
                        Already tested, its just some cheap Chinese diodes thats not even accurate. Well, the luck was just not there. Ive returned back those diodes and request for originals.
                        • DjKrish
                          • Oct 2012
                          • 354
                          • SG
                          #32
                          Tested the unit, everything works perfectly fine with the new original diodes.
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • caspian
                            What Zener Diodes on a Linear Power Supply
                            by caspian
                            Dear members,
                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                            In addition, I discovered that its zener diodes are defective.
                            I can replace the burned transistors.
                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                            Therefore, I cannot replace the zener diodes.
                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                            no schematics are available...
                            05-26-2025, 12:38 PM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
                          • shamsudeen
                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                            by shamsudeen
                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                            07-19-2025, 07:14 AM
