Amazon Basics Laminator design
  • pintglass
    • Jul 2019
    • 79
    • United Kingdom
    Hi
    I've just purchased an Amazon Basics laminator, to use for PCB toner transfers but thats not the reason for my post.
    I opened up the unit to see what was going on inside to find that it contains 3 normally closed temperature sensors.
    I have draw a schematic of what i believe to be how its wired up, but if I've draw it correctly I don't understand the purpose of the third 130 degree temp switch, as regardless of whether the other 2 temp switch's had switched off the third would remain on therefore defeating the object of the other 2 switch's.
    I have attached the schematic that i have draw and some images of the device so if you could take a look to see if I'm mistaken i would be grateful.
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Amazon Basics Laminator design
    Is the DPDT switch "center off", by chance?
    If that's the case, then the two "other" positions represent operation at 115C and 125C ("operation" implying the motor is running to pull the material through the laminator). The 130C cutout then acts as a standby/preheat setting -- with the motor off (as soon as anything passes through the laminator, the temperature will drop to a point where the appropriate 115/125 cutout acts to control the temperature).
    Note that most laminators are designed to laminate bits of paper in plastic encapsulants. So, you may find the heating element underperforming for your needs.
    [I have to give the heating element in my laminator time to "catch up" if I have been laminating large (e.g., 8x14") items -- or, set it to run hotter than desired (I have a variable temperature control)]
    • Harvey
      • Apr 2007
      • 264
      I've over driven one of these type of basic laminator before now by changing the thermal switches for higher temperature and used it for a while for making PCB's. It lasted about a year before the plastic rollers holding the rails and rollers started to melt and it became useless.
      It was replaced with a variable temperature model that can hit the required temps without fear of it melting or bursting into flames.
      • pintglass
        • Jul 2019
        • 79
        • United Kingdom
        Yes the DPDT switch is centre off.
        I still don't get how the heater could be preheating until I've switched to either side as the heater is switched on the neutral side. Sorry I may be just being thick.
        • R_J
          • 9535
          It does'nt make sense. Does the unit start to heat up when first pluged in and the switch in the OFF position?
          It could be that one thermal cutout is just to control the "ready" led
          • pintglass
            • Jul 2019
            • 79
            • United Kingdom
            The unit doesn't heat in the off position it only starts heating when the rocker switch is placed in the low temp or high temp position as the heater is switched on the neutral side at the same time as either thermal cutout's are switched in.
            The unit has got a ready led which I think is switched on from the 130 degree temp switch. I didn't draw that in as i haven't taken the small PCB out to look at how its wired up.
            The 125 degree and 130 degree seem to switch off and on at around the same time.
            To me the lower temp setting seems pointless as when this position is selected with the rocker switch it wouldn't turn the heater off until all 3 thermal cutouts are off no matter what.
              • 31012
              so your using laser-toner??
              • pintglass
                • Jul 2019
                • 79
                • United Kingdom
                Yes that's the plan, I was looking at changing the thermal cutout's for a higher Temp.
                  • 31012
                  have you seen the project to use a modified $50 laser printer to print directly to the pcb and fuse it in one pass?
                    • Jul 2011
                    • 6039
                    Please post this link
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Marco Reps has done a video printing direct to PCB but he uses acetone vapour to fuse the toner.
                      https://m.youtube.com/watch?v=5FWUul62irY
                        • 31012
                        i'm surprised he didnt just vaporise the copper with a co² laser knowing him!!
                          • 31012
                          http://www.instructables.com/id/Modi...Direct-Laser-/
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Yeah, he has a few videos a couple of years after his laser toner using his CO₂ laser to cut traces.
                            • CapLeaker
                              AcuRite 5 in 1 temperature sensor replacement repair
                              by CapLeaker
                              Got a new victim:
                              AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                              A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                              B: stuck at some temperature and maybe updating once in 12 hrs or so.
                              Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                              04-15-2025, 01:32 PM
                            • asdas09
                              Temperature to remove chips from motherboard
                              by asdas09
                              What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                              I have device Sugon 202. I'm used also normal flux and rosin flux.
                              09-12-2023, 12:44 AM
                            • Dreigas
                              ISL95880HRTZ desoldering temperature
                              by Dreigas
                              I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                              Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                              09-13-2024, 10:59 PM
                            • jm1234
                              9V relay temperature 40C
                              by jm1234
                              Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                              I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                              05-09-2024, 03:03 AM
                            • Windows8RTMUser
                              Repair knowledge for -55c CPU temperature on AMD Ryzen CPUs in bios, the AMD Sideband temperature sensor interface (SB-TSI)
                              by Windows8RTMUser
                              Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
                              In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
                              I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
                              tags:...
                              Today, 07:26 PM
