Solytech/deer getting better
  • i4004
    • Oct 2006
    • 2029
    Re: Solytech/deer getting better
    could you post some images of that fortron with 2 tr. design?
    i presume it's this
    http://www.newegg.com/Product/Produc...82E16817104951
    if that one indeed has 2 tr. circ. then i need to stop generalizing.
    <wink>
    • everell
      • Jan 2009
      • 1514
      I purchased my Allied as a used one among several. It looks like brand new, very clean inside. So I only spent one dollar on mine. Yes, it has the 2 transistor 5vsb circuit. I started looking at it, and the Allied is totally dead. The fuse is good, the input voltage across the two stacked input capacitors is 320 volts. But the 5vsb circuit is dead, dead, dead. I measured the resistance of the 2N65 transistor - looks OK. Even tried replacing it with another. Still dead. I also took out the other transistor (2222A) and measured it. Looks OK. So no shorts. The transformer measures OK for ohms. So now will have to look at and check out parts one by one. I have never been able to fix one - unless you call "permanently" fixing one - that is, putting a transistor into orbit! So if I don't find a fix in a reasonable amount of time, I will just gut the circuit and install one of my DM311 circuits on this power supply.
      This board has resistors and capacitors mounted to top of pc board instead of the little surface mount components on bottom of board (like the better Bestecs). It also has the chip of the year - 2005 pwm/supervisor chip. I get the impression that this must be leftover war surplus or something. No date on pc board to give a clue.
      The main switching transistors on mine are 13007.
      Nice power supply to play with for a buck!
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        i presume it's this
        <wink>
        http://www.newegg.com/Product/Produc...82E16817103915
        That one
        Kinda hard to get a pic, it is in a server rack running a home server for a friend who lives about 20 miles away, and I only go over there once every 2 weeks for a lan party. It does do pretty well being cooped up in that server rack with a dual p3 1ghz board. Just based on a old design.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Originally posted by 370forlife
          So you wouldn't use a low watt fsp, hipro, delta, enermax, corsair, etc... because those too only have 2 capacitors per rail?
          ive seen better... even my 300w delta is built better than that.
          sigpic
          (Insert witty quote here)
          • i4004
            • Oct 2006
            • 2029
            everell, but it seems to me (from your pics) that power tr. for +5vstby is blown?
            or is it just optical illusion?
            this pic
            https://www.badcaps.net/forum/attach...chmentid=11759
            look at it on 370s pic
            https://www.badcaps.net/forum/attach...chmentid=11470
            that seems like a proper price for it.
            <wink>
            i would pick delta or something cwt made over fortron, but for the price of fortron...
            <wink>
            this fortron
            http://www.ve-mil.hr/opis.aspx?prika...=0&Sifra=21552
            is essentially cheapest decent psu i can find here...
            though(just now i see it) this
            http://www.ve-mil.hr/opis.aspx?prika...&Sifra=1011557
            is not too bad price-wise...
            what's inside, i wonder....
            • everell
              • Jan 2009
              • 1514
              Back to the Allied power supply ...................... it is fixed, and running. Turns out that a wire lead was shorting across to another trace grounding out the 5vsb. Judging from the way it looks, this was probably a defect from the factory, So much for Solytech improved quality. And I finally fixed one of them 2 transistor 5vsb circuits.
                master hoarder
                • May 2008
                • 12174
                • Bulgaria
                #27
                I wouldn't be too surprised if they were, whichever war that might be for .
                I've seen some '2002' or '2004' variants as well, but they seem to be very rare.
                Congrats on the fixed Allied.
                If you ask me, their QC is still better than most other gutless units, especially when compared to Leadman, Raidmax, and a few others which have absolutely no indication (be it a sticker or mark) that they passed QC.
                • everell
                  • Jan 2009
                  • 1514
                  The transistor was OK, that was just flash from the camera.....an optical illusion!
                  • i4004
                    • Oct 2006
                    • 2029
                    #29
                    that snafu aside, you probably take best pics of psu guts i've seen here...
                    and yes, i checked what camera you use, it seems to be some cheapo kodak..heh...
                    well done.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Lookie here what I found!
                      Sorry to dig this thread up, but I have an Identical PSU to everell's one here. one of the transistors on the 5vsb has exploded. I'm thinking of recapping it and giving it a DM311 PWM chip mod, however, I'll need some help. everell, would you be able to draw up a few diagrams of the 5vsb of this PSU (a bit like you did in your Bestec ATX-250-12E thread?)
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        I bought the fsp atx-300pa off newegg. Its quiet but i dont trust. It has shit caps (teapo, capxon, and Has a so-so adda fan.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #32
                          Teapo is nice if it cooled enough.
                          • weirdlookinguy
                            • Sep 2007
                            • 1638
                            #33
                            Some of the older Adda fans have a history of seizing up after a few years of service. I don't know if their newer fans still do this.
                            Don't worry about it, but do check it every now and then.
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              Um...im selling it. Still better than the sunbeams you often find on some ebay pcs
                              • everell
                                • Jan 2009
                                • 1514
                                Compare this power supply which I modified with the one you have. They should be very close.
                                https://www.badcaps.net/forum/showth...=raptor&page=2
                                It includes the drawing of the 5vsb before conversion and the drawing of the new 5vsb circuit.
                                The starting point is to draw the circuit which you actually have. Then draw what you plan to change. Then you can begin removing parts and replacing parts. Kinda like cut and paste!
                                • everell
                                  • Jan 2009
                                  • 1514
                                  Also study this thread showing a recent Solytech power supply. It has the Infineon ICE series chip in the 5vsb circuit. I have included schematics in the thread below
                                  https://www.badcaps.net/forum/showthread.php?t=11416
                                  There are several different pwm chips you can use in the 5vsb circuit.
                                  • kotel studios
                                    DEER B350ATX PSU - tips on making it safer and "better"
                                    by kotel studios
                                    Since it looks like my excellent power PSU chances at living are now close to zero, I decided to give a shot at upgrading this DEER B350ATX PSU.
                                    At first glance it looks like, well.... a shitty cheaped out DEER garbage (cause it is). Although it does have an LF 1250CD00 filter transformer (at least I think that's what it is) 😆
                                    Tiny heatsinks, small transformators, single-pole ON/OFF switch. You name it.
                                    Now since this one works, I'd like to know how can I make it safer and better (besides burning it with napal 😃). My plan is to make the switch double-pole...
                                    03-04-2025, 12:09 PM
                                    by momaka
                                    03-12-2025, 03:42 PM
                                  • Pentium4
                                    Solytech SL-8360EPS analysis + mods
                                    by Pentium4
                                    Unfortunately I got rid of most of my power supplies a few years back so I hunted some on eBay. Of course I could have got some with already good caps but what's the fun in that when you can save unsuspecting victims on eBay from buying something that could cause them problems?
                                    I'm also aware that Solytech is capable of making a decent unit, minus their caps. This one is on the 80 Plus website as being able to do its full wattage.
                                    I bought two of these as a lot. One was made in July 2017 and one was made in September 2017. Interestingly, the only...
                                    08-04-2023, 06:21 PM
                                  • flibidy
                                    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                    by flibidy
                                    I have here a Magnum IA.100 which belongs to my parents.
                                    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                    What Ive done........
                                    01-01-2025, 01:26 PM
                                    Copy DMI info easily with Hex editing software and Macro script
                                    by SMDFlea
                                    Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                    Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                    02-28-2023, 02:14 PM
