Solytech/deer getting better
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Brand spankin' new rosewill 350W psu. $25 on newegg, my dad needed one for his computer, combined with the other parts the cost of getting the seasonic 300w was too much. Shaved a bit off by getting this instead. Very impressed by build quality actually.
    This has the same PCB layout as my rebuilt Rosewill 350W, same ratings, but much more parts.
    Overkill input filter, 3 X caps, 4 Y caps, 2 coils. (2 Y caps, 1 coil, and 1 X cap on the pcb on the receptacle)
    YC Caps on secondary, primaries are Anodia. Actual bridge rectifier good for 400v, 6A. Secondary silicon are pretty beefy. 12v and 5v have 30A, 45v parts, 3.3v has 20A, 45v part. Actual 35 transformer, not the fake 35 like in my other deer, about 1/2" taller than my 33 old transformer from my yuelin. Fan is a very quiet silence (same company enermax uses for fans,) sleeve bearing and is temp controlled, with the sensor bolted to the secondary heatsink.
    Once done being under surgery from my soldering iron with new nichicon PW's, it will be a pretty good psu. 5vsb before measured 5.07, all other voltages with no load were 12.51, 5.17, and 3.23.
  • Newbie2
    • Sep 2005
    • 885
    Re: Solytech/deer getting better
    I must say that this Solytech/Deer power supply is impressive looking, considering the previous history of Deer-made power supplies.
    I guess Deer wants to improve their reputation under the Solytech brand name. At $25 USD for that power supply, it is a very good deal considering the quality (besides the electrolytic caps used).
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      The only thing that concerns me is the 20A 45v part on the 3.3v, as that is the max rating for the 3.3v. Cutting it a bit close if you ask me, but it is capable of it, but probalby at 25C. Not really digging the puke-green caps, but they are not visible, and are gone now. Also, can't find any info on those strange Anodia caps.
      I don't think this little emachines will draw nearly that much from the 3.3v though.
      BWA HA HA, look at the date stamp on the pictures, I think I need to reset the clock on this stupid HP camera, can't take pics for crap. Those were the only 4 non-blury picks out of about 25.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Not that bad at all for $25. Well, the capacitors could have been at least Teapo or Ost, but other than that this power supply actually looks like something that you can use.
        How's the soldering on the other side?
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i noticed that the pcb has a spot for a bridge, not a spot for 4 diodes with a bridge monkeyed in there. not too bad. thin wire?
          heatsinks could be better.
          im curious: is a-power getting better or are they still chicken crap?
          sigpic
          (Insert witty quote here)
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            Well, they're all nichicon now
            I didn't get a chance to flip it over and check out the soldering. My dad wanted it done and I didn't want anything to happen to it. I think I might buy one for myself to do a complete run over with.
            @ratdude747, I noticed it dosen't have any provision for 4 diodes. FINALLY.
            • Oklahoma Wolf
              • Dec 2005
              • 353
              Bridge could use a heatsink.
              I still don't trust it - looks a lot like the Allied I reviewed. Looked half decent, but then it went and blew out the primary side when I asked for the label ratings.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                last ones i saw for sale new at the dayton hamvention were the same trash with new look and logo's.avoid like the plague.
                • Newbie2
                  • Sep 2005
                  • 885
                  But for an eMachines computer (I'm guessing low end hardware) that this power supply is going into, it should be sufficient.
                  At least Solytech/Deer attempts to manufacture a decent product.
                  My gaming PC:
                  • linuxguru
                    • Apr 2005
                    • 1564
                    Yes, it looks passable, at least for 300W. Should be fine with upgraded electrolytics. It's worth checking out the ESR of the funky green caps. I've never heard of Anodia - maybe sister firm of Cathodia.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3113
                      The fuji electronics 2sc3320's are the same primary switcher's used in the old CWT 420W (or antec 400W,) and that could run it's ratings...so you should have gotten at least 400W from it. In your review it looks like something on the opposite side of the switcher that didn't blow is what blew out, and that took out the switchers.
                      I know because I removed the primary switchers from a antec 400W based off the CWT-420, and it had those exact primary switchers, and they now reside in my rebuilt YueLin.
                      • everell
                        • Jan 2009
                        • 1514
                        Lookie here what I found!
                        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          still not enough caps on the secondary side for my liking...
                          sigpic
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            Who makes those radioactive green caps Crapxon?
                            • everell
                              • Jan 2009
                              • 1514
                              Anodia (second cousin to Cathodia)
                              This Allied is totally dead - must be the one Oklahoma Wolf blew up! Or perhaps it has the same problems??? Will have to wait till I get some time to fix it.
                              • i4004
                                • Oct 2006
                                • 2029
                                do i smell a nasty 2 transistor stby circuit there?
                                i would say it's still rosebud...you know, like the cunt in the wells' movie...
                                <wink>
                                btw. 370, to reiterate what i said here
                                https://www.badcaps.net/forum/showth...1351#post81351
                                you don't really know if you helped it with those nichicons, or you provided more ripple for the mobo and hdd...heh...
                                in other words, why the well didn't you get fortron instead?
                                won't 25$ buy you fortron instead of this shit?
                                as kc puts it
                                "avoid like the plague."
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3113
                                  <wink>
                                  as kc puts it
                                  Though the nichicons may have made ripple even worse, there are 2 reasons why I did this. This emachine is seldom ran and when it does it dosen't do much more than check the mail or maybe watch a youtube video. p4 2.4 with integrated video dosen't do much.
                                  1. the allied 500W reviewed on JG may have only gotten to 384W, but never got over 35mv of ripple. So I'm guessing 50mv of ripple is probalby what I am getting with these nichicons. But who knows, I don't have a oscilliscope or a load tester.
                                  2. Longevity. I don't know how trustworthy Anodia and YC caps are, so might as well replace them with something that won't blow.
                                  The reason why I didn't get one of those fsp's is because usually fsp's don't have that good of ripple control, so it's probalby about the same thing there, and I have seen some of these new solytech's can be pretty well made so I thought for the same price and probalby the same grade of caps I can see how well made one of these new ones are. Kind of a experiment. Yes, a FSP is well built we already know that. But how nice are new solytechs? Took a gamble, and I was pleased.
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3113
                                    So you wouldn't use a low watt fsp, hipro, delta, enermax, corsair, etc... because those too only have 2 capacitors per rail?
                                    • i4004
                                      • Oct 2006
                                      • 2029
                                      any proof for this claim?
                                      (i don't mean for "probably" but for the claim that fortrons have ripple issue)
                                      btw. proof is NOT if you've found one review on jonnyguru of 700w fortron that has somewhat more ripple on particular rail.
                                      about longevity..heh..but what is stby circuit there?
                                      i see two transistors there and i see lytic, and i smell trouble there....
                                      what did you do to solve THAT critical issue of cheap gutless wonders?
                                      if that circuit is indeed what it looks it is, it can blow mobo.
                                      when you buy fortron you know you have proper +5vstby circuit.
                                      AND you know you don't have to change any caps.
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3113
                                        The 300W fsp on newegg too has a two transistor 5vsb circuit, it is based on a old fsp design, with all capxon caps. I know this because we have one running a home server at a friend's house. As long as you have a good cap down there in the two transistor circuit, it is not much of a issue. I replaced that YC 50v, 47uf with a nichicon PET 50v, 47uf.
                                        Please tell me you are not a OCZ fanboy, too? I'm not saying in a solytech fanboy, BY FAR, but I'm just saying not all FSP's are gods and can trounce any power supply they come by, because they can't hold a candle to a zippy or a delta.
                                        As I said, it was a experiment. I wanted to see how well made a new solytech is, and it is quite well made. Done and done.
                                        • kotel studios
                                          DEER B350ATX PSU - tips on making it safer and "better"
                                          by kotel studios
                                          Since it looks like my excellent power PSU chances at living are now close to zero, I decided to give a shot at upgrading this DEER B350ATX PSU.
                                          At first glance it looks like, well.... a shitty cheaped out DEER garbage (cause it is). Although it does have an LF 1250CD00 filter transformer (at least I think that's what it is) 😆
                                          Tiny heatsinks, small transformators, single-pole ON/OFF switch. You name it.
                                          Now since this one works, I'd like to know how can I make it safer and better (besides burning it with napal 😃). My plan is to make the switch double-pole...
                                          03-04-2025, 12:09 PM
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • Pentium4
                                          Solytech SL-8360EPS analysis + mods
                                          by Pentium4
                                          Unfortunately I got rid of most of my power supplies a few years back so I hunted some on eBay. Of course I could have got some with already good caps but what's the fun in that when you can save unsuspecting victims on eBay from buying something that could cause them problems?
                                          I'm also aware that Solytech is capable of making a decent unit, minus their caps. This one is on the 80 Plus website as being able to do its full wattage.
                                          I bought two of these as a lot. One was made in July 2017 and one was made in September 2017. Interestingly, the only...
                                          08-04-2023, 06:21 PM
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
                                          Copy DMI info easily with Hex editing software and Macro script
                                          by SMDFlea
                                          Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                          Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                          02-28-2023, 02:14 PM
