Bypassing Passive PFC In ATX Power Supplies
  • Hitto
    • Apr 2019
    • 95
    • Italy
    I'm planning to remove and bypass the passive PFC transformer/coil on an ATX power supply.
    I don't care about reduced efficiency. I'm worried, howewer, about any problem in terms of increased ripple in the primary rail.
    Does the removal of the passive PFC has negligible downsides in terms of increased ripple?
    Thank you.
    • 31284
    Re: Bypassing Passive PFC In ATX Power Supplies
    i doubt it effects the ripple.
    • Hitto
      • Apr 2019
      • 95
      • Italy
      But it reduces harmonics, correct? It looks that it may have some benefits in terms of less stress placed to the components placed onto the primary (based onto the following topic: https://www.badcaps.net/forum/showthread.php?t=67663).
      • Stefan Payne
        • 1267
        passive PFC is just a big fat coil.
        So its only a bridge you need.
        • Hitto
          • Apr 2019
          • 95
          • Italy
          That's good to hear.
          If you have more informations about any possible drawback (I'm going to upgrade the primary capacitors from 560uF to 820uF and the goal is to combine as many improvements as possible) feel free to write them.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            You MIGHT experience slight bulging on some PSUs. YMMV depending on how good was the PSU built.
            The one I fixed in that thread you mentioned managed to somehow make a Hitachi HP3 cap (820uF 200v if my memory serves me right) slightly bulge. The PSU is still running fine, although I sold the PC I installed the PSU in and bought a GTX750Ti.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
              master hoarder
              • May 2008
              • 12175
              No, that would be APFC which puts more stress on the primary caps.
              PPFC (large line-connected inductor) *shouldn't* put more stress on any of the primary components. However, the reasons I say *shouldn't* is because there are cases where PPFC can stress the primary caps. Like all inductors, a PPFC coil may produce significant inductive kickback in the event of sudden power loss. Thus, if you live in an area where you get frequent power outages and power dips (or very dirty power), then it may be possible for the PPFC coil to put more stress on the primary caps. But in general, that is very rare. So I suggest you leave it, as you get added benefits of extra filtering from noise on the line input and better PF.
              • Hitto
                • Apr 2019
                • 95
                • Italy
                It should also limit inrush current, isn't it?
                By the way, this power supply has no NTC. Which should be a practice for increased efficiency but I do not like that.
                I am planning to add a 2.5 Ohm NTC: I know that the value is usually higher (8-10 Ohm) but it is just for reducing a bit the inrush current.
                The rating of the NTC is 5.5A but I do not know if it refers to the instantaneous current or the operating current.
                  NTC has nothing to do with efficiency, once the NTC gets hot the resistance will go down but will not be 0 Ohms so you will have power loss on the NTC.
                  The purpose of BTC is to limit the inrush current when power is first applied to the circuit, once that is over the NTC should be bypassed so it is no longer in the circuit.
                  • Hitto
                    • Apr 2019
                    • 95
                    • Italy
                    Passive PFC removed. Just noticed there is a 1uF/250V Mylar between "A" and "B" pins where the PFC was desoldered. And a 22uF/50V capacitor with its negative leg connected to "A". Shall I remove just the Mylar?
                    • Hitto
                      • Apr 2019
                      • 95
                      • Italy
                      More informations.
                      This is a F.S.P. with almost the same design:
                      https://www.anandtech.com/Gallery/Album/312#3
                      No mylar but the 22uF capacitor is there.
                      • Hitto
                        • Apr 2019
                        • 95
                        • Italy
                        I've found several revision based onto the same design and looked at the differences.
                        This one is without PFC:
                        (From: www.hardwaresecrets.com)
                        The differences:
                        1) Anti-series diodes
                        2) 22uF/50V capacitor
                        3) 1uF/250V Mylar capacitor
                        Simply bypassing the PFC will at least short the 1uF/250V capacitor, connecting both its legs together as it had, prior to PFC bypassing, one leg connected on the input wire of the PFC and the other one connected on the output wire. A snubber, maybe?
                        The anti-series diode protects the PFC in case of surges and is also suggested on official PDFs of PFC designs. Dunno about the 22uF/50V capacitors and I would like to know its purpose, if possible, for the sake of learning.
                        Some informations which will be useful to other members of the forum:
                        This power supply is quite sturdy and worked good as it was, so I was worried about removing the PFC transformer and do more harm than good.
                        The PFC was measured and, at least in this case, also acts a huge inductor (rated 26mH with a resistance of 0.20 Ohms) making to my opinion things a bit better for at least the diode bridge and the primary caps.
                        Not simply a matter of bridging two poles because there are also quite a bunch of components around it. I suggest keeping the PFC and the other components. At least in this design.
                        • bauto601
                          KDM 480W PSU upgrade succes! (opinions?)
                          by bauto601
                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                          A "nice" YoungYear unit? - Badcaps
                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                          12-26-2023, 03:05 PM
                        • chth96
                          Is it no harm to replace with capacitor without ripple current rating?
                          by chth96
                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                          Rubycon YK DataSheet (b...
                          04-19-2024, 05:19 AM
                        • Antonynl
                          What are typical ripple voltages on a laptop motherboard?
                          by Antonynl
                          I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                          So I have two questions:
                          1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                          2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                          Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                          12-09-2022, 06:51 AM
                        • iMic
                          Vintage AT Power Supplies - Selecting Capacitors
                          by iMic
                          Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                          The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                          02-19-2023, 06:45 PM
                        • Ady2017
                          Is there a manufacturers tolerance for ripple?
                          by Ady2017
                          Hi all
                          I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
                          As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
                          The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
                          11-13-2021, 11:46 AM
