Removing PFC from PPFC PSU?
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    So I've recently got a dead nJoy 500W PSU. ERL39 transformer (real),2SC3220 transistors, sleeved cables and pretty thick heatsinks, all nice stuff (except caps which are ChengX but that's not the point for now). It even has a pretty beefy bridge rectifer. (although no heatsink on it)
    It came to me with two bad Fhy 1000uF 200V caps. I replaced them with some 680uF 200V caps and bypassed the PFC connector, and temporarily replaced the glass fuse with a 100W lightbulb.
    On powering on, I only get a flash of the light bulb and a quick click (about a split second) and no fan movement or nothing.
    Is there anything I should remove? I have a feeling I haven't fully disabled the PFC circuitry.
    I really wish to fix this PSU since it's pretty much full of parts. Of course, after fixing it (means when it will finally power on fine and voltages will be within range) it will probably get back some new 1000uF 200V caps (hope I can snatch some Pannies or Rubies for it to go with the black PCB) and a nice recap on the whole secondary.
    Oh, and it has dual rails, and I'm not even kidding. The PCB literally has two separate 12v spots where the wires go.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8709
    Re: Removing PFC from PPFC PSU?
    PPFC is basically just filtering the input a bit, I'd think it's a lot more reliable than APFC which would be harder to bypass/rebuild especially if it would need a tripler or something to get the voltage needed for the next stage.
    Not sure why one would want to remove PPFC?
    At least if the light bulb isn't solid on, you don't have a short... does it work? I'd imagine the 5VSB should work with the light bulb in that position?
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      • Romania
      No voltages come up, just a click from the primary heatsink. The bulb does flash once though. Same behaviour if I short the green wire to GND.
      I want to remove the PPFC because I installed it in a PSU shell that doesn't have the space to screw in the PFC.
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8709
        Well if the bulb lights temporarily, it's charging the primary caps and likely you didn't cause an open circuit while removing ppfc.
        Now you just have to go through regular debugging starting with whether 5vsb is working? then you can go and see if the controller ic is good for starting up...
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          • Romania
          I'll put up the multimeter and check.
          Although I have a feeling 5vSB is not working even though the caps aren't bulged (ChengX tho, going to replace them) they may have failed.
          I also have found some pics of a non-PFC variant and will see what components will need removing in case I didn't fully disable the PFC circuit.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            • Romania
            Okay, some updates:
            1. The switchers weren't 2SC3220 but 2SC3320.
            2. Both switchers were kaput - at least one of them had a huge burn mark on it.
            3. 5vSB did come up even with the bad 3320s, strange enough, at 5.21V.
            4. I'm not sure but there might be a bigger short somewhere or I must've screwed up somewhere, because after replacing the bad 3320s with a pair of 2SC4106s, the PSU would click and the lightbulb would constantly flash. A few seconds later smoke came out of one of the 4106 (interestingly the same one near the main transformer, just like the 2SC3320 that had a burn mark) and I quickly turned off the PSU.
            Any ideas what could be wrong with it? I'm ready to give up on this as I've replaced a whole lot of stuff.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8709
              5VSB has its own switcher, so the main switchers don't need to be working for 5VSB to be up.
              hmm. Wonder if the main controller chip died after the small caps blew up. Not sure...
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                If you have a bipolar transistor for the main 5VSB switch then the main controller chip is going to be on the secondary and have absolutely nothing to do with the 5VSB. The standby supply is what turns the main controller chip on. I am 95% sure you have the classic two transistor switch circuit for 5VSB, check out some ATX power supply schematics on the internet and you should find a pretty good match for your circuit, which will help you troubleshoot it.
                A working TV? How boring!
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  • Romania
                  Main chip is a KA7500 and doesn't look burnt.
                  And for the record, it wasn't the small caps that blew, but the big 1000uF 200V caps that blew.
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1866
                    • Romania
                    Well, I finally fixed it.
                    Seems that somehow the standby switcher was bad too. I replaced the 2SC4106s with another pair of 13007s (temporarily, I plan to get some new 3320s soon) and the IRF3N80 with a BU3150AF from a old iMicro PSU and it came to life. Also main caps were already replaced with Ricon 680uF 200v caps I had from another PSU. Not going to replace these since I don't have bigger replacements and they work fine for me.
                    I replaced the casing with one from a RPC 500LBL PWPS-050000L-BE01A (no joke, that's the model number). Rectifiers are 30A for both 5v and 3.3v and 12v has two 16A rectifiers in parallel. (it originally had 2 shorted 20A rectifiers.)
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                    • repair-it
                      TOSHIBA DLP 52HM95 How to reset timer module on bulb
                      by repair-it
                      I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                      Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                      10-11-2023, 07:18 PM
                    • ezenia
                      LUMIMAN Smart Bulb IC ID?
                      by ezenia
                      I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                      In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                      04-28-2025, 05:56 PM
                    • nicktasios
                      Macintosh Quadra 840AV PSU
                      by nicktasios
                      I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                      12-22-2024, 05:07 AM
                    • ygorsan
                      LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
                      by ygorsan
                      Hi everyone,
                      I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
                      🧩 Problem Summary:
                      • The TV keeps scrolling through the menu or selecting items by itself.
                      • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
                      • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
                      • I
                      07-28-2025, 08:34 AM
                    • JimBanville
                      Replacing incandescent bulb on Pioneer LD player with led. Need help :)
                      by JimBanville
                      I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
                      Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
                      01-24-2023, 07:49 AM
