	This is a sticky topic.
 Notice that it is the same model with this charger but they are different inside.
 They never fail. I don't think they are so bad after all.Comment
 They may not fail, but these single-transistor self-osc. designs have absolutely no feedback. I guess for a phone, that is okay since the phone does have some high quality internal regulators to charge the battery. Just don't try to use those chargers for anything else that requires a constant, stable voltage.
 I'm still surprised Astec would build something like that, though. I have a bunch of old PSUs made by them, and they are all top-notch, high quality inside with all Japanese caps.Comment
 FSP FSP-300-60GHS
 180uF 420V Teapo LH primary unit.
 2200uF 16V OST RLS before +5VSB inductor with 1000uF 16V Suscon HG after it.
 2200uF Teapo SZ before and after +3.3V inductor.
 1000uF 16V Suscon HG before and after +5V inductor.
 1000uF 16V Suscon HG before +12V inductors and on both +12V rails after each inductor.
 1000uF 16V Suscon HG for -12V rail.
 SDB30A40CT rectifier for +3.3V and +5V rails.
 STPS30L45CT rectifier for +12V rail.
 GBU606 primary side rectifier.
 FSBH0270 IC for +5VSB.
 FDP18N50 with BYC5-600 rectifier for PFC stage.
 AOTF8N50 x2 for output stage.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
 Those heat sinks look awfulI love putting bad caps and flat batteries in fire and watching them explode!!
 Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
 Yeah, as Fortron increses efficiency, they use smaller and smaller heatsinks.Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts Half of the computer problems is caused by bad contacts
 Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
 yeah, but they are still too small (unless that PSU is 80+ platinum, which I doubt very much)I love putting bad caps and flat batteries in fire and watching them explode!!
 That's why, despite general talk, their PSU's aren't really quiet Less jewellery, more gold into electrotech industry! Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts Half of the computer problems is caused by bad contacts
 Might look inadequate at first glance but it's really not.
 FSP-300-60GHS is an SFX type and it's 80+.
 20% of 300w is only 60w of heat to cool [for the whole supply at 100% load] and due to the reduced casing size the 80mm fan is basically right on the PCB.
 That's a lot of air for a little guy..
 Hardware Secrets tested this one and he had to do it at 39C because he couldn't get enough heat out of it to make the test box heat to 45C.
 It looked like a good unit all the way around.
 Shame on FSP for the crappy caps though.
 .Last edited by PCBONEZ; 02-11-2012, 08:32 AM.Mann-Made Global Warming.
 - Dr Seuss
 Here is whats inside a nice AT Compaq PSU. I saved it from getting "recycled". The cover is all messed up with some brown goo...
 It's a 150W unit; +5V 18A, +12V 4A, -5V .3A -12V .4A. There was almost no dust inside. I couldn't find out anything about the OEM but it sure has quality all over it. It works fine too.Comment
 UL Number?Here is whats inside a nice AT Compaq PSU. I saved it from getting "recycled". The cover is all messed up with some brown goo...
 It's a 150W unit; +5V 18A, +12V 4A, -5V .3A -12V .4A. There was almost no dust inside. I couldn't find out anything about the OEM but it sure has quality all over it. It works fine too.Mann-Made Global Warming.
 - Dr Seuss
 Maybe it's OK with a helicopter grade fan, but my first reaction, just seeing the thumbnails, was, "Where's the beef?!"
 The core of the O/P inductor has me curious. A Micrometals -26 core is painted yellow, with one side painted white. It's a very decent GP core, assuming it's sized right, the switch frequency isn't too high, and cooling is decent. A better choice is the -52 material, which, IIRC, is green body with one side blue - lower loss (less heat!), better for higher switch frequencies. That core looks to be black, with writing on it.PeteS in CA
 ****************************Comment
 Yeah, those coupled inductors - where most or all the O/Ps have windings on the one core - are not as simple as they seem. The number of turns and wire gauge for each winding, and the order in which the windings are wound are optimized so that the inductor helps with the regulation of the O/Ps that are not part of the main regulator loop. Sounds like the core is Micrometals -26 material, which has been standard for use in P/S since before 1980, when I started working with power supplies.PeteS in CA
 Assuming...7 Photos
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
			by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
 I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
 i know that in linear power supply the noise will be very low comparing to SMPS supply....
- Loading...
