K-Mex 450W
  • c_hegge
    • Sep 2009
    • 5219
    K-Mex 450W
    In spite of the no-name sounding brand, this PSU actually looks half decent. The promary caps are 680uF HEC brand. We have a rectifier, not 4 diodes. The transformaers are a decent size, as are the heatsinks. The components are all there (none missing). The secondary caps are all fuhjyyu brand . I'd say this one would be quite a good unit after a re-cap.
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: K-Mex 450W
    From the transformer label I can tell these psus are also found under the name "Maxpower" or "Rexpower".
    Some of their models are very decent after a recap.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      Re: K-Mex 450W
      I'd agree. Everything is well sized in this psu for a good 300-350W output.
      • c_hegge
        • Sep 2009
        • 5219
        Re: K-Mex 450W
        The transformers say Ever-Power on them. I'm guessing that they are the OEM?
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          Re: K-Mex 450W
          Yeap.
          Google search of the OEM's name didn't help much:
          http://www.outletpc.com/c0810.html
          Same OEM psus:
          https://www.badcaps.net/forum/showpo...&postcount=110
          https://www.badcaps.net/forum/showpo...87&postcount=4
          https://www.badcaps.net/forum/showpo...7&postcount=40
          edit:
          key mouse electronic ltd lol
          http://www.kmepc.com/
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Re: K-Mex 450W
            I see a fan controller too. Not bad at all.
            Check the capacitance on the primary HEC caps, though.
            • c_hegge
              • Sep 2009
              • 5219
              Re: K-Mex 450W
              Here's a shot of the label. Maybe Key mouse is the OEM? I've partially re-capped it with Nichicon HE, Panny FM and some Rubycon MBZ which I salvaged off a dead board. The only cap left is a 16v 2200uF. I don't have a replacment for it on hand. I can get FC from RS Components.
              • c_hegge
                • Sep 2009
                • 5219
                Re: K-Mex 450W
                I replaced that last cap, although I ended up going with Nichicon HE, since it was slightly cheaper and the endurance lifetime is higher. As usual, I couldn't find a 10mm replacment, so I had to settle for 12.5mm and mount it off the PCB slightly. The weird thing about this PSU is that, in spite of the fact that it was a few years old, the fuhjyyu caps were showing no signs of failure as the PSU was still working perfectly. This re-cap was entirely pre-emptive. Any ideas as to what might have kept them alive?
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3113
                  Re: K-Mex 450W
                  Fuhkyoo's are extremely inconsistent. I have worked on lots of old antec smart powers and the likes that still have the original fuhkyoo's and work like a charm still. Even one 400W smartpower that had both fans cease up on it and ran like that for about a week straight.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Re: K-Mex 450W
                    I scored myself a couple more of these and it's the same story with the fuhjyyu caps. they are still alive after several years service. All the antecs I've seen with this amount of usage had failed. Maybe the 92mm fan over them?
                    • ChaoZ
                      • Oct 2007
                      • 37
                      Re: K-Mex 450W
                      Your unit is very similiar to the lower end FSP, especially with the 12v sensing fan.
                      I have encountered a good number which simply didnt charge anymore, eg taicons, fuhjyyu etc. And I was reading on the lcd forum and the primary 400v cap is another one. I know it is a pain to desolder+test+re-solder but there is no better way.
                      Lesser known capacitor manufacturers do not follow the protocol, that an expended product needs to POP or VENT. When they failed, they do not display any physical evidence of popped top vent, protruding bottom plugs, rust looking or malformed.
                      And the 'sick' ones usually miss beats every 10 - 15 repetions, irregular charge/discharge or might be leaking badly.
                      I did change the 2 big caps with good results, even though the 2 rubycons still hold charge. The 80mm exhaust fan spools up better with the 2 new caps, perhaps from a cleaner(less noisy) circuit.
                      Just my thoughts, good day!
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Re: K-Mex 450W
                        Usually when the caps fail, even if it is without bloating, the PSU will not work properly. The voltages will be out of spec and fluctuating wildly, or the PSU will refuse to power on. These K-mex PSUs were not displaying any such symptoms and all seemed to be working perfectly. The voltages are all in spec and they do not cause stability problems. I just can't understand what keeps them alive in these units, while they all fail in antecs.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          Re: K-Mex 450W
                          In antecs the get really hot.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Re: K-Mex 450W
                            That's all I can think of. these don't run anywhere near as hot as Antecs, so maybe that's what keeps them alive.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              Re: K-Mex 450W
                              Btw bulging fuhjyyu caps can be found in those psus too:
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Re: K-Mex 450W
                                I finally got around to reading the part numbers on the silicone. The primary switchers are 13009s and the secondary has a 20A diode pack on the 3.3v and 12v rail and two 20A parts on the 5v, so I doubt if it will manage it's lablled specs, although we'll find out for sure when I finish my load tester.
                                • mockingbird
                                  • Dec 2008
                                  • 5486
                                  Re: K-Mex 450W
                                  That is an FSP (Fortran) rebrand. They have good stuff, but lousy caps.
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Re: K-Mex 450W
                                    No, K-Mex/Key Mouse are their own OEM. If it were an FSP, "SPI" would be printed on the transformers, not "Ever power"
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      Re: K-Mex 450W
                                      ~350W max
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3113
                                        Re: K-Mex 450W
                                        Nothing like an FSP design. Key Mouse is mostly a shan zhai factory, they often copy ATNG and (more recently) FSP.
                                        Here's their knock off of a FSP design:
                                        http://www.clubedohardware.com.br/ar...EX-PG-580/2118
                                        Here's their knock off of the old ATNG AP design (see everell's Rosewill RP550 thread and compare the layout)
                                        http://www.clubedohardware.com.br/ar...500T-USPC/1673
                                        As far as I can tell, c_hegge's unit is either a knock off of a Wintech or it's one of their own engineered designs.
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • AdrenalinTL
                                          450W PSU capacitor Identification and where to get another one?
                                          by AdrenalinTL
                                          Howdy peeps.
                                          Can someone tell me where to get another one of these? google doesn't seem to have a 560uF and I am still quite a newbie to the whole world of electronics so trying to learn as I go. The one to the right of this pic is definitely swollen. PSU does random shut downs / no power on etc
                                          Also, can it be replaced with a higher uF cap ? Same voltage?
                                          Thanks...
                                          12-11-2024, 02:20 AM
                                        • aaronkatrini
                                          by aaronkatrini
                                          - Autorange
                                          - DC volts up to 30V
                                          - Accurate Resistance
                                          - Diode test (Beep mode)
                                          - Frequency up to 200MHz
                                          - Capacitanze up to 5000uF
                                          - as cheap as possible
                                          05-06-2024, 09:54 AM
                                        • harp
                                          Learning with ATX CHIEFTEC 450W PSU
                                          by harp
                                          I have a little question regardless a way to repair ATX power supply CHIEFTEC MODEL: GPS-450AA-101 A. It is 450w power for computer.
                                          The psu has initial short on +5VSB (purple), and I found and replace shorted diode SB340. After replace, unpowered measurement of all outputs seems fine. All other big double diode on heatsink are ok in secondary side. I connect psu with 60w bulb in serial, and bulb shortley flash as it would be. There is steady 5.2v on +5VSB and PS-ON, on any other is nothing, like 0.00v. So the primary is ok, right?
                                          But, when I PS-ON (green) connect, bulb...
                                          06-17-2022, 05:04 PM
