	This is a sticky topic.
 You're right - I opened it up again and it has 4 legs.. so it's the rectifier. I initially counted only 3 legs, that's why I assumed it's a transistor.
 Now I'm not so sure about the point of the IN4001 diode on the other side connecting two of the legs of the rectifier...
 Yeah... I don't think the transformer is able to do more than 200-300mA....Comment
 Here it is!Infact, i could go to the surplus store and get a whole bag of phone chargers for a few bucks, would be interesting to dissect them.
 The Best phone charger I have seen was an old nokia charger, it had an Astec power supply, with Lelon and Nichicon caps in it, a nicely sized transistor, a control chip, secondary feedback, and even a mini bridge rectifier on the input!
 -Ben
 Notice that there are no Nichicons here... Only Lelon and Ltec and some are 85C.Comment
 Heh, is it me or are the primary caps slightly bulged?
 -Ben
 Edit: the one I took apart must have been a different version, it has a defferent layout, etc.. may be able to post a pic or two tomorrow!Muh-soggy-kneeComment
 Used to have one just like that.Reminded me of my universal wallwart that i bought when i was 9 or 10 (I'm 24 now).
 Except mine does what the label says and i't considerably more beefy than that black blob of plastic and metal that wants to be a PSU in your pics lol
 AAA battery for size comparison.
 There's a SEC (Samsung) LM317T on that heatsink (capable of 1.5A, so the PSU is underrated by 500mA) Not sure of its current whereabouts tho.
						A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. Not sure of its current whereabouts tho.
						A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
 No, it's due to the macro and the flash
 This is the cheapest nokia charger available. It takes forever to charge big capacity batteries!Comment
 I had a Nokia ACP-12E (E for europe) made by Astec. Had a break in the cable somewhere.
 Caps were Nichicon and Elna.
 5.7V 800mA output
 The Salcomp (Finland) made ACP-8E had Elna everywhere.
 5.3V 500mA output
 Most newer ones use LTec and Lelon exclusively.. bye bye quality.. Comment
 Btw the one in the photo had a break in the cable too and that's the reason I opened it.Comment
 Here is another wall wart. This is the power supply that came with the Harman Kardon HK-206 speakers I recapped. The filter cap is a Fulltec RHA 2200uF 25V (possibly low ESR) and the diodes are RL201s. Note that there is no thermal cutoff on the transformer and the transformer and circuit board just flop around inside the case when the back cover is removed.Comment
 Probably because the bridge rectifier has an open diode (or shorted, but they "fixed" that with a short burst of high currentYou're right - I opened it up again and it has 4 legs.. so it's the rectifier. I initially counted only 3 legs, that's why I assumed it's a transistor.
 Now I'm not so sure about the point of the IN4001 diode on the other side connecting two of the legs of the rectifier... ) so it's cheaper to add another diode around it. ) so it's cheaper to add another diode around it.
 Notice the current through the LED changes with the voltage selector switch position  Comment
 Ok, I also think there was a bit of confusion there, I cant see any extra diode on the circut board, just the bridge rectifier, LED, resistor, and capacitor( & switches).
 -BenMuh-soggy-kneeComment
 Check his 2nd photo where it shows the back side of the board."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
 -David VanHornComment
 Haha, getting myself all confused! Yes, there is a diode there!
 But its in a very strange setup :S
 -Ben
 EDIT:
 HAHA WTF! the circuit b700029 drew is correct too, they added an extra diode for some reason.
 I am surprised that they will do stuff like this to save money! :OLast edited by ben7; 12-05-2011, 06:24 PM.Muh-soggy-kneeComment
 For the quality of the rest of the thing, I'm surprised it's even got a full-wave rectifier!"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
 My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
 Assuming...7 Photos
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
			by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
 I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
 i know that in linear power supply the noise will be very low comparing to SMPS supply....
- Loading...
