This is a sticky topic.
  • Behemot
    • 4845
    • CZ
    #401
    From the lack of transistors and its performance it IS the good ol' transformer I have been talking about! That si also the reason the voltage drops to 0,2 V under load and it heats to 70 °C lol
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      #402
      Nope, that's still a SMPS. Likely a flyback. And it would honor its rating if a proper output diode had been used, i have a similar one and to my surprise it meets spec.
      As for using a regular mains transformer to power a PC, someone i know did this. And it works just fine - it's just a little on the big and heavy side.
      A working TV? How boring!
      • lti
        • May 2011
        • 2550
        That power supply is similar to this, but with a smaller transistor and only one output rectifier diode. This cell phone charger has better build quality. It uses a two-transistor oscillator to drive the transformer, a full bridge rectifier, double the capacitance on the input and output, and 1A rectifier diodes. I could draw at least 500mA from it.
        • japlytic
          • Oct 2005
          • 2086
          Thermaltake Toughpower Qfan 650W
          390uF 400V Hitachi HP3 primary unit.
          2200uF 10V Samxon GF (bulging) before output inductor on +5VSB rail with 1000uF 10V Samxon GF after it.
          2200uF 6.3V Samxon GF before and after +3.3V and +5V inductors.
          2200uF 16V Samxon GF x3 on +12V rail.
          100uF 16V Samxon RL on -12V rail.
          Also has a few small value Jun Fu units.
          GBJ1506 input rectifier.
          SPW60N60C3 x2 PFC stage with CSD06060G rectifier.
          STW50NK50Z x2 output stage.
          FQPF2N50 for +5VSB stage.
          SB1040CT rectifer for +5V rail.
          STPS4045CW x2 rectifier for +12V rail.
          STPS40L45CW rectifiers for +3.3V and +5V rails.
          CM6800 PWM/PFC controller on primary side with P5229 monitor on secondary side.
          • Shocker
            Banned
            • Dec 2011
            • 635
            #405
            Should be "SB1040CT rectifier for +5VSB rail".
            • Behemot
              • 4845
              • CZ
              #406
              Yeah, GF are Samxon's KZG.
              Whos the OEM? Does not look like CWT.
              • c_hegge
                • Sep 2009
                • 5219
                It is a CWT. The heat sink style and the fact that it uses Samxon caps gives it away, even when they don't use green tape.
                • japlytic
                  • Oct 2005
                  • 2086
                  My mistake, it should have been SB1040CT for the +5VSB rail.
                  Time for Part 3 of the power supply build quality pictorial section?
                  • dmill89
                    • Dec 2011
                    • 2534
                    Here's a blast from the past. PC Power & Cooling Turbo Cool 425ATX.
                    Label
                    Overhead
                    Primary
                    Secondary
                    That is about as overbuilt as I have seen an ATX PSU especially a 400 watt. All the capacitors are either Teapo or Hermey although they seem to be doing just fine in this PSU thanks to well designed circuits and exceptional cooling (the fan on this thing moves a ton of air), still I wonder why they used medicore caps in an expensive industrial grade PSU like this one. Since this is a perfectly working PSU currently in a functional server ,removing the case and blowing it out with compressed air was as much disassembly as I did, and given the rather cramped quarters inside I was unable to get any specifics on the components. But figured I'd post the pics.
                    • Shocker
                      Banned
                      • Dec 2011
                      • 635
                      #410
                      You bet!!!
                      Has Astec gone downhill? They used to have good caps in their power supplies...
                      I never thought Astec would go to cheap craps.
                      Originally posted by cheese007
                      That hateful little Fuhjyuu mark of death. Naturally, this POS is full of them, including the primaries. Note the larger cap, which may have been someone's previous attempt at a repair.
                      No big surprise as they used TN series, which is General Purpose.
                      As for the big +12V cap, the brand is "GoldLink", and I've seen them used from the factory in Macron PSUs. I doubt they're any better than Fuhjyyu.
                      • dmill89
                        • Dec 2011
                        • 2534
                        And for a little comparison with the Turbo Cool 425 above. Here is a free with case Gutless Wonder OKIA "420W" PSU.
                        I think they accidently added a 0 to the end of the wattage rating 42W seems more realistic.
                        Overhead Shot. 330uf canicons on the primary. Tiny (all less than 1000uf) micons on the secondary. Undersized heat sinks, under sized transformers, super group regulation, missing components, no input filtering, 4 diodes for the bridge rectifier, etc. OEMed by Yuelin.
                        And a shot of the secondary or lack thereof.
                        As you can see this is the polar opposite of the PCP&C I showed earlier and an excellent example why you should never use or even trust the label on a PSU that came with a cheap case.
                        • japlytic
                          • Oct 2005
                          • 2086
                          PPL-I-150 8-28V input ATX power supply (for automotive PCs or ITX boards)
                          4x 220uF 35V Nichicon HD for boosted input with one 47uF 35V Jackcon unit.
                          2x 330uF 16V Sanyo OS-CON SVP on +12V (6A) output.
                          3x 620uF 6.3V Sanyo OS-CON on +5V (8A) (shared with +5VSB) and +3.3V (8A) outputs.
                          47uF 35V Jackcon on -12V output.
                          AO4468 x2 MOSFETs for synchronous +3.3V and +5V rails.
                          AOD484 x2 MOSFETs for synchronous +12V rail (step-down; also has AO4468 x2 for step-up)
                          AO4468 MOSFET for switched +5V rail (input connected to +5VSB).
                          This supply had the good capacitors (mostly), but there are some of the same model with not-so good capacitors.
                          • Shocker
                            Banned
                            • Dec 2011
                            • 635
                            #413
                            Why OS-CON and Jackcon in the same unit???
                            • ncovert
                              • Feb 2011
                              • 291
                              Bestec PSU's:
                              Pic 1: ATX-300-12Z
                              Connectors: 24 pin main, 4 pin atx12v, 5x molex, 1x floppy, 2x sata
                              Pic 2: ATX-250-12Z
                              Connectors: 20 pin main, 4 pin atx12v, 4x molex, 2x floppy, no sata
                              What do you think?
                              • Behemot
                                • 4845
                                • CZ
                                #415
                                From these pictures don't look so bad. There are even optocouplers instead of transformers.
                                • ncovert
                                  • Feb 2011
                                  • 291
                                  Future Power WIN-400PS (OEM most likely WinTec)
                                  Pic 1: Label.
                                  Pic 2: In the back there is a second fan.
                                  Pic 3: Inside view.
                                  Pic 4: Primaries side, Fuhjyyu caps.
                                  Pic 5: Secondaries side, more Fuhjyyu caps.
                                  When jumpered (green-black), it will turn on and fans run.
                                  However, when in PC, It will not boot, instead gives mobo green light but no power.
                                  Connectors: 20 pin main, 4 pin atx12v, one of those weird flat connectors (think AT power supply), 6x molex, 2x floppy, no sata.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #417
                                    Secondary seems to be quite bad, most likely also the rectifiers would be not something.
                                    • mariushm
                                      • May 2011
                                      • 3799
                                      #418
                                      For people that don't follow this thread, this is sort of in continuation of this post: https://www.badcaps.net/forum/showpo...&postcount=374
                                      I was doing some cleanup and found an AC/DC adapter I have fond memories of. This thing was used by my father around 1992-1994 to power an electronic calculator (the hand held kind) which still had the digits formed by pre-lcd elements, sort of like this one:
                                      I remember my father was always upset after finding it in my hands - I used to "borrow" it to power my tetris game because I didn't have money to buy batteries... later I used to borrow a nintendo gameboy from a richer boy at school and used this to power the game (damn, that nintendo gameboy used to eat 4 batteries in 20-30 minutes)
                                      Like any kid, managed to break the plug and cause some damage to the DC plug so you you can see in the pictures my soldering skills at about 13-14 years old, when I just started to learn about electronics and computers and started to get interested in this.
                                      The thing itself is well built for a 20 year old device... the only issue it has is that 6v and 7.5v selections no longer work... which is because the wires from the transformer are loose, no longer soldered to the PCB.
                                      Yeah, that's regular scotch tape that's insulating the 230v wires from the PCB ... i didn't know shit back then...
                                      While I'm at it, I figured I'd open a charger my brother left here and no longer uses it...
                                      The PCB is just shoved and there's a couple of blades making contact with the pcb, a resistor is used for a fuse... tsc 13002 npn transistor, some surface mounted resistors , samxon and JH caps..
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        wow, heh, I think taking things apart is very addicting actually, cause you never know what you will find.
                                        LOL, a 'Shecon' brand cap.
                                        My soldering was bad like that too, but I practiced on old junk circuitboards, and I got very good at it
                                        -Ben
                                        Muh-soggy-knee
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          #420
                                          Is that really a Nokia OEM charger? If so, shame on them.
                                          This single-transistor self oscillating design is crap. It should not be used in any electronic device, except for perhaps a classroom experiment.
