This is a Just Wireless Blackberry/Treo charger that was purchased a few years ago. It produces 5VDC with an unknown maximum current (they put the wrong label on it
There is no fuse. The bridge rectifier diodes are 1N4007s. The primary filter cap (C1) is a 4.7uF 400V Fullcon (the logo reminds me of Fujicon), and the small cap next to it (C4) is a Jakec 33uF 50V. The output filter cap is a CA 470uF 16V and is probably not low ESR. The largest cap is 8mm in diameter. It has a very small transformer.
There is also a current sensing circuit on the output. It is a voltage divider in parallel with a diode. The voltage divider is connected to the base of an S9015 transistor that switches on a yellow LED if the current draw reaches a certain level. The LED is a bicolor yellow/red part, and the red section is powered constantly.
I tested this charger by connecting it to my cheap computer speakers. The amplifier produced a buzzing noise that sounded like a nest of angry bees. I turned the volume up and turned the charging indicator into a level meter
. The charger didn't like that, judging by the smell it produced
Is this charger dangerous? Is there anything that needs to be improved? I am not currently using it, but I am keeping it as a spare.
).There is no fuse. The bridge rectifier diodes are 1N4007s. The primary filter cap (C1) is a 4.7uF 400V Fullcon (the logo reminds me of Fujicon), and the small cap next to it (C4) is a Jakec 33uF 50V. The output filter cap is a CA 470uF 16V and is probably not low ESR. The largest cap is 8mm in diameter. It has a very small transformer.
.Is this charger dangerous? Is there anything that needs to be improved? I am not currently using it, but I am keeping it as a spare.
I never said that the diodes were too small. The DVD recorder I tried to repair used the same diodes in its bridge rectifier. I know that phones have regulators and a charging circuit inside them. As I said in my previous post, the amp simply provided a load that would allow me to measure the output voltage. I don't rememmber saying that I planned on using it for anything other than charging phones.
