"easy" PSU repair
Re: "easy" PSU repair
can be that TOP ic measure outside of board?
all traces looks ok
with - lead on - of rectifier o dont have any voltage on TL431Comment
Please check the voltages with meter ground on Bridge [-]:
1
2
3
4
5Last edited by R_J; 01-27-2019, 10:15 AM.Comment
Having 0 volts on test point #1 tells me there is no voltage being generated by the feedback winding. Check that that winding is not open and check that the diode between the winding and the opto is good. Also the smd caps could be shorted, the one across the winding would need to be remove to be tested.
The 5.3 volts on Test point #3 is coming FROM the control pin of the ic (internaly generated). 5.2v on test point 2 tells me the trace between the control pin and the opto is good.
If the main output (12 volts) is about half (~5v), that tells me the feedback voltage should be at least a 2-3 volts,
when the power supply is working normal I would expect the feed back voltage to be about 10 voltsLast edited by R_J; 01-27-2019, 01:52 PM.Comment
does anybody know from pictures what leads is for aux and what for primary winding?Last edited by ktmmotocross; 01-28-2019, 02:06 PM.Comment
True.
But that doesn't mean the O/P can't try to open the transformer and fix the burned out aux winding.A lot of work for a small adapter? -Yes. Then again, this adapter is being fixed for learning purposes, is it not?
BTW, a suggestion to ktmmotocross:
If you're going to bridge the fuse in the future, then at least use a the series incandescent bulb trick to limit current in case something goes wrong. Details here:
https://www.badcaps.net/forum/showpo...4&postcount=70
Otherwise, you could end up with lots of smoke and a bunch of melted wires on the floor - which is both a fire hazard and an electrical hazard for you.
It's fun to fix power supplies, but make sure you're safe too.On that note, I also encourage people to wear safety glasses when testing things. High-power diodes and transistors tend to go out with a big bang and could send flying shrapnel parts right in your eyes. Venting electrolytic caps can also be dangerous.
True.
True.
I know that but as i wrote i dont mind if it blow as i dont want to use it even if it was reapired. i just wanna learn from itComment
If you are going to jump a fuse like that for testing only, just use one thin strand of wire. somthing like #30 gauge. If the power supply was repaired, then you should replace the fuse with the correct type.
There might be a different number stamped on the transformer side or maybe under that label? if you did want to try to find one.Last edited by R_J; 02-01-2019, 10:35 AM.Comment
(most likely will have to take a hacksaw / dremel to the outer plastics.)
A thin wire should at least partially limit the current.
It's OK to want to learn from something and try not to waste too much time or resources/parts on it. But bridging fuses with thick wire and plugging the DUT in the wall can be DANGEROUS. What if some component blew and shrapnel from it got into your eye? What will you learn then and would it be worth getting injured for that?!
In your case, you mentioned you were measuring current with your multimeter and the PSU was barely drawing anything. Well, what if it didn't and something went wrong while measuring with your multimeter? Now your multimeter would get damaged too.
It's like trying to learn how to ride a motorcycle when you don't even know where the throttle, breaks, and gears/clutch are. Surely before you jump on it, you will want to know where these things are and how they work. Otherwise, you'll just be another video submission for one of those Fail channels (Fail Army, Fail Blog, etc.)... and that's if you don't end up breaking something.
If you want to learn in a more proper way, you should take all of the suggestions mentioned in this thread and learn from those.Last edited by momaka; 02-01-2019, 07:06 PM.Comment
Surprised it was the aux wiring, so I kind of doubt that it was the story ender. I'd more think of the aux winding opening up due to manufacturing defect and causing the PSU to go open loop and burn the fuse with high V*I draw.
Sometimes the broken spot is just where the winding is attached to the pin and may get lucky repairing it there, but even this I don't have much faith in repairing transformers...Last edited by eccerr0r; 02-01-2019, 08:35 PM.Comment
When turning on the internal led of the octocoupler, the led should light on the other side.
To test U3, google search, there are hundreds of circuits to connect it in a breadboard and get a voltage of 2.5vdc as a reference. If you get it then it's fine.
Greetings.Last edited by SoporteHR; 02-07-2019, 01:45 PM.Comment
by user392097Hello. Just want to share my experience of easy DMI Data transfer on HP Laptop with corrupted BIOS.
Open the backup image with UEFIToolWithReplace, go to Intel image / BIOS Region, extract first Padding area, replace it in a new clean factory BIOS using the same UEFIToolWithReplace. That's all...
Channel: BIOS Requests ONLY!
10-31-2023, 04:19 AM -
by JaneI can already make cell phone repairs on chip level. Now I would like to learn
laptop repairing ,also on chip level.
Can you please recommend a good source( web, books or similar)?
Thank you -
by ktmmotocrossi have this HP Elitebook 8460p that have that stupid wifi whitelist.
how to remowe wifi whitelist the easy way, as im a bit lazy to disassembly it.03-07-2022, 09:26 AM -
by ZentechI am fairly comfortable fixing laptop's motherboards and other electronics. But never venture into phone/tablet repair. So what is the best way to learn to fix phone and tablets? of course, besides the obvious, get a board and fix it!!!.. I know. I'm looking for method of learning, and resources like: phone diagrams explaining the main components. How different are phones from tablets and laptops. For example, a laptop has the charging circuit, power supply circuit providing 3,5V etc.. the EC chip which starts the motherboard. How different is to troubleshoot a phone compare to a laptop? Finally,...
by StiffmesiterHello,
I have a A2159 stuck at 5.16 V and 0.01 A on the amp meter. I should note that this will be my first 'real' fix, and have really caught the learning bug for logic board repair. I am really excited to hear what this forum has to say and help round out my understanding. With that being said, I have slowly been working on it over the holidays and acquiring the tools to fix it, but have not done anything substantial yet besides ultrasonic cleaning the board.
Here is the pre-req information:
History, symptoms, and state-of-the-machine...
... - Loading...
