Easy dmi transfer on hp bios
  • user392097
    • Jun 2023
    • 11
    • Georgia
    Hello. Just want to share my experience of easy DMI Data transfer on HP Laptop with corrupted BIOS.
    Open the backup image with UEFIToolWithReplace, go to Intel image / BIOS Region, extract first Padding area, replace it in a new clean factory BIOS using the same UEFIToolWithReplace. That's all
  • Focus2005
    HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
    by Focus2005
    Hello everyone.
    I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
    05-01-2025, 05:41 AM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
    by Vesko356
    08-11-2023, 03:27 AM
  • grimacelord
    Latitude E6530 - Trouble Extracting BIOS Image From EXE
    by grimacelord
    Hi folks,
    I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
    Service tag number for this model is: "JYDWYW1".
    Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
    I have tried:
    • Simply extracting with 7zip
    • PFSExtractor
    • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
    • Check Temp folder
    10-26-2023, 08:15 AM
  • someonenotyou
    How to transfer information from one BIOS to another?
    by someonenotyou
    Hi.
    I am starting to learn about UEFI BIOS.
    At the moment I have Lenovo laptop with bad BIOS.
    I tried to clean ME region and transfer EC region from a known working BIOS, but the laptop does not POST (just fan spin).
    So there is something else bad.
    If I flash a know working BIOS, the laptop POSTs and boots into Windows.
    But the problem is, that the serial numbers, Windows key, and every thing else is from another laptop.
    Where do I start to transfer the S/N, Windows key and other information from one BIOS to another?
    Thank y...
    03-04-2025, 03:41 AM
