"easy" PSU repair
  • petehall347
    • Jan 2015
    • 4435
    • United Kingdom
    #41
    Re: "easy" PSU repair
    Originally posted by budm
    I would expect the MOSFET inside the SMPS to be damaged since the snubber diodes shorted out and also blew the fuse. The strange part is that OP is indicating output Voltage on the cold side so something is switching in the HOT side, at this point I would suggest to replace the IC and the OPTO. It is also strange to have BOTH snubber diodes shorted out.
    depends if measured in circuit or not i would think .
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3616
      • slovakia
      #42
      can be that TOP ic measure outside of board?
      all traces looks ok
      with - lead on - of rectifier o dont have any voltage on TL431
      • R_J
        • 9583
        all traces looks ok
        And you won't measure any voltages that way. but that is NOT what I asked you to check.
        Please check the voltages with meter ground on Bridge [-]:
        1
        2
        3
        4
        5
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3616
          • slovakia
          #44
          sry. my fault
          1 - 0.3V
          2 - 5.3V
          3 - 5.2V
          4 - 0.0V
          5 - 315V
          • R_J
            • 9583
            Having 0 volts on test point #1 tells me there is no voltage being generated by the feedback winding. Check that that winding is not open and check that the diode between the winding and the opto is good. Also the smd caps could be shorted, the one across the winding would need to be remove to be tested.
            The 5.3 volts on Test point #3 is coming FROM the control pin of the ic (internaly generated). 5.2v on test point 2 tells me the trace between the control pin and the opto is good.
            If the main output (12 volts) is about half (~5v), that tells me the feedback voltage should be at least a 2-3 volts,
            when the power supply is working normal I would expect the feed back voltage to be about 10 volts
            • R_J
              • 9583
              Did you find anything with this power supply?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3616
                • slovakia
                #47
                does anybody know from pictures what leads is for aux and what for primary winding?
                • R_J
                  • 9583
                  Easy, here you go
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3616
                    • slovakia
                    #49
                    so we have our winner
                    the aux winding is open
                    thanx for help guys
                    • R_J
                      • 9583
                      Oh well, about the only part you can't get.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #51
                        True.
                        But that doesn't mean the O/P can't try to open the transformer and fix the burned out aux winding. A lot of work for a small adapter? -Yes. Then again, this adapter is being fixed for learning purposes, is it not?
                        BTW, a suggestion to ktmmotocross:
                        If you're going to bridge the fuse in the future, then at least use a the series incandescent bulb trick to limit current in case something goes wrong. Details here:
                        https://www.badcaps.net/forum/showpo...4&postcount=70
                        Otherwise, you could end up with lots of smoke and a bunch of melted wires on the floor - which is both a fire hazard and an electrical hazard for you.
                        It's fun to fix power supplies, but make sure you're safe too. On that note, I also encourage people to wear safety glasses when testing things. High-power diodes and transistors tend to go out with a big bang and could send flying shrapnel parts right in your eyes. Venting electrolytic caps can also be dangerous.
                        • R_J
                          • 9583
                          Originally posted by momaka
                          True.
                          I can see you did'nt look at the picture of the board... encapsulated transformer good luck opening one of these
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3616
                            • slovakia
                            #53
                            True.
                            I know that but as i wrote i dont mind if it blow as i dont want to use it even if it was reapired. i just wanna learn from it
                            • R_J
                              • 9583
                              If you are going to jump a fuse like that for testing only, just use one thin strand of wire. somthing like #30 gauge. If the power supply was repaired, then you should replace the fuse with the correct type.
                              There might be a different number stamped on the transformer side or maybe under that label? if you did want to try to find one.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                #55
                                As long as it's not epoxy-impregnated (like TV flyback traffos), it *can* be opened. I'm not saying it will be easy or look pretty afterwards (most likely will have to take a hacksaw / dremel to the outer plastics.)
                                +1
                                A thin wire should at least partially limit the current.
                                You're missing the point.
                                It's OK to want to learn from something and try not to waste too much time or resources/parts on it. But bridging fuses with thick wire and plugging the DUT in the wall can be DANGEROUS. What if some component blew and shrapnel from it got into your eye? What will you learn then and would it be worth getting injured for that?!
                                In your case, you mentioned you were measuring current with your multimeter and the PSU was barely drawing anything. Well, what if it didn't and something went wrong while measuring with your multimeter? Now your multimeter would get damaged too.
                                It's like trying to learn how to ride a motorcycle when you don't even know where the throttle, breaks, and gears/clutch are. Surely before you jump on it, you will want to know where these things are and how they work. Otherwise, you'll just be another video submission for one of those Fail channels (Fail Army, Fail Blog, etc.)... and that's if you don't end up breaking something.
                                If you want to learn in a more proper way, you should take all of the suggestions mentioned in this thread and learn from those.
                                • petehall347
                                  • Jan 2015
                                  • 4435
                                  • United Kingdom
                                  #56
                                  wondering if the transformer became a fuse and ended this story ?
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Surprised it was the aux wiring, so I kind of doubt that it was the story ender. I'd more think of the aux winding opening up due to manufacturing defect and causing the PSU to go open loop and burn the fuse with high V*I draw.
                                    Sometimes the broken spot is just where the winding is attached to the pin and may get lucky repairing it there, but even this I don't have much faith in repairing transformers...
                                    • SoporteHR
                                      • Sep 2018
                                      • 80
                                      • Venezuela
                                      #58
                                      i checked almost every component on it except optocoupler, U3 and smd capacitors
                                      dont know how to check that U3 and optocoupler
                                      Hello, to test the Octo-couplers, what I do is dismantle it from the PCB, I connect it to a protoboard with the next circuit and I connect a duly polarized LED to the side of the transistor.
                                      When turning on the internal led of the octocoupler, the led should light on the other side.
                                      To test U3, google search, there are hundreds of circuits to connect it in a breadboard and get a voltage of 2.5vdc as a reference. If you get it then it's fine.
                                      Greetings.
                                      • eliasseverholt
                                        Looking to learn about troubleshooting my Lenovo L14 Gen 1
                                        by eliasseverholt
                                        Hello!
                                        Unfortunately my Lenovo L14 Gen 1 (motherboard NM-C741) was involved in a terrible mishap. At first, one of my friends accidentally spilled coffee on it which made some of the ports stop working but the computer worked fine otherwise. After that I stupidly opended it and forgot to disconnect the battery... One thing leads to another and I accidentally short it between two components (unfortunately I do not remember which components). After that I get nothing, no charging indication, no boot indication, no fan spin, nothing.
                                        So I'd love to learn my mistakes and...
                                        12-19-2023, 06:13 PM
                                        Packard Bell Easy Note EN TE11BZ Q5WT6 Laptop Schematic
                                        LA-8531P Rev 0.3...
                                        11-06-2024, 06:29 AM
                                      • SarcasticOP
                                        Seeking Guidance on Motherboard Diagnostics
                                        by SarcasticOP
                                        Hello everyone!
                                        I hope this is the correct place to post this, if not please let me know and I will post in the appropriate location.
                                        I'm venturing into the intricate world of board repair within electronics, and I'm reaching out to this community for some guidance and shared wisdom. I have tried to do some research myself and find this information on my own, but I don't know what I don't know, and that is really starting to become an insurmountable issue that I cannot overcome. The only person I had nearby that I could turn to passed away recently so I do not have anyone...
                                        01-10-2024, 03:35 PM
                                      • user392097
                                        Easy dmi transfer on hp bios
                                        by user392097
                                        Hello. Just want to share my experience of easy DMI Data transfer on HP Laptop with corrupted BIOS.
                                        Open the backup image with UEFIToolWithReplace, go to Intel image / BIOS Region, extract first Padding area, replace it in a new clean factory BIOS using the same UEFIToolWithReplace. That's all ...
                                        10-31-2023, 04:19 AM
                                        Samsung N145 Plus Netbook Specification for Upgrade or Repair
                                        This specification for the Samsung N145 Plus Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the N145 Plus boardview and N145 Plus schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung N145...
                                        09-06-2024, 05:27 AM
