"easy" PSU repair
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3599
    • slovakia
    "easy" PSU repair
    Hello.
    I try to learn repairing PSU. I watch many repair and instructional video, so i know how it works.
    But i cant figure aut what is whag with this easy PSU
    The output voltage must be 12V, but its about 5V and is oscilating from 3V-6V
    Can somebody lead me to bad component and little teach how to find it?
    That diode must be on the other side but have broken leads so i solder it to other side
    • 31048
    Re: "easy" PSU repair
    that bullshit with the fuse is unwise - you have no idea how much current it's drawing.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3599
      • slovakia
      forget about that fuse. if it blow i throw it to bin.
      i just need to learn how to repair it, and how trouble looks like
      i think that is problem with regulation but how to check optocoupler, how to check that U3 - TL431 and other components
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3599
        • slovakia
        actually i see from top224 datasheet sample diagram that are two diodes on primary, but one of them is i see a zener diode
        when i measure components on this PSU i see that this two diode was shorted, so i replace it with two normal diodes.
        how can i know the value of that zener diode when i dont have original diode
          Check the small lytics cap on the primary side, that is the startup/running cap.
          You cannot test that snubber diode with your meter, that Zener is about 200V typical and it is made that way with back to back condition, put the original one back in place. Do not just put in regular diodes in place!
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3599
            • slovakia
            from top datasheet i check that i it mostly 200V zener som i put another as the way datasheet shows, but still have oscilation around 5V
            i removed that cap from board and test it
            it is 100uf/25V and testing shows 98uF ESR-0.88ohm Vloss- 1.7%
              OK, I see the two diodes in your pictures now, they are individual diodes not all in one body type.
              So if both of those two snubber diodes shorted out, if they were then I would expect the IC to be damaged and I will expect it to have any output in the cold side..
              The TO-220 diode in the cold side is mounted like that on the bottom side of the board? and that Diode is OK, correct?
              If you measure the DC V between the two legs of that small startup/running cap, it is going up and down too, correct?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3599
                • slovakia
                The output diode is mounted correctly and is ok. DC voltage on small startup capacitor moves between 5,15V and 5,35V
                • R_J
                  • 9550
                  What do you have jumpered here (yellow box) Is there a resistor on the other side?
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3599
                    • slovakia
                    no thats just a fuse that was blown, so i jumped it. i dont want to use this psu anymore, just repair it to learn something
                    and its white box fuse, just lighted by bulb
                    • R_J
                      • 9550
                      Look at the picture. I am looking at the wire on the ic
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3599
                        • slovakia
                        sorry i was not see that u moded the picture. it was just trace ripped off so i replace it with wire. on the other side is trace connected to starting capacitor so i make wire trace to it
                        i know it is a mess, but i just want to repair it, learn from it and than i just take components from it
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3599
                          • slovakia
                          i checked almost every component on it except optocoupler, U3 and smd capacitors
                          dont know how to check that U3 and optocoupler
                          • R_J
                            • 9550
                            Check the voltage on TL431, then check the voltage on the 2 pins of the optocoupler cold (secondary) side
                            Then check the voltage on the 2 pins of the optocoupler on the hot (primary) side with meter ground on bridge rectifier (-)
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3599
                              • slovakia
                              here are the measurements
                                • Jul 2011
                                • 6040
                                When you are doing these voltage measurements where are your meter lead at
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3599
                                  • slovakia
                                  just as u wrote. on hot side i put - lead to - on rectifier
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3599
                                    • slovakia
                                    can be optocoupler tested with two multimeter in diode mode like mosfet?
                                    in diode mode i dont have any readings on transistor side. on diode side i have in one direction reading around 1000 and nothing on other polarity
                                    when i using two multimeters in diode mode, nothing happend when i try to activate the optocoupler
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3599
                                      • slovakia
                                      i made a test circuit with 6.5V PSU and multimeter in diode mode and optocoupler was working.
                                      • R_J
                                        • 9550
                                        It looks like you have 0 volts on the opto, so the internal led is not lit, I believe you should have at least 1 - 1.5 volts
                                        I can't see how the traces are run so its hard to diagnose. The diode in the picture covers the traces.
                                        Is the circuit close to the diagram I posted ? does one of the pins of the opto connect to the 12 volt output?
                                        What is the number on the optocoupler?
                                        • eliasseverholt
                                          Looking to learn about troubleshooting my Lenovo L14 Gen 1
                                          by eliasseverholt
                                          Hello!
                                          Unfortunately my Lenovo L14 Gen 1 (motherboard NM-C741) was involved in a terrible mishap. At first, one of my friends accidentally spilled coffee on it which made some of the ports stop working but the computer worked fine otherwise. After that I stupidly opended it and forgot to disconnect the battery... One thing leads to another and I accidentally short it between two components (unfortunately I do not remember which components). After that I get nothing, no charging indication, no boot indication, no fan spin, nothing.
                                          So I'd love to learn my mistakes and...
                                          12-19-2023, 06:13 PM
                                          Packard Bell Easy Note EN TE11BZ Q5WT6 Laptop Schematic
                                          LA-8531P Rev 0.3...
                                          11-06-2024, 06:29 AM
                                        • SarcasticOP
                                          Seeking Guidance on Motherboard Diagnostics
                                          by SarcasticOP
                                          Hello everyone!
                                          I hope this is the correct place to post this, if not please let me know and I will post in the appropriate location.
                                          I'm venturing into the intricate world of board repair within electronics, and I'm reaching out to this community for some guidance and shared wisdom. I have tried to do some research myself and find this information on my own, but I don't know what I don't know, and that is really starting to become an insurmountable issue that I cannot overcome. The only person I had nearby that I could turn to passed away recently so I do not have anyone...
                                          01-10-2024, 03:35 PM
                                        • user392097
                                          Easy dmi transfer on hp bios
                                          by user392097
                                          Hello. Just want to share my experience of easy DMI Data transfer on HP Laptop with corrupted BIOS.
                                          Open the backup image with UEFIToolWithReplace, go to Intel image / BIOS Region, extract first Padding area, replace it in a new clean factory BIOS using the same UEFIToolWithReplace. That's all ...
                                          10-31-2023, 04:19 AM
                                          Samsung N145 Plus Netbook Specification for Upgrade or Repair
                                          This specification for the Samsung N145 Plus Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the N145 Plus boardview and N145 Plus schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung N145...
                                          09-06-2024, 05:27 AM
