I have a PC smps FSP300-60ATV (PF) from Aopen with problem to start up.Only after several attempts it starts .
I found several elco's to be bad :
1) (c33?) 4700uF/10v FUHJYYU TMR (M) P10 CE 105°C VENT ø10mm L31mm
located at ?
2) (c32?) 4700uF/10v FUHJYYU TMR (M) P10 CE 105°C VENT ø10mm L31mm
located at the end of 3,3v ( to ground)
3) (c26?) 1000uF/10v FUHJYYU TNR (M) P10 CE 105°C VENT ø10mm L18mm
located at the end of 5v ( to ground)
4) (c23?) 1000uF/10v FUHJYYU TNR (M) P10 CE 105°C VENT ø10mm L18mm
located at ?
5) (c25?) 2200uF/16v FUHJYYU TMR (M) P10 CE 105°C VENT ø10mm L31mm
located at the end of 12v ( to ground)
6) (c28?) 3300uF/10v TEAPO A3 11/02 SEK 105°C ø10mm L26mm
7) (c29?) 3300uF/10v JAMICON 245C1 TK 105°C ø10mm L30mm
located at ?
I have made the choice to take RS to order new caps and to take panasonic as brand.
I chose to replace them with :
1) PANASONIC EEUFM1A472L : 4700uF/10v ø12,5mm L35mm
2) PANASONIC EEUFM1A472L : 4700uF/10v ø12,5mm L35mm
3) PANASONIC ECA1CHG102 : 1000uF/16v ø10,0mm L16mm
4) PANASONIC ECA1CHG102 : 1000uF/16v ø10,0mm L16mm
5) PANASONIC EEUFM1C222 : 2200uF/16v ø12,5mm L25mm
6) PANASONIC ECA1AHG332 : 3300uF/10v ø12,5mm L20mm
7) PANASONIC ECA1AHG332 : 3300uF/10v ø12,5mm L20mm
CAN ANYBODY GIVE ME ADVICE if I made THE good choice ?
located at ?
located at ?
located at ?
