Ham/CB/other transmitter radios... linear vs switching PSU?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    Now I don't own any HF gear other than CB, but there still seems to be some arguments against switching PSUs.
    Do people still have a good reason to use a linear PSU?
    Or is it fully possible to clean up a switching PSU so that it won't interfere a radio?
    Now that it seems Yaesu even doles out switching PSUs, is this a sign to start getting rid of linear PSUs?
    • 31304
    Re: Ham/CB/other transmitter radios... linear vs switching PSU?
    switchers must be well filtered - cheap ones arent.
    and they need LOTS of output capacitance to keep them stable between RX that is probably only a couple of watts and TX which sure as hell isnt.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      cheap smps always litter the hf spectrum with their wandering birdies.
      a surprise is that an xbox 360 supply does well for running 100w hf rigs.
      they dont like cap charging inrush so connect then power on.
      i have one at the shop running a kenwood ts50 over 3 years.
      even with their weight and poor efficiency i prefer an old linear astron.
      but if you need something to get on the air with an xbox 360 brick can be free from a dead game.
      the older ones are rated for up to 18a.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        I was more wondering about people deathly afraid of using SMPS with HF - heard someone mentioned it recently. Yes it's worth experimenting/testing but definitely don't preclude it.
        Then there's also the VHF/UHF radios, which seem to be more tolerant of SMPS?
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          ^ I run my rigs on a pair of Dell Poweredge 2500 PSUs. Works well.
          Follow the white rabbit.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            Currently I only have 70cm LMRS radios tuned to ham bands, and using SMPS just fine. Almost seems just getting enough watts is sufficient, I'm using a random 12V 40W SMPS PSU that I adjusted to 13.8V on one of my radios - can't seem to hear PSU noise.
            That PSU is being shared with the ancient 2m radio... which isn't being used, yet...
            My 35W LMRS radio makes the 40W SMPS die on transmit. Well, that figures, so much for radio efficiency
              • 31304
              well most ps run at 30-80KHz so they are going to be more of a problem for people running in the sw area.
              • redwire
                • Dec 2010
                • 3912
                A linear PSU is the quietest, great for DX and 6-8 digit multimeters.
                But your noise floor is always limited by other interference, usually the neighbor's cheap computer gear.
                Any SMPS that passed EMC regulatory like FCC part 15 or EN550xx will have decent filtering and low emissions, i.e. Meanwell 50W PSU.
                SMPS wall adapters are ungrounded and less room for filtering components, so not good for radios, I find.
                The cheap Ali or eBay PSU's that have never been tested or certified for EMC- they are a crap shoot.
                Some have the filter components just jumpered out. You can add a line filter and CM choke on the output though.
                The really cheap chinese PSU's I find unstable and make tons more EMC.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8716
                  Here we go... I got an 175W Xbox PSU, time to up it to ~13.8V and use it to charge the backup battery and power the shack. Then I can stop using the little 40W switcher...
                  I wonder if I'll need to add any noise elimination hacks to it... hopefully not.
                    • 31304
                    keep it clean,
                    they contain a fan and pull air from one end to the other across a huge heatsink.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8716
                      oh weird, I thought it was passively cooled, strange... did not see any fanlike vents. Grr. Oh well.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8716
                        Oh this sucks. I have to trick the supervisor circuit too? This thing has OVP/UVP with an internal reference! Grr!!! I guess no battery charging with this...
                        • llonen
                          • Sep 2014
                          • 495
                          • hampshire
                          I have used switching PSU's on 100 watt radios in the past, and I have tried the Xbox 360 gig. I don't know while they do seem to work I just don't feel comfortable unless I am using a heavy linear supply of which I have no shortages of. Also I have float charged a bank of lead acid batteries in the past to power my radio equipment, I suppose if I had a real need to use smps then I might get around to feeling differently and I do have a couple of surplus corsair 1200 watt supplies.
                          That said I know several local radio amateurs who use 50 volt smps supplies for their high power solid state amplifier's either 400 watt or 1 kw amps and they seem to get away with it.
                          • japlytic
                            • Oct 2005
                            • 2086
                            It may be hard to find in specifications, but frequency jittering (helps reduce EMI) is a good feature to look for in a switching power supply for this application.
                              • 31304
                              that's called "spread spectrum", pc motherboards usually use it too.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8716
                                Problem with a 12.0V power supply is that the voltage isn't high enough to charge...
                                I also have a half-made homemade linear using the parts I had on hand. I had it working well with one series pass transistor, alas I wanted to parallel two so it can safely pass 10A+ total. Just don't have enough of the right parts to implement foldback for two transistors.
                                Yes it was kind of scary shorting the output to test foldback, but it worked when it was just one pass transistor!
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8716
                                  AHA! I think I found the parts that I need to change to adjust the voltage on the xbox PSU... though the %#&*!@$ stupid @*()$#@(% chip manufacturer of the #($(#@%*#^ supervisory chip did not *(#%$@% clearly specify the %*(%# specifications of the OVP input...GRRR... However it minimally won't cut out under 13.4V so I probably can get it to 13V without modifying the OVP, above that might get into the risky zone depending on how lucky I got with the chip.
                                  The other possibility is to remove the chip, but OCP is also handled by this circuit.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8716
                                    SUCCESS! With some risk of the OVP failing... at least it worked for me luckily!
                                    I have: Microsoft XBox PSU Model HP-AW175EF3 (HiPro made in China)
                                    Noting that the resistors on the board are all glued and soldered, I figured the best way is to parallel a resistor.
                                    I paralleled a 36K resistor (it's what I had in my junk box...) to the existing R318 on the board. I got a resultant voltage of ...
                                    13.73 volts (unloaded)!
                                    Close enough! This should be excellent for a car battery eliminator. Now I need to have a connector on the output that's actually usable...
                                    I need to work on my SMT rework skills... or actually have some good flux or something.
                                    BTW: Yes, my noise floor in my house for 2m/70cm is pretty awful... all my computer gear it appears *sigh* In fact it seems when I have BCN loaded one of my monitors, it causes tremendous noise picked up on 70cm. It's kind of hilarious, I can hear it when I move a window off one display to the other...
                                    Tradeoffs...
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8716
                                      XBox HP-AW175EF3
                                      Output: 13.73V DC
                                      Test device: car headlamp
                                      Amperes: 4.27A
                                      Watts: 58.63W
                                      Measured wattage at wall: 75W
                                      Efficiency: 78%
                                      PF: 0.69
                                      Standby power: below resolution of measurement
                                      Power on, no load: 6.5W
                                        • Jul 2011
                                        • 6070
                                        Originally posted by eccerr0r
                                        XBox HP-AW175EF3
                                        Output: 13.73V DC
                                        Amperes: 4.27A
                                        Watts: 58.63W
                                        Efficiency: 78%
                                        PF: 0.69
                                        Could you please post exactly what you changed to make work
                                        Reference number that are on the board
