Rewinding burnt choke coil
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    #41
    Re: Rewinding burnt choke coil
    I believe we are discussing an output inductor, which would have a powdered iron core, not a ferrite core. That powdered iron cores can lose their magnetic properties over time by being run too hot is not news. Here's Micrometals' webpage on the topic.
    Hmmm. Good point!
    Thanks for posting that link - I learned a lot of new things from it today.
    So according to that article, increasing the number of turns decreases the core loss?... at least in the last example they showed with the APFC coil.
    - Very interesting!
    I'll probably read it a few more times just to make sure I didn't miss something. We did some simple boost and buck regulator calculations back in one of our classes in university, but I've forgotten a large part of that. I don't think we got anywhere near as deep as core material or anything like that. Mostly it was just calculating the inductance for the coil needed based on current and voltage requirements and whatnot.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      #42
      Originally posted by momaka
      Hmmm. Good point!
      - Very interesting!
      That article's been on Micrometals' website for as long as I can remember. No author is given, but I suspect the/an author may have been Dale Nichol, an applications engineer there for many years. Before Micrometals Dale was the magnetics designer-guru at Boschert back in the late 70s and early 80s.
      PeteS in CA
      • FZG
        Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
        by FZG
        Hello there, helpful forum people!
        I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
        On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
        The original part...
        05-10-2023, 11:54 AM
      • electomech-fixer
        First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
        by electomech-fixer
        I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
        I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
        09-15-2025, 01:42 AM
      • bauto601
        KDM 480W PSU upgrade succes! (opinions?)
        by bauto601
        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
        A "nice" YoungYear unit? - Badcaps
        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
        12-26-2023, 03:05 PM
      • chth96
        How can I test coil whether it is really broken or not?
        by chth96
        I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
        I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
        I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
        I want to replace this round black fuse and unidentified coil if it got broken.
        02-20-2024, 01:07 AM
      • waterchill
        What part is this coil from a MacBook A2681 ?
        by waterchill
        Hi everyone
        I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
        So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
        IAny ideas? It is from a MacBook A2681
        Thank you...
        08-08-2024, 01:46 AM
