Fixing a Battery Maintainer
  • evilkitty
    • Nov 2017
    • 299
    My dad has a few of there not working and nags me to fix them now and then
    I have this 1.5A battery maintainer
    it says it is fully automatic with float mode monitoring
    It looks like it uses the transformer to drop the AC voltage down
    how should i begin testing this thing?
    the big cap is a 330 uf 25v
    the medium cap is a 16v 1000uf
    the 2 small ones are 10uf 50v
    Caps are G-luxon
  • evilkitty
    • Nov 2017
    • 299
    Re: Fixing a Battery Maintainer
    Ok so i decided to just start pulling caps out
    both the big and medium caps are shot, both meters are with the margin of error for 0uf
    I found these 2 caps:
    https://www.mouser.com/ProductDetail/EKYA350ELL332MLN3S
    https://www.mouser.com/ProductDetail/EKYB350ELL102MJ30S
    How would i know if i need to find low esr?
    the big cap looks to be there to smooth out the dc output
    the small cap look to smooth the input dc, does this thing not use a bridge rectifier? i only see one diode per low voltage AC am i not seeing something?
    given the caps are in the bad cap brand list, would these be good to replace the 10uf 50v caps:
    https://www.mouser.com/ProductDetail...L1H100KDDANATD (I have these onhand)
    • diif
      • Feb 2014
      • 6978
      • England
      Find the datasheet for the caps you want to replace. They will show the ripple and ESR.
      I use Panasonic FR, FM and FC in that order after recommendations on here a few years ago.
      • evilkitty
        • Nov 2017
        • 299
        I can't find any, but i really suck at finding them
        is this a series number?
        large cap: 808P(M)
        medium cap: 809Q(M)
        small cap: 805X(M)
        • redwire
          • 3900
          It looks like a linear regulator, I don't see a SMPS anywhere.
          Does it have a wall wart or transformer or something.
          One resistor is brown and sorta burned.
          • evilkitty
            • Nov 2017
            • 299
            yes there is a transformer
            you mean the odd looking diode between the 2 1% resistors near the cap in the corner?
            it does not look burned to be, no trace of residue or anything
            I managed to find a few FR caps
            https://www.mouser.com/ProductDetail/EEU-FR1E332
            https://www.mouser.com/ProductDetail/EEU-FR1E102B
            https://www.mouser.com/ProductDetail/EEU-FR1H100B
            is there any way these could be a bad decision as replacements? is low esr ever bad?
            • Longbow
              • Jun 2011
              • 623
              This is just a simple linear supply. They are usually set to deliver about 14v when connected to a battery. Output current automatically decreases as the battery charge gets up to normal. The connections on the wires easily break. Mine had a wall-wort transformer under-rated and it got hot - it might have to be replaced with a larger one. If you found some bad caps, replace them and you are done. Don't worry about low ESR caps - that does not apply to this simple device. This is not the unit you want to bring a battery up from 10v or lower, but they work fine for maintaining a charge while you replace the engine.
              Is it plugged in?
              • evilkitty
                • Nov 2017
                • 299
                Thanks, then i just get what ever quality brand has the longest life span
                edit: about how much ripple current should i look for?
                  • Jul 2011
                  • 6018
                  The more ripple the better as long as you can fit in the space that you have
                  Because the more ripple they can handle the bigger the cap get
                  • redwire
                    • 3900
                    This resistor I think looks burnt, but your pics are kinda fuzzy
                    • evilkitty
                      • Nov 2017
                      • 299
                      Good eye, missed that, i think it was probably overheated by the cap that failed next to it, definitely needs testing
                      • jazzie366
                        • May 2016
                        • 304
                        large cap: 808P(M)
                        medium cap: 809Q(M)
                        small cap: 805X(M)
                        No, those are lot codes. G-Luxon brands their caps by putting a two letter combination before the temperature rating. Take the TW series for example, it will look like "TW 105C". You'll find something along those lines on there.
                        Also, those look to be standard caps, non low ESR, as it's a linear regulator and they can go both ways. Seeing as they are failed without bulging points more towards age killing them, instead of the load/ripple they had to withstand. You can get middle of the road caps (in terms of ESR) that would do the job just fine.
                        IMO if I were you I would use low ESR, but not extremely low ESR such as is used on motherboards.
                        My recommendation:
                        https://www.amazon.com/Illinois-Capa...+25v+capacitor
                        https://www.digikey.com/products/en?...CKE025M&v=1572
                        https://www.amazon.com/ECEA1HKA100-A...words=10uf+50v
                        I'd say use those unless there is high frequency filtering needed, which unless you have a scope we can't figure that out.
                        Popcorn.
                          It is just linear power supply so FM/FR series will work.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            select 105c replacements by endurance.
                            low esr not needed but fine if they have best endurance.
                              I would go with FR which has more choices for life rating.
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                and use the largest can that will fit.
                                i used fr in a product i manufacture.
                                the lifespan being the most needed parameter.
                                the devices power supply is live at all times.
                                • Bowline
                                  by Bowline
                                  06-11-2025, 10:13 AM
                                • techfreak9356
                                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                  by techfreak9356
                                  I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                  09-14-2023, 11:10 PM
                                  NVDC charger configuration...
                                  11-05-2024, 03:28 PM
                                • ferah831208
                                  Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                  by ferah831208
                                  Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                  03-18-2025, 01:18 AM
                                • huzo
                                  HP ELITE X2 1013 G3 weird battery issue
                                  by huzo
                                  Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                  01-31-2025, 12:09 AM
