Could a PSU tester cause a power supply to start smoking?
  • myaccount
    • Sep 2017
    • 7
    I got this PSU tester recently:
    https://www.amazon.com/dp/B005CTCD6S
    I used it to test one of my PSUs and it worked fine.
    But I have another PSU - an old PSU that I got from someone off ebay about 10 years ago, which I ended up never using and it just sat on the shelf since then. I decided to use the tester on it. I plugged the PSU into the tester and turned the PSU on. After a couple seconds, the PSU started making a weird noise, and then smoke started coming out of the PSU. I quickly unplugged it.
    Is there any chance the tester could have caused that PSU to start smoking? Or could the PSU have just died after sitting on the shelf for so long?
    • 31068
    Re: Could a PSU tester cause a power supply to start smoking?
    i have seen in those, they cant damage anything.
    your psu was faulty - just a lucky coincidence you hooked it to the tester instead of a system!
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Nope, the PSU tester shouldn't be able to damage anything.
      That said, those PSU "testers" are pretty much useless. I wouldn't really call them PSU testers. More like a device to see if a PSU turns ON - nothing more and nothing less. That said, just because a PSU turns ON doesn't mean that it's actually working properly. Likewise, just because the tester may say that it is bad doesn't mean that it is. I've seen cheap testers like that fail many high-end PSUs right out of the box, mostly because those high-end PSUs need a bigger load to have voltages properly in spec.
      The best way to check a PSU is to connect it to a load and measure ripple/noise with a scope. But obviously not everyone has the time and equipment to do that. So instead, the best *easiest* way to check a PSU is to open it up and post some pictures here on BCN . Then we can tell you if there are things that you might want to look out for - like a gutless PSU, or perhaps a good PSU but with dodgy output capacitors.
        Capacitors sitting unused for 10+ years should be slowly reformed before applying full Voltage to them.
        Just look up 'reforming electrolytics capacitor'
        http://www.qsl.net/g3oou/reform.html
        • dmill89
          • Dec 2011
          • 2534
          This one can (if the PSU is of very poor quality since it puts it under about 140W load):
          But your "everyday" amazon/eBay/best buy/etc. "PSU tester" that doesn't put any significant load on the PSU won't (but like you mentioned it isn't much of a "test" either with no load).
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Yeah, that kind of tester is just a multiple-input digital voltmeter, along with a little timing circuit to measure the rise time of the "power good" signal. Does not present any significant load.
            A working TV? How boring!
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              https://www.badcaps.net/forum/attach...1&d=1504916496
              Nice!!!
              Where did you get that one?
              I still haven't built a proper load tester. That said, I have a NiCr 3000 Watt heating element from a dryer. I hooked up some jumper leads to the turns a few times and was able to load some of my PSUs to about 100 Watts. My idea is to build one with that heating element that can do at least 500 Watts with forced air cooling. Unlike resistors that can burn out, NiCr wire can take a tough beating, even with passive cooling only.
              • dmill89
                • Dec 2011
                • 2534
                Nice!!!
                eBay a few years ago. It was part of a test kit Seasonic sold to PC shops/techs in the early 2000s. It has two modes (jumper controlled) 75W and 140W, not enough to really load a modern PSU much, but definitely better then the cheap testers that don't put any load at all on the PSU (aside from the tiny bit to run the LEDs/LCD).
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4970
                  • New Zealand
                  If the PSU tester had a manufacturing defect which say, shorted +12v to the PWR_GOOD output or something, then I could see a possibility for damage...
                  -David VanHorn
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Nope.
                    Supervisory chips are usually rated for -0.3 to Vcc as their operating voltage. With Vcc typically the 5VSB rail or the 12V rail (depending if the main PS is running or not), that makes it pretty much not possible to damage the supervisory chip on any of its inputs and outputs outputs.
                    Also, PG and PS_ON are typically in series with a resistor inside the PSU, so that alone will protect the supervisory in most cases.
                    Awesome!
                    Actually 75 Watts / 140 Watts is perfect for testing PSUs in just about every office rig / low-end PC. It's only the mid-range and high-end gaming PCs with dedicated video cards that will usually pull more power and thus require a bigger PSU. But even then, 140 Watts is more than enough to test a PSU.
                    This Seasonic tester is a brilliant idea. They should make more of these.
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
                      by sam_sam_sam
                      I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
                      One other check that...
                      08-03-2021, 06:41 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
