Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
    • Jul 2011
    • 6070
    I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
    One other check that I did on this switching power supply transformer was I took the ESR meter and checked the winding and the valves on the were very low resistance except for the winding that had good had higher resistance value
    One thing I noticed is that this switching power supply does not seem to have a switching power supply regulator which I found a little odd but it does have an optic sensor between the hot and cold side of the switching power supply
    This is the third or fourth time that this ring tester has come in very handy to troubleshoot a switching power supply issue with a blowed fuse on input power supply lines in
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4543
    • Italy - Milan
    Re: Used a Ring tester to troubleshoot a switching power supply that has a blowed fu
    U are in wrong section
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      After all of...
      07-13-2024, 08:14 PM
      DVR camera recorder switching power supply capacitor failure really
      These cheap non brand capacitors at it again
      Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
      Well at least I have the cameras back on line I to try the...
      01-22-2022, 06:28 PM
