UPS Powerware 9120 3000i Battery Disconected Error
  • Hrvoje-CRO
    • May 2017
    • Croatia
    Hello everyone!
    After the air blowing(cleaning), UPS reports an error "battery disconected" error. Cold start is not possible, ups tries to start but it fails. I measured the battery voltage and the voltage is about 110v. When plugged in mains, during powering up the display show's the message "battery disconected". What could be the cause of the problem?
    Thank you in advance!
  • petehall347
    • Jan 2015
    • 4440
    Re: UPS Powerware 9120 3000i Battery Disconected Error
    battery is likely disconnected then . check continuity and check the fuse .
      • 31247
      check the fuse with a meter - not your eyes.
      i had a 50A fuse fail with a hairline break in a ups.
      • Hrvoje-CRO
        • May 2017
        • Croatia
        Checked and there is no problem with fuses or battery packs. Also i measured voltage on the rear side of ups, the voltage is 111V.
          How many batteries are used in your UPS? Did you test each battery with dummy load connected to each battery when testing the battery's Voltage?
          BTW, DO you have any good clear pictures of what we are dealing with?
          • Hrvoje-CRO
            • May 2017
            • Croatia
            https://postimg.org/image/4zcyyu1th/
            https://s3.postimg.org/fr02njdlf/20170523_135316.jpg
            https://postimg.org/image/87s3iljah/
            https://postimg.org/image/e7ude6h5p/
            I tested each battery and there is no problem with the batteries. Ups has 2 battery banks with 4x of them in each pack.
            • AleXis6
              • Feb 2021
              • 69
              • Belarus
              what it was the fault reason?
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • drscoot
                HP X360 convertible battery blown fuse error, not charging
                by drscoot
                HP Modelnumber: 14-dh0061nb​
                This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                All these 3 batteries are charging...
                12-15-2023, 05:54 AM
              • ianbak
                Dell Vostro 3578 Battery Error
                by ianbak
                Please can anyone shed some light on why my Dell Vostro 3578 is giving the following BIOS error: 'The primary battery is not identifiable and this system will not charge this battery pack.'?
                The problem is not the battery - I've tried three different identical ones, all Dell OEM. They all work perfectly in other systems (different models, though) whilst giving the same error in the Vostro.
                The laptop will run happily from the battery if it is charged and Windows accurately reports the charge level, proving that the communication between the laptop and the battery...
                10-17-2025, 02:52 AM
              • mkdj
                by mkdj
                Mark and model: ASUS X571
                Tests already made:
                - I have removed...
                07-14-2025, 09:16 AM
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                09-14-2023, 11:10 PM
