Bench PS Problem (Volteq HY3010D)
  • orientalsniper
    • Apr 2013
    • 461
    Bought this bench power supply a few years ago, recently when I start it up, the output voltage is about 25V and I cannot knob it down to zero.
    How can I tell if it's a problem with the knobs? Or is it something else?
    • 31304
    Re: Bench PS Problem (Volteq HY3010D)
    probably has a shorted output transistor.
    • PeteS in CA
      • Aug 2005
      • 3586
      • USA, Unsure of Planet
      If the output transistor is a 2N3055 (very common) it's $2 or $3. It could also be a bad potentiometer.
      Open it up, clean out the dust, and post some pix!
      PeteS in CA
      • orientalsniper
        • Apr 2013
        • 461
        They seem to be 2N3055
        Here's the photos: http://imgur.com/a/r0P2z
        Forgive me, how do I test the transistors? Solder them out and test for resistance?
          • 31304
          yes, but you probably dont need to desolder them unless they meter bad to begin with.
          i'm impressed that it has 4, they can manage 7A or more each!
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            I suppose the problem is not actually current limit but dissipation limit. I think 4 is actually about right for a single stage series dissipative design with the specs of this psu...
            I know my homemade 1.2-15V 2A does exceed the power dissipation of the single series pass transistor... at least the heatsinking is not great. I've fried it a few times already :o However due to the circuit topology I'm not sure if any learnings from its failure can be applied to the OP's supply.
            • PeteS in CA
              • Aug 2005
              • 3586
              The 2N3055 is one of those ancient parts that is too good for the price for it to be obsoleted. I'd guess it was designed in the late 1960s.
              That 14-pin IC may be a uA723, another ancient part. the linear regulator IC. Basically, it has a precision reference, an error amplifier (with the output pin accessible for compensation purposes), and an output transistor that could be used to drive higher current transistors.
              If the output transistor leads are accessible, testing for shorts should be easy, though discerning which one would require removal. There may also be a high current rectifier across the transistors' CE, with the anode at the collector, and the cathode at the emitter. This would provide some protection to the transistors against a higher voltage being externally applied at the output. This could short instead of one of the output transistors shorting CE.
              Finding a schematic - dead-tree or online - could be valuable. I'm just working from memory of typical linear power supplies.
              PeteS in CA
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8716
                Perhaps while varying the adjustment pot, testing the voltage across it and voltage at the base of the transistor(s) would be some first order tests even without schematics.
                • R_J
                  • Jun 2012
                  • 9633
                  This is a different model (Hy3020)but might help, I found this one also (HY3010D)
                    • 31304
                    http://www.volteq.com/volteq-regulat...new-model.html
                    looks like a rebadge of:
                    http://www.mastechpowersupplies.com/...h-hy3010d.html
                    • orientalsniper
                      • Apr 2013
                      • 461
                      Thank you all for the assist, I'm gonna try all your suggestions and will let you know.
                      • orientalsniper
                        • Apr 2013
                        • 461
                        I tested the 4 2N3055 in circuit and they don't appear to be shorted. I'm gonna have to desolder them and do this test ( https://www.youtube.com/watch?v=xyKzUCrwTpA ) to make sure.
                        I attached better and more focused pictures (log in to see) so you get an idea of what's inside.
                          • 31304
                          shit, that's some scary foto's!
                          the cap almost? touching the heatsdink, the rectifier just bolted to the case without sleeving on the outputs, the soldering!
                          • orientalsniper
                            • Apr 2013
                            • 461
                            I just replaced the 4 power transistors (2N3055) and still got the same problem.
                              So you verify that the Output transistor driver V13, V14 are good?
                              • redwire
                                • Dec 2010
                                • 3912
                                It's the usual circuit, where the pass-transistor (array) is normally on (R4, V11) and the control op-amps turn it off through an OR-gate (V15,V16).
                                Like budm mentions, check the driver transistors. I would check the +12V, -6.2V rails.
                                Circuit-common for the control op-amps and stuff is the power supply's +OUTPUT, once you get a handle on that, these chinese bench PSU's are easier to repair.
                                But like this one, a potpourri or kludge of parts.
                                • orientalsniper
                                  • Apr 2013
                                  • 461
                                  OP rezzing thread, just replaced V14 and V13, still voltage high, 45V now.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8716
                                    Ah... problem still exists we thought you fixed or gave up!
                                    Well M1 and M2 (LM741s) are the error amplifiers - M1 being the voltage error amplifier (M2 is the current limit feedback). What is the voltage at each of the pins of M1 when you have the voltage turned down all of the way?
                                    In case it's not clear, M1 is the LM741 that has the unpopulated C8 near it and J7 on the other side. M2 is the one that's between C10 and RP9.
                                    Oh gosh 45V??? I think that will kill the LM741, you may need to replace them regardless now. But still report the voltages an the pins. A proper working PSU probably should look like:
                                    (Note: voltages reference to GND, or output negative pin)
                                    Pin 8 - NC - ignore
                                    Pin 7 - V+ 12V over what your output voltage is
                                    Pin 6 - OUT your output voltage minus somewhere from ~3 to ~11 volts.
                                    pin 5 - Offset - ignore
                                    pin 4 - V- 12V under what your output voltage is
                                    pin 3 - IN+ this should be fairly low, no more than 1V or so
                                    pin 2 - IN- this should be whatever your output voltage is
                                    pin 1 - Offset - ignore
                                    • orientalsniper
                                      • Apr 2013
                                      • 461
                                      Oh yeah, I just didn't need the PSU urgently and had things going on in life. I had the parts ordered months ago and just replaced them.
                                      You mean UA741CN? You want the voltage to ground? I can't seem find ground in this PCB.
                                      Edit: Just read your edit, I'm just going to order the UA741CN and LM324, will report back when I replace them.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8716
                                        Actually don't be hasty and replace them, we don't know what's wrong yet. If you report the voltages on those pins then we could help pinpoint the problem.
                                        I tried to make a guesstimate based on the schematic. I referenced "Ground" as the negative output of the main power supply, just to pick an arbitrary point.
                                        And yes, UA741CN, same op amp circuit as LM741.
                                        • ashan000
                                          yx-305d bench power supply decreasing voltage problem
                                          by ashan000
                                          This power supply is 30v 5amp. Problem is when turned on after about 3 minutes voltage starting to decrease slowly. (like - 5.8 > 5.7 > 5.6 > 5.5) can't see any damaged component or dry solder joints. Checked main 2 transistors with multimeter. Reading seems ok. Tried changing potentiometers(both coarse and fine) still the same situation. Can any one help me to troubleshoot? What voltages to check? Any ideas helps to fix this. thank you.!
                                          07-12-2025, 08:43 PM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • ClockChip
                                          Advice sought - Selector switch knob repair
                                          by ClockChip
                                          Hello Everyone,
                                          I am seeking to repair a knob on an old (circa 1971) Panasonic clock radio (a model RC-6900). The good news is that I have the small, easily lost knob. The bad news is that the knob has come off a slotted post and I need to re-attach it in such a way that I won't have to worry about it coming loose again.
                                          Here is a picture of the bare slotted post (if I have the term right) the knob should be attached to:
                                          As you can see, this is an Old School selector switch, which means it's pretty stiff. Put another way: the knob has to fit...
                                          07-20-2024, 04:52 PM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
