Bad Antec experience, need a new PSU :(
  • Oklahoma Wolf
    • Dec 2005
    • 353
    Re: Bad Antec experience, need a new PSU
    Originally posted by PCBONEZ
    Haven't run into Enhance's globby glue problem yet have ya...
    Frequently. I review PSU's for a living
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I know exactly who you are.
      Which is why I was surprised you use Enhance OEM.
      Mann-Made Global Warming.
      - Dr Seuss
      • Oklahoma Wolf
        • Dec 2005
        • 353
        I don't use them... I just find them a lot more acceptable for quality than most of the units out there. Seasonic's actually dropped quite a bit in my eyes lately now that I've seen an Antec Neo Blue 650W up close... I didn't think they were quite as cheaply made on the low end as that. Personally, I now actually have a higher opinion of FSP than those lower end Seasonics, and my view of FSP isn't real flattering right now either.
        Of my three rigs, the PSU's I'm running are OEM Delta, CWT, and Etasis. The one running the CWT is in an HTPC case... it's only in there because I can't think of anything else I have that would be much better for that particular case. It's a Glacialtech that runs the fan after power off. Caps in there are all OST IIRC... I've been keeping an eye on it to make sure it's still behaving itself. It also goes fanless below a certain temp, but that case has never been cool enough to see the fan stop.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Seasonic-Seasonic is one thing.
          Seasonic-OEM is another.
          I wouldn't be surprised if Antec SPECIFIES the units be built ultra cheap.
          Pondering if the Antec switching to FSP is because Seasonic told Antec to take a hike.
          HTPC
          Here's a suggestion for your occupational endeavors.
          How about a roundup of 400w+ uATX units.
          I haven't run across any I'd trust yet. (Either in person or reading reviews.)
          - Dr Seuss
          • Oklahoma Wolf
            • Dec 2005
            • 353
            I wouldn't be surprised either. Actually, I think they're starting to drop Seasonic now because if certain rumors are true, Delta's turning out to be a bit more demanding with minimum order quantities than what Antec's used to. In order to get them to do the Signature, they had to let Delta do a bunch of other units too, in other words.
            Fortunately, the Earthwatts 650W turned out to be a pretty decent unit anyway despite the drop in quality from the Sig.
            I'd love to do a few of the smaller form factors, actually. I've done a 1U unit for Claypower that did pretty well in terms of site hits, so there's definitely interest out there. Problem is, I can't afford to buy review samples and have to depend on what these companies are willing to send. That said, I do have a Seasonic 1U in the review pile I'm anxious to get to.
            Also have an Etasis built fanless unit coming up. That one may be replacing that CWT/Glacialtech I mentioned if I like it.
            • agraham
              • Jan 2009
              • 24
              #26
              I have an Antec Phantom 500 that I bought in mid 2005. Do you think it might be bad?
              I'm also not sure if it's actually big enough to run my system.
              I've been having stability problems with my computer lately. I assumed it was the ASUS A8R-MVP mobo because I borrowed a power supply from work and the computer still was not stable but now I'm wondering if the PS from work was also too small.
              Here's what ASUS had to say about PS:
              Power is another issue that can cause instability to occur, as there are numerous power supply manufa cturers on the market it is not viable anymore to just go by what the manufacturer claims the wattage to be as 400 watts to 1 company may be considered to be actually only 300 watts to another.With this being the case it is more feasable to recommend that you check the amperage for each of the voltage rails of the power supply you are purchasing by looking at the sticker on the side of the power supply.On the side of your power supply there will be a sticker that has the dc outputs for each of the 3 voltage rails supplying power to your motherboard, we recommend at least 28 amps on the +3.3 voltage rail which supplies power to your CPU and AGP slot, at least 35 amps on the +5 voltage rail which supplies power to all of the IC chips on your motherboard and a minimum of at least 18-20 amps on the +12 voltage rail which provides power to your drives and fans. these are just recomendations and may need to be adjusted depending on your set-up and the type of hardware you are usin g as certain newer cards ie: sound and video cards are needing more power than some of their older counterparts.
              Here's the stats off the side of the PS:
              +5V:30A +12V(1):17A +12V(2):18A +3.3V:30A -12V:0.5A +5Vsb:2.0A
              So it seems it's 5A short of what ASUS recommends for the 5V rail. Problem?
              • agraham
                • Jan 2009
                • 24
                #27
                ...think I have my answer...
                Looking in the grille at the back of the PS I see this:
                http://agraham.ca/shared/antec_phant...dcap_large.JPG
                I assume that's cap scum and not glue on that purple cap.
                So should I get this thing recapped and keep it or buy a new one with the recommended 35A 5V rail?
                Goddamn.. I spent $238 on this power supply because it got reviews and it's so fricken heavy and huge and annodized and silent I assumed it would be rock solid plus I thought Antec was a good name. Now I find out they're jokers after all. That's the last $238 they'll ever get from me.
                  master hoarder
                  • May 2008
                  • 12175
                  #28
                  Unless I'm missing something out, your mother board has PCI Express, not AGP correct? With that said, the above claims from Asus can be considered bs. Those numbers seem bloated (except the +12v since your CPU runs on that). Your PSU should be good enough for your computer.
                  Likely not.
                  I'm thinking your PSU is solid one, but it's probably that the damn Fuhjyyu caps inside that have vented. If the warranty has expired on it, open it and inspect. A recap will likely bring it back to life and I'm sure it will be much cheaper than a new PSU.
                  • agraham
                    • Jan 2009
                    • 24
                    #29
                    Antec needs to pick up the frackin phone! I've been filling out the RMA form on thier website every week since I made that post trying to get an RMA number - nothing.
                    I call thier RMA line during business hours - they don't pickup.
                    I leave a voice mail - they don't call back.
                    TopCat - tell your buddy at Antec that for every customer they pick up advertising on your site THEY ARE DRIVING ONE AWAY WITH THIS INFURIATING NONSENSE.
                    Low end caps in their high-end products? Won't even answer the phone or return a call for weeks on end? BULLCRAP!
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      I have seen your same scenario play itself out over and over online.
                      Antec actually pays people to troll forums and give the appearance they support their customers.
                      http://www.google.com/search?hl=en&q...earch&aq=f&oq=
                      But when it comes to actually following through ->> rarely happens.
                      There must be a hellacious profit in costing down an otherwise good PSU to total crap [and then charging extortionate prices] for Antec to bother with [or afford] doing that.
                      Seems to me Antec doesn't ACTUALLY give a gave a rats ass about the end user.
                      They just want people to THINK they do.
                      - Actions (and lack there of) speak louder than words Antec.
                      - Dr Seuss
                      • Logistics
                        • Apr 2007
                        • 721
                        What's all this about hating Antec, etc., etc., on a site about recapping? Just recap it and use it. I have recapped Antec supplies and had great success. GO!!!
                        • KeriJane
                          Mac Enthusiast
                          • Sep 2008
                          • 681
                          I
                          Wow!
                          That sounds EXACTLY like the company I work for!
                          Lemme check and see if Antec is maybe a subsidiary....
                          Keri
                          The More You Learn The Less You Know!
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I've had it out with "AntecRep" on 3 or 4 different sites now.
                            So, now any time AntecRep sees my handle show up he goes *POOF*.
                            - Dr Seuss
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              #34
                              i think he left here with his ass on fire.
                              pages of evidence that the units are trouble is hard to refute.
                              i should not bitch too loudly as i have several i got free and recapped.
                              its a relatively easy job so just do it rather than fuss with antec,antecrep(shill),ect.
                              what good is an rma if it will fail the same way soon.
                              • acstech
                                GrumpyModerator
                                • Jul 2007
                                • 1432
                                At least he made his identity known. There are a lot of companies that hire people to pose as standard users and improve the company image on internet forums.
                                This article, which I found google searching, seems to sum it up:
                                http://www.escapistmagazine.com/arti...62/363-Im-Evil
                                A man convinced against his will is of the same opinion still.
                                • Wizard
                                  • Mar 2008
                                  • 2296
                                  #36
                                  Belkin is been caught by paying reviewers to do painting rosy reviews of their products.
                                  Happened recently.
                                  Cheers, Wizard
                                  • agraham
                                    • Jan 2009
                                    • 24
                                    #37
                                    Well I called the customer support line instead of the RMA line. The guy says he replied to my web form I filled out weeks ago. Checked my spam folder - it's not there. I don't think he's lying to me tho so I guess Antec is not quite as bad as I said. It still doesn't excuse the RMA dept for not answering the phone or returning my voice mails tho. About two minutes after my conversation with the CSR the RMA dept finally returned my call. Not a coincidence I'm sure.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Trust me.
                                      Antec IS as bad as you said.
                                      Your only hope to get anything done is to make it public in places like right here.
                                      You are still better off recapping it yourself.
                                      You dunno what kind of craps will end up in an RMA replacement from Antec.
                                      - Dr Seuss
                                      • agraham
                                        • Jan 2009
                                        • 24
                                        #39
                                        Yeah... you're right of course. But I would need to get a proper soldering iron. The one I have works for speaker wire and plumbing but I don't think I would touch it to my computer. Then I have to learn how to electronic solder again. That last time I did was around 1989 when I was in grade 9 electronics class.
                                        ... and I need to actually get the replacement caps.
                                        At some point I do want to do it... but right now I want to put Antec to some expense for scamming me with this piece of crap in the first place.
                                        • tazwegion
                                          • Jun 2006
                                          • 444
                                          Geez... you leave for a while and find Antec getting clobbered when you get back, weren't they sponsoring OR advertising with this site at some stage?
                                          +1 they need to pull their socks up
                                          But in the meantime I'm still happy to collect pre-owned Antecs and recap them, that's how I obtained my best PSUs!
                                          FWIW I also recapped a new FSP too (to ensure reliability) and have had no complaints from the new owner as of yet, nice basic entry level PSU IMHO
                                          Viva LA Retro!
                                          • coinwizx
                                            Corsair HX1200 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                                            by coinwizx
                                            The power supply is 2020 Corsair HX1200 modular power supply.
                                            Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
                                            Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up....
                                            09-15-2025, 12:46 PM
                                          • coinwizx
                                            NZXT C850 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                                            by coinwizx
                                            The power supply is 2024 newest version of NZXT C850 modular power supply.
                                            Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then...
                                            09-15-2025, 12:44 PM
                                          • EasyG0ing1
                                            Anyone have experience with an RC driven temporary "ON" transistor switch?
                                            by EasyG0ing1
                                            The idea is to use a transistor to activate a latching relay once a voltage is applied but to prevent a constant voltage from being applied to the relay coil, I thought it might be a good idea if it were possible to make sure that the voltage applied to the coil is temporary even though the source voltage could be "ON" for long periods of time.
                                            This is the circuit that I came up with. I have not tested it yet because I don't have the relay yet, though I am looking for anyone who might have experience with this kind of a setup to hopefully offer some advice,...
                                            07-03-2024, 10:25 AM
                                          • 90Ninety
                                            Zotac RTX 3060 , another learning experience
                                            by 90Ninety
                                            Disclaimer Firstly I am by no means expert and this is still a learning experience , I buy broken stuff , with the intention to fix or learn something by failing.. I wanna break this into a few sections, please feel free to mention the section if replying , to assist me on getting a better understanding
                                            Part 1 , identifying Rails .. So for the record , I understand on NVIDIA cards there are several Rails. Along with their Supposed Voltages ( Voltage depends on age/ generation )
                                            Part 2. Blown / Missing component check .. I purchased this from the original...
                                            06-09-2024, 09:43 AM
                                          • sirpsychol
                                            Antec Earthwatts EA-380 smd element type/value
                                            by sirpsychol
                                            While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                            09-03-2023, 07:58 PM
