DC boost converter max power ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: DC boost converter max power ?
    any other idea for increasing current beside playing with inductor ? perhaps a transistor follower ?
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      #62
      At that frequency you will need 7392uH
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
      • bianchi77
        • Jun 2016
        • 1121
        which equation or calculator do you use ?
        • bianchi77
          • Jun 2016
          • 1121
          I put 700uH and the voltage drop to 24V
            Btw, are you trying to use the boost converter for your nixie project?
            http://www.dos4ever.com/flyback/flyback.html#ind1
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              #66
              i used https://learn.adafruit.com/diy-boost...the-calculator
              My pc
              • bianchi77
                • Jun 2016
                • 1121
                Probably I use a better inductor or change to flyback transformer to obtain a better power...
                • bianchi77
                  • Jun 2016
                  • 1121
                  No I don't have a nixie tube, but I change it to bulb, that's why I need more power, do you have an idea to increase the power beside changing the inductor to transformer ?
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    #69
                    easiest option is increase oscillator frequency.
                    My pc
                    • bianchi77
                      • Jun 2016
                      • 1121
                      then change the inductor ?
                      I've tried with higher frequency but voltage drop...
                      but I'll try again
                      for example from 15KHz and 33uH...
                        Well, you now have two calculators you can use for plugging the known parameters.
                          I think you should use single inductor instead of using two discrete inductors connected in series, I do not know what kind of effect when you use two discrete inductors, never seen any one using it in that manner.
                          • joshnz
                            • Feb 2011
                            • 969
                            • New Zealand
                            #73
                            9khz with 750uh or greater
                            or
                            10khz with 680uh or greater
                            or
                            15khz with 450uh or greater
                            as you can see inductor size and frequency go together also input voltage and output current
                            Also you will need a psu that can supply at least 20 watts to be sure the boost converter has enough power.
                            My pc
                            • bianchi77
                              • Jun 2016
                              • 1121
                              following this equation
                              what's x value ? is it 220/12 ?
                              • bianchi77
                                • Jun 2016
                                • 1121
                                or
                                or
                                so for 47uH probably 150KHz ?
                                • joshnz
                                  • Feb 2011
                                  • 969
                                  • New Zealand
                                  #76
                                  where did you get that from?
                                  My pc
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    I have one big 120uH 3A inductor...could be 45KHz, will match what I need ?
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      just a guess
                                      • joshnz
                                        • Feb 2011
                                        • 969
                                        • New Zealand
                                        #79
                                        yes
                                        My pc
                                        • joshnz
                                          • Feb 2011
                                          • 969
                                          • New Zealand
                                          #80
                                          in your drawing it shows output diode as 1N3822 is that correct?
                                          Your output diode will need to be fast switching type.
                                          My pc
