Could use some psu help
  • junktv
    • Nov 2010
    • 3065
    Have two psu's from around 04 with the ultra being used 24/7 until 2-3 years ago. Still works ok but as you can see has some bulging caps. The bestec has been 24/7 for about 2-3 years and no clue before that. The 5vsb on the bestec is iffy and needs to be warmed up before it will work and also has some bulged caps.
    I want to recap them but I am a noob at this and not sure what replacements I should get. Here is a list of the caps if you can help.
    Bestec atx-250-12z rev D
    Jamicon TK 2200uf 10v 5
    Jamicon TK 2200uf 16 1
    Jamicon TK 1000uf 16v 2
    Jamicon TK 10uf 50v 2
    Jamicon TK 220uf 35v 1
    Jamicon TK 2.2uf 50v 2
    Jamicon TK 0.1uf 63v 2
    Jamicon TK 0.47uf 50v 1
    Jamicon TK 22uf 50v 1
    Ultra ult-350p
    jee 2200uf 10v tall 1
    jee 2200uf 10v (says low esr) 2
    jee 2200uf 16v 1
    jee 470uf 10v 1
    jee 680uf 16v 4
    jun fu 1000uf 16v 1
    jee 1uf 50v 3
    jee 2.2uf 50v 1
    jee 10uf 50v 3
    don 22uf 50v 1
    Sorry for not making threads in the power supply section but I figured one thread may be better than 2 at the same time.
  • junktv
    • Nov 2010
    • 3065
    Re: Could use some psu help
    Well I found this from when ratdude did a 300 watt with ideas for the bestec. It's a different model but same type caps. www.badcaps.net/forum/showthread.php?t=36835
    Not sure on the ultra though. I know i'd like to order what i need for these a motherboard and a router this week though.
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      i used Nichicon PW series on my 500 watt. Seems to work just fine. I'm not an expert though. I thought the experts would have jumped in by now.
      sigpicThe Sky Is Falling
        • 31294
        the cap list is missing the diameters.
        having said that, it's always the same advice anyway.
        panasonic FR / FC / FK or the rubycon / nichicon / chemicon equivelents.
        • junktv
          • Nov 2010
          • 3065
          Fixed sized and forgot to list a couple on the ultra.
          10mm
          8mm
          4mm
          Ultra ult-350p
          12x26mm
          jee 2200uf 16v 1
          10x20mm
          jun fu 1000uf 16v 1
          8x18mm
          jee 470uf 10v 1
          jee 680uf 16v 4
          8x ~26mm
          5x12mm
          jee 1uf 50v 3
          jee 2.2uf 50v 1
          jee 10uf 50v 3
          don 22uf 50v 1
          4 d x 8mm h
          don RM .22uf 50v short 1
          5 d x 8mm h
          jee 10uf 50v short 1
          Stj, that is the problem i don't know the equivalents. Some of the other things you guys have helped me fix I had bought other caps and found out they were wrong even though it was the right microfarad and voltage.
          BTW the last number is how many are on the board.
            • 31294
            well in europe, panasonic is cheapest - so we use panasonic.
            i have a feeling, in the u.s. nichi / chemicon are cheaper - some u.s. based person needs to chime in on this.
            • Mint Waxed
              • Aug 2016
              • 35
              Ultra ult-350p
              jee 2200uf 16v 1
              jee 470uf 10v 1
              jee 680uf 16v 4
              jun fu 1000uf 16v 1
              jee 1uf 50v 3
              jee 2.2uf 50v 1
              jee 10uf 50v 3
              don 22uf 50v 1
              I would use a spreadsheet such as a free copy of Open Office Calc and make a new list with the following columns: Quantity, uF Value, Voltage, Diameter, Length, Lead Spacing, and Series. I typically use the Panasonic FR series available at MouserElectronics. Search aluminum electrolytic capacitors, leaded and then do the drill down.
                • 31294
                quicker to use the datasheet to get the part numbers.
                • junktv
                  • Nov 2010
                  • 3065
                  Ok I see in the data sheet that the FR like FM are low esr. This is ok to use in all of them? Since only one says low esr I didn't think the others would be.
                  Good idea on the spreadsheet. I planned on marking a picture or ms point of locations since I was going to pull them all to get spacing.
                    • 31294
                    you may want to look again at the diameters - 2200uf 26mm??????
                    • junktv
                      • Nov 2010
                      • 3065
                      It's right the jee 2200uf 16v is 12 diameter x 26mm long. Same with the 2200uf 10v but it is 8 x around 26mm long.
                      • junktv
                        • Nov 2010
                        • 3065
                        Can anyone explain why the they use 2 different 10uf 50v caps on the ultra? They are both jee but one is 8mm tall while the other is 12mm tall and both 5mm diameter.
                          • 31294
                          what are the series on them?
                          • junktv
                            • Nov 2010
                            • 3065
                            Your guess is as good as mine. Both say jee 10uf 50v and both have IM0518 on them. The only difference is height and the short one has a light blue stripe and the other 3 have a gold stripe.
                              • 31294
                              oh well, they have about 20 different types, but if they cant be assed to print the 2letter code on them then we wont know.
                              http://www.paullinebarger.net/DS/JEE/
                              still, a cap that's better than it needs to be, is better than a cap that's not good enough!
                              • junktv
                                • Nov 2010
                                • 3065
                                Atleast you found spec sheets I couldn't even find that.
                                Making a spreadsheet just have to look up part numbers and availability yet. So far panasonic seem similarly priced to ucc and nichicon from what i've looked at so far. Haven't done the lead spacing either.
                                Also found a couple 470uf 25v ZL caps i had left over and a 1000uf 16v MCZ but it's smaller than the ones in there now.
                                  • 31294
                                  you shouldnt use XLS format, it changes a bit with each release of the software.
                                  very useless infact - 90% of the time, it wont open properly for other people.
                                  • junktv
                                    • Nov 2010
                                    • 3065
                                    I use openoffice and libre on linux but that pc is one i need caps for. The defaults aren't on the list of being able to upload. Guess I could have zipped it. I think office is backwards compatible so used the excel 95. Wasn't sure what everyone would have so figured it would be the best.
                                    Opens fine when i downloaded it and tried.
                                      • 31294
                                      yes, this forum needs to sort that, i have to change extensions sometimes.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Here's a list of suitable PSU caps I often use:
                                        Manufacturer......................... Series
                                        Nichicon ................................ PW, PM, PS, PJ, PV, HE, HD, HW
                                        United Chemicon (UCC) ............ KY, KYA, KYB, KZE, LXV, LXY, LXZ, KZH, KZM
                                        Panasonic .............................. FC, FK, HFQ (old stock only), FR, FM
                                        Samxon ................................. RS
                                        Rubycon ................................ YXJ, YXG, ZL, ZLJ, ZLK
                                        • cap__
                                          Can I replace 15uf capacitor with 22uf?
                                          by cap__
                                          "If I wanted to replace an old 15uF/400V capacitor with a new one,
                                          I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
                                          11-29-2023, 11:16 AM
                                        • Cory Marqusee
                                          MacBook Air 820-3209-A Missing (3) AGX 22uF Decoupling Capacitors
                                          by Cory Marqusee
                                          Hi Everyone,
                                          I have a MacBook Air I've repaired, a mid-2012 13-inch 820-3209-A. It works. My only concern is that it is still missing (3) 22uF (0402 4V 20%) VAGX decoupling capacitors. Specifically, capacitors C1730, C1731, and C1732.
                                          How necessary are these capacitors? It has (11) 22uF to begin with; missing (3), my board now only has (8).
                                          I've been having difficulty sourcing new replacement capacitors without paying too much. Does anybody have any vendors state-side to recommend? Mouser charges parts + $8 shipping + $7 cutting fee (unless I buy an...
                                          09-15-2022, 02:03 PM
                                        • ajdrenter
                                          Picking caps for Antec SU-380
                                          by ajdrenter
                                          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                          https://www.badcaps.net/forum/showthread.php?t=14159
                                          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                          05-13-2023, 10:40 AM
                                        • iMic
                                          Vintage AT Power Supplies - Selecting Capacitors
                                          by iMic
                                          Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                          The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                          02-19-2023, 06:45 PM
                                        • Rugon
                                          Question about DR-8460BTX
                                          by Rugon
                                          Hi. I found this psu a DEER DR-8460BTX and I know it's a very low end power supply but I want recap it, obviously without spending too much because probably the capacitor cost more than PSU 🤣. inside of the PSU Inside the power supply has them all Yang chun caps:
                                          X2 200V 680uf
                                          X3 50V 2.2 uf LE
                                          X1 50V 22uf LE
                                          X2 50V 1uf LE
                                          X1 10V 1000uf LE
                                          X1 50V 47uf LE
                                          X1 50V 10uf LE
                                          X2 10V 2200uf LE
                                          X1 16V 2200uf
                                          X1 16V 470uf LE
                                          I had 2 questions about changing the capacitors though ... Does LE stand for low ERS?
                                          Can...
                                          11-06-2022, 12:55 PM
