Question about DR-8460BTX
  • Rugon
    • Nov 2022
    • 7
    • Italia
    Hi. I found this psu a DEER DR-8460BTX and I know it's a very low end power supply but I want recap it, obviously without spending too much because probably the capacitor cost more than PSU 🤣. inside of the PSU Inside the power supply has them all Yang chun caps:
    X2 200V 680uf
    X3 50V 2.2 uf LE
    X1 50V 22uf LE
    X2 50V 1uf LE
    X1 10V 1000uf LE
    X1 50V 47uf LE
    X1 50V 10uf LE
    X2 10V 2200uf LE
    X1 16V 2200uf
    X1 16V 470uf LE
    I had 2 questions about changing the capacitors though ... Does LE stand for low ERS?
    Can I put general caps (naturally of the same or better value) instead of low ERS capacitor? Thank you
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Question about DR-8460BTX
    1. If those blue ceramic caps in the bottom right of your pic are not safety agency approved caps, replace them.
    2. That main transformer, the heat sinks, and that output inductor are probably only good for 250-300W.
    3. Some Deer models are notorious for the 5VSB going out of regulation high and damaging MBs. If the standby regulator is not a power IC (e.g. a Power Integrations Tiny Switch) it may have that design issue.
    PeteS in CA
    • Rugon
      • Nov 2022
      • 7
      • Italia
      Thank you for your reply... And what about the caps? For you is low ESR or not? Thank you again
      • kotel studios
        DEER B350ATX PSU - tips on making it safer and "better"
        by kotel studios
        Since it looks like my excellent power PSU chances at living are now close to zero, I decided to give a shot at upgrading this DEER B350ATX PSU.
        At first glance it looks like, well.... a shitty cheaped out DEER garbage (cause it is). Although it does have an LF 1250CD00 filter transformer (at least I think that's what it is) 😆
        Tiny heatsinks, small transformators, single-pole ON/OFF switch. You name it.
        Now since this one works, I'd like to know how can I make it safer and better (besides burning it with napal 😃). My plan is to make the switch double-pole...
        03-04-2025, 12:09 PM
      • Rotsinger
        I replaced one Xbox 360 16v 1500uF Cap with 25v 2200uF what issues will it cause?
        by Rotsinger
        So the 16v 1500uF capacitor C9B1 near the power connector on the back of a Phat started leaking. Haven't been able to find the right cap, so I replaced it with a larger 25v 2200uF capacitor a couple weeks ago and everything is working fine since then. I didn't replace the other six 16v caps, they were all good.
        When putting the fan plastic cover back I remember there were maybe 2-3 mm of clearance on top of it and 1-2 mm of clearance to the side of it.
        For those that don't remember what the fan cover looks like I found this picture https://cdn.quade.co/wp-content/uploads/2...
        08-10-2021, 11:07 AM
      • cloppy007
        [MSI KT3 Ultra ARU] Advice on capacitor choice
        by cloppy007
        I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
        The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
        There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
        I think I recall hearing that I don't have to use the same capacitance for in series...
        08-21-2023, 03:18 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
      • ajdrenter
        Picking caps for Antec SU-380
        by ajdrenter
        In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
        https://www.badcaps.net/forum/showthread.php?t=14159
        It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
        05-13-2023, 10:40 AM
