opti ups 500 vs ii?
  • bianchi77
    • Jun 2016
    • 1121
    Re: opti ups 500 vs ii?
    Ok, I have no idea about that...looking for a battery for a test...
    • dmill89
      • Dec 2011
      • 2534
      A motorcycle battery (or other smaller engine, like a riding lawn mower, etc.) would be very similar to a UPS battery (but only for a test since most of these aren't sealed and will off-gas). A car battery could also work in a pinch for testing (but not long term, the capacity is much greater than a UPS battery, so running on it for a long time could overheat the UPS).
      • bianchi77
        • Jun 2016
        • 1121
        I have one old car battery 12V 70Ah....but I'm not sure, I think my wife has thrown it away...
        For a test only....see if we can see a charging voltage or not...or my primary side has a failure...since the fuse had blown.....I don't wanna replace the fuse yet....not sure if my primary side is ok or faulty....bulb test later on with new fuse....
        ....there is but....the fuse is connected , 0 ohm but it has a sign of burn inside so there's a possibility that my primary side is ok...
          • 31063
          That's good idea....diode on positive side ?
          positive charger-----anode-----cathode---plus battery---battery----negative battery----ground .....?
          NO
          if you put the diode that way, the battery will charge, but the ups will never see it!
          • bianchi77
            • Jun 2016
            • 1121
            then how can I put it ?
              • 31063
              anode towards the battery+
              cathode towards the charger+
              so the battery voltage flows towards the charger.
              so the striped end of the diode goes toward the charger.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #27
                just hook up whatever 12v battery you have.
                the problem only comes if you leave it in battery mode and it overheats due to no heatsinking.most of the cheap n nasty ones have a timer in the firmware to shut it down in a specified time.
                skip the diode.
                  Since you have blown MAIN fuse so why are you bothering trying to hook up the battery, why not try to find if there is shorted circuit in the unit first?
                  • bianchi77
                    • Jun 2016
                    • 1121
                    Started from primary ?
                    Any schematic for this device ?
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Here're the board photos
                      • bianchi77
                        • Jun 2016
                        • 1121
                        can it be tested without battery on it ?
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • mkdj
                          ASUS X571 no power : battery issue?
                          by mkdj
                          Mark and model: ASUS X571
                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                          Tests already made:
                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                          - I have removed...
                          07-14-2025, 09:16 AM
                        • techfreak9356
                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                          by techfreak9356
                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                          09-14-2023, 11:10 PM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
                        • ferah831208
                          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                          by ferah831208
                          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                          03-18-2025, 01:18 AM
