opti ups 500 vs ii?
  • bianchi77
    • Jun 2016
    • 1121
    opti ups 500 vs ii?
    Guys
    I got option ups not on at all while power up, battery voltage = 0.8V.
    Any ideas ?
    Thx
  • dmill89
    • Dec 2011
    • 2534
    Re: opti ups 500 vs ii?
    How old is the battery? If it is at 0.8v it is probably shoot, lead acid batteries don't handle deep discharges well. You can try to charge it with an SLA (sealed-lead acid) battery charger, but if it is that low odds are it won't take a charge, there is a possibility that you could connect it (in parallel) to another charged battery if you have one, but again 0.8v is extremely low and very unlikely to be recoverable.
    It looks like you will definitely need at least a new battery, the question then becomes how it got so low. Was it sitting unpowered for a long time? If not they battery may be completely (or nearly completely) dry or shorted, or there may be a problem with the charging circuitry of the UPS.
    • bianchi77
      • Jun 2016
      • 1121
      I have no idea how old the battery is....if there's no battery it will not do anything ?
      I can't see even LED is on ??
        Remove the black and red cables to the batteries then plug the unit into the AC outlet, then check the DCV between the black and red cables that were attached to the battery to see if has any charging Voltage, the Voltage should be there as long as the AC cord is plugged into the AC outlet.
        There should be date code on the battery also.
        • bianchi77
          • Jun 2016
          • 1121
          Ok, I will see if there's a charging voltage...but why there's no LED at all ?
            Those LEDs may not be on unless the batteries are good and no problem with the unit, you need to look at the owner manual. Most UPS will have the charging circuit running the minute you plug the UPS into the outlet without even turning on the UPS.
            http://www.opti-ups.com.tw:8080/User%20manual/
            • dmill89
              • Dec 2011
              • 2534
              ^This, My Opti-UPS ES1000C won't start up at all with no or dead batteries. It came with Yuasa batteries (which are theoretically good quality) but they only lasted a little over two years, the cheap (~$20 for the pair) Chinese batteries I replaced them with have lasted nearly 4 years so far.
              • bianchi77
                • Jun 2016
                • 1121
                Voltage at battery = 0.7V....no charging no LED...
                Looks like there's some kind of short on high voltage side...
                I can see the fuse partially burn...it's still connected but I reckon some FETs and diodes,transistors are faulty inside...I haven't checked yet but I can see the fuse like this in the photo..
                  Is that the main AC fuse at the IEC AC inlet? You definitely has shorted component in the unit.
                    • 31161
                    bastards, that fuse should be ceramic!
                    more penny saving.
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Yes it is, I've opened it this noon...but strangely it's not completely blown...
                      abit risky.....what do you reckon it's shorted ?
                        • 31161
                        it's blown, or it's not blown.
                        i'v seen ups fuses fail gently from the stress of charging old battery's
                        your battery is done btw.
                        • bianchi77
                          • Jun 2016
                          • 1121
                          Ok, so it's slowly blown....is it possible if I try charging my battery ? 1.09V now...looks like very bad...rating 12V 7.2Ah...
                            • 31161
                            the ups probably wants to see atleast 7v before it will try to charge that battery.
                            *maybe* you could trick it wih a 9v battery and a diode to stop the 9v battery being "charged"
                              The charger in those kind of the units is not smart charger, it should be running with output Voltage the minute you plug the UPS into the outlet.
                              We need good clear pictures of the inside the unit.
                              12V LSA with no load Voltage reading of 0.8V I do not think you can bring it back to life with good capacity.
                              • dmill89
                                • Dec 2011
                                • 2534
                                ^This, the battery is shoot. Not sure about Aus., but in the us 12V 7.2Ah SLA batteries can be had for around $15 including shipping.
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  Probably I can use one of my used laptop battery to test, it's charging or not ?
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    That's good idea....diode on positive side ?
                                    positive charger-----anode-----cathode---plus battery---battery----negative battery----ground .....?
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      Not a problem, I'll take picture of it later on....component side ? track side ?
                                      • dmill89
                                        • Dec 2011
                                        • 2534
                                        Do you like fires/explosions? If not hooking up a Li-Ion battery to a charger designed for an SLA battery is a very bad idea.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • ferah831208
                                          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                          by ferah831208
                                          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                          03-18-2025, 01:18 AM
