12V rail is not on ?
    Re: 12V rail is not on ?
    Less than 100 Ohms in BOTH direction, the really bad one will be <1 Ohm in both direction.
    Bottom line, it should only show conduction in ONE direction only.
    To truely test the diode you need to use variable power supply with current limiter to test the diode break down Voltage since your meter does not put out high enough Voltage that is supply by the circuit to cause the diode to breakdown and conduct when reverse bias is applied to the diode. The test will also show the leakage current.
    https://cdn.badcaps-static.com/pdfs/...95e0f81994.pdf
    • bianchi77
      • Jun 2016
      • 1121
      the resistance for both diodes, forward = 1K ohm and reverse is blinking between 8K and OL....it's not normal...should be OL in contant for reverse...right ?
        Sounds like you are not making good contact in reverse, if you do get 8K then it's bad, and if you check with the 9V and 100 Ohms resistor in reverse, does it show 9V across in reverse bias, it should if it is good diode.
        At this point why do you not just change the diodes?
        BTW, your hands are not making contact with the probes or the diode legs, right?
        • bianchi77
          • Jun 2016
          • 1121
          This is the small test that I had done...please correct me if I'm wrong...
          That's for forward bias....how about reverse bias ? swap the probe minus to plus and plus to minus with DMM in diode test ?
          • bianchi77
            • Jun 2016
            • 1121
            How can I do that ? do you have a schematic ? cheers
              This is the small that I had done...please correct me if I'm wrong...
              All you have to do is to flip the diode around then you will see that the DCV across the diode will be at 9V.
              • bianchi77
                • Jun 2016
                • 1121
                Measuring with diode test on dmm or voltage test?
                  Well, lest see now, you are trying to read the Voltage drop across the diode that is hooked up the power source in reverse bias, so what do you think?
                  I hope you never ever try to measure any resistance or in Diode mode while the power is still applied to the circuit unless you have lots of money to replace damaged meter, you should know by now on how and when to use meter in Ohm mode, Diode mode, Amp mode.
                  This thread is getting really long and you do not seems to know the basic of the term Voltage drops across the DUT means, it is really basic electronics terminology that you should know by now when some one ask you to check the Voltage drops on the DUT, at the same time you are trying to troubleshoot the complex circuit.
                  You need to go by some book for electronics for beginner and study them. It is hard to teach some one that does not have basic knowledge yet, and my patience is running low right now from just trying to explain simple diode testing.
                  • bianchi77
                    • Jun 2016
                    • 1121
                    So I will use it on voltage mode when I measure it with battery ( power source )...
                    I keep learning...
                    cheers
                    • bianchi77
                      • Jun 2016
                      • 1121
                      I never use ohm or diode test when there is battery...
                      • bianchi77
                        • Jun 2016
                        • 1121
                        Here's the observation I've done...do you reckon the diode is faulty ?
                        • bianchi77
                          • Jun 2016
                          • 1121
                          Rforward =825 ohm, Rreverse = 167K
                          Vforward = 252mV
                          Vreverse = 4.7V
                          Diode = SBL2040CT
                          R = 41.2 ohm
                          Vbattery = 5.72V
                          I want to replace this diode for a long time, not arrived until today, ordered since July..
                          • bianchi77
                            • Jun 2016
                            • 1121
                            What happened if the 5V or 12V diode sunk to the ground ....
                            I reckon the diode will get over current....how much current will it be in that 5V and 12V loop ?
                            I gave a surge current for those SBL1040....but I have no idea how much ?
                            Is it related with Maximum rating in datasheet :
                            Peak repetitive reverse surge current per diode at tp = 2.0 μs, 1 kHz == IRRM == 1.0 A
                            It will die instanly if the limit is only 1 A
                              Vforward = 252mV
                              Vreverse = 4.7V
                              Diode = SBL2040CT
                              R = 41.2 ohm
                              Vbattery = 5.72V
                              V drops on the diode should be the same as the supply Voltage because the diode will not conducting due to reverse bias.
                              • bianchi77
                                • Jun 2016
                                • 1121
                                are you talking about V drops = V reverse ? so the diode has a leak in this case...1V leak...and getting higher if I have higher voltage and amperage from transformer....
                                  Just think of the diode as an open switch when it connected in reverse bias, the reading will be the same as the power supply source, if the diode is truly not conducting any current.
                                  Diode connected in forward bias mode will conduct and let current flow, diode connected in reverse bias mode will not let the current flow through, it is that simple! so when there is no current flowing through the diode, what do think the Vdrops on that diode will be when it is not conducting?
                                  Just remove the diode complexly and take the reading between the two wires that were connect to the diode to see what Voltage you will get, that is what it should be when the diode is connected back to the two wires in reverse bias.
                                  Vdrops is the Voltage reading between the two legs of the device, it does not matter if it is a resistor or a diode. it is just a Voltage reading between the two legs of the device.
                                  Just do the search of the word 'Voltage drop'.
                                  You should search he web for 'what is diode' and study it.
                                  If you want to know what the leakage current through your diode in the reverse bias test, all you have to do is to measure the Vdrops on that resistor connect in series with the diode then you can calculate the leakage current. You can also look at the spec sheet of the diode to find out what the leakage current spec of that diode is.
                                  I waste enough time with this simple test, sorry. You are skipping the basic that is why you are not understand the test result.
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    Ok thanks for the time....sorry if I'm wasting your time....I keep learning
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      it looks simple and basic but it's not that simple and it's not completely basic...
                                        Well if you know what diode is then it will be simple to see that diode will only conduct in one direction only, and if you understand the current flow in the circuit then you will know what Voltage you will read between the two legs of the diode when the it is not conducting., same way how you find out when you have 10 lamps connected in series, what Voltage will you see on the lamp that has open filament?
                                        BTW, it is also easy enough for to put GOOD diode in your test setup and see what Vdrops you will get in the forward and in reverse bias, it is that simple! Do it and tell us the result.
                                        Right now it is not simple to you because you do not understand the simple current flow in the circuit so you are wondering why the LED lights up when you test those diodes in the power supply.
                                        Post 56:
                                        I test D22,D20,D17,D18 in circuit with 9V and LED,1K ohm....something is not normal...
                                        It's on a both side of test reverse and forward bias...
                                        Are they all bad ?
                                        or to be sure must be off circuit ?
                                        PCB code Y-B200 ATX Ver 2.6...and they are on 12V and 5V rail...
                                        • bianchi77
                                          • Jun 2016
                                          • 1121
                                          what Voltage will you see on the lamp that has open filament? = source voltage
                                          source---probe--open filament--probe--lamp x 9------ground
                                          voltage at open filament = source
                                          am I right ?
                                          • Victor Moreira Silva
                                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                            by Victor Moreira Silva
                                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                            Well, my decice specs are the following:
                                            Model: Acer Nitro 5 AN517-54-55T5
                                            CPU: Intel Core i5-11400H
                                            GPU: NVIDIA GeForce GTX 1650
                                            Motherboard: GH51G LA-L181P Rev:1c
                                            The symptom:
                                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                            05-26-2025, 10:49 AM
                                          • nyar2
                                            ASUS G513Q short on 1.8 and 0.75v rail
                                            by nyar2
                                            I have this laptop that initially had a short on VBAT
                                            I found that the short was coming from U60600, a DC/DC converter responsible for 1.8v. There was also a shorted cap on pin 13, the LDO for the chip.
                                            Removing these has cleared the short on VBAT. But 1.8v and 0.75v rail read 0.1 OHMS.
                                            I have read another article here that said that this typically indicates a failed cpu.
                                            Is there any way to confirm? I was borrowing a thermal cam and now don't have one to see what heats up on that rail. I feel like I may be wasting my...
                                            11-26-2025, 10:51 PM
                                          • grimacelord
                                            Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                            by grimacelord
                                            Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                            After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                            I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                            10-24-2024, 12:31 PM
                                          • nagkiller
                                            Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                                            by nagkiller
                                            Hello everyone!
                                            This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                                            After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                                            Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                                            The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                                            I would like some...
                                            05-10-2025, 09:19 AM
                                          • joshAU
                                            Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                                            by joshAU
                                            Hi all.
                                            This notebook was showing no signs of life.
                                            I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                                            However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                                            If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                                            I tried replacing the MOSFET with a new one, but again no voltage on the...
                                            05-29-2024, 12:33 AM
