Gaming laptop Clevo NH79EP with short on 5VS-rail
  • techrepairheide
    • May 2024
    • 15
    • SH
    first of all I want to apologize for my bad English, but I try to give my best.
    Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
    For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic".
    I dissembled the motherboard and removed all connectors and pressed the power button. Under the thermal camera, I could see that the dual-channel load switch with part number U67 (its an EM5290) was getting hot and had make the noises in the same interval. So I measured on power controller TPS51275B-1RUKR that I only got VDD3 with 3.3V on coil and 3VS, but no VDD5 for 5V on coil and no 5VS. The voltage will increase but is getting stopped by a dead short on 5VS-rail. Because of that, I removed the EM5290 to isolate the short and the wonderful thing is, without it, the laptop is getting power and boot up completely (so I think it can´t be a big problem) but the fans aren´t spinning so the laptop is overheating and is shutting off after a while.
    Now I have a few questions:
    - After removing the EM5290 I still don´t get VDD5 with 5V on coil PL20 until I press the power button. Then the voltage will show up and is holding the 5V. Is it normal? I think yes, because on last page of service manual there is a boot-sequence which is showing 5V (but not VDD5) after pwr_btn.
    - I try to inject voltage on PIN 13/14 and 8/9 of EM5290 on motherboard and on other components for 5VS but only the point where I inject the voltage is heating up. The voltage is draining down and current goes straight to max (resistance is zero). How can I find the faulty component with this conditions?
    - I replaced EM5290 already with new one at first, because i hoped maybe its a low resistance rail.
    - There a some bypass capacitors and mosfets/transistors which are connected with ground. I already removed a few components and put it back. Does someone have an idea which components in a case like this are often failure? I don´t want to remove more components blind.
    - Is it correct that 5VS (I think it means standby and is the same like always on) is here only on mDP, HDMI, audio codec, fans and rgb keyboard? Because the laptop will boot without 5VS so important components can´t be bad.
    If someone need more informations or needs the schematic to help me, feel free to ask.
    Thanks in advance!
  • reformatt
    • Feb 2020
    • 1506
    5VS is switched, not standby. Looking at the schematic, most likely suspects for me is either C1208 or U46/U47. Use voltage injection and IPA on those components to see if you get a reaction when voltage is applied. Not many things on that switched rail.
    Yes 5V only enabled after the power button is pressed.
    • techrepairheide
      • May 2024
      • 15
      • SH
      I found the faulty component. The capacitor "C646" of the RGB-lights for the keyboard was shorted to ground. After I removed it, got 500+- ohms and short has gone. Put EM5290 back and laptop starts working fine again.
      Thanks!
      • keldeo
        Obscure Pentium laptop, sudden short?
        by keldeo
        I've purchased this weird (and might add appears to have had a fairly rough life) laptop a while ago for $1 at a yard sale. It powered up one time, (saw a POST screen!) Then, never powered again. I've since thrown it in some dark corner, BUT, I've decided to look at it again. First, this seems like a very obscure laptop, mine just has the name "BIT" on it and nothing else. Very similar (same?) can be seen here https://www.vogons.org/viewtopic.php?t=54655.
        At first, I had gotten the weird mini display on the lower part of the laptop to display a few icons, but if I attempted...
        01-02-2025, 03:22 AM
        Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
        This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
        09-06-2024, 09:30 PM
        Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
        This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 08:47 AM
      • playit
        laptop 19v short circuit dell vostro 1400 motherboard ,need help in repair .
        by playit
        the comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
        02-25-2025, 08:15 AM
        Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
        This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-07-2024, 06:11 AM
