12V rail is not on ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    Does anyone know why my 12V rail is not on ?
    5V standby is on....
    The power supply is LC 300ATX, does anyone have the schematic ?
    I suspect my 12V rail is short, because of short on my capacitor on motherboard..
    it's using to diodes soldered together into heatsink...is it FR302 ?
    I saw :
    http://danyk.cz/s_atx05a.png
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8354
    Re: 12V rail is not on ?
    5VSB is always on. I am guessing that is the only thing that is powered up. No -12V, no +12V, no -5V,no +5V neither the +3.3V. To turn the rest of the PSU on, take a 1k resistor and jump 5VSB to PSon.
    Other than that, check that D8 isn't shorted, T4 has continuity between pin 5 and 6, L6 isn't open, and that C26 isn't shorted to GND.
    • bianchi77
      • Jun 2016
      • 1121
      D8 is bad...from my diode test 0v
      • bianchi77
        • Jun 2016
        • 1121
        L6 is ok
        • bianchi77
          • Jun 2016
          • 1121
          Can t find C26? Is the schematic the same between 250w n 300w
          • bianchi77
            • Jun 2016
            • 1121
            Got it..small 22nF near the chip..is that Pwm switching chip?
            • bianchi77
              • Jun 2016
              • 1121
              I tried common an ps_on..no response only can hear high pitch noise...
              • fzabkar
                • Mar 2009
                • 772
                If there is a short between 12V and Ground, then isolate the relevant components on the secondary side until the short goes away.
                • bianchi77
                  • Jun 2016
                  • 1121
                  How?
                  • fzabkar
                    • Mar 2009
                    • 772
                    CapLeaker has already identified the components that are likely culprits.
                    In any case you appear to have already found the problem -- shorted D8. After removing D8, test for shorts across the 12V output again. Also confirm that D8 tests shorted out-of-circuit. There should be an electrolytic capacitor filtering the 12V output. Test it also.
                    Edit:
                    Here is the circuit diagram for an LC-B250ATX.
                    "LC-B250ATX ch. Y-B200-ATX ver. 2.9 JNC Computer Co.""
                    https://cdn.badcaps-static.com/pdfs/...83951b6882.pdf
                    Some time ago I had a fake 400W PSU which was actually a 200W version of the above circuit:
                    http://www.electronicspoint.com/thre...atabase.132952
                    • bianchi77
                      • Jun 2016
                      • 1121
                      C27? Is it possible I break other rails?
                      • fzabkar
                        • Mar 2009
                        • 772
                        Don't switch the PSU on after removing components. Just test them for shorts without powering on.
                        • bianchi77
                          • Jun 2016
                          • 1121
                          Diode in the middle is connected to 12V rail...
                          and I measure with diode 0.1V both side from the base...
                          and the left and right diode SBL1040..
                          I got only 0.4V left and right from the base...
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Are they all faulty ? I measure from new diodes 0.6V
                            • bianchi77
                              • Jun 2016
                              • 1121
                              Some photos :
                              • bianchi77
                                • Jun 2016
                                • 1121
                                Looks like it's different from the schematic, since it's not D8...
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  Almost the same with :
                                  I can see diode label is match...
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8354
                                    Umm... that link isn't showing.
                                    With your DMM set to diode mode, probe the left and right pins of the diode to the middle pin. If there is a short, the diode is bad. easy.
                                    The SBL1040 is a 40V, 10A Schottky rectifier that has a voltage drop of 0.6V. Problem is that it is only a diode with 2 legs, it should be one with 3 legs.
                                    Maybe you can upload nice straight shot, high resolution pictures here to badcaps, using the attachment feature.
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      Which link ?
                                      • bianchi77
                                        • Jun 2016
                                        • 1121
                                        can I replace with :
                                        http://www.aliexpress.com/item/Free-...6-a85bf6bb2cc6
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • nyar2
                                          ASUS G513Q short on 1.8 and 0.75v rail
                                          by nyar2
                                          I have this laptop that initially had a short on VBAT
                                          I found that the short was coming from U60600, a DC/DC converter responsible for 1.8v. There was also a shorted cap on pin 13, the LDO for the chip.
                                          Removing these has cleared the short on VBAT. But 1.8v and 0.75v rail read 0.1 OHMS.
                                          I have read another article here that said that this typically indicates a failed cpu.
                                          Is there any way to confirm? I was borrowing a thermal cam and now don't have one to see what heats up on that rail. I feel like I may be wasting my...
                                          11-26-2025, 10:51 PM
                                        • grimacelord
                                          Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                          by grimacelord
                                          Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                          After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                          I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                          10-24-2024, 12:31 PM
                                        • nagkiller
                                          Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                                          by nagkiller
                                          Hello everyone!
                                          This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                                          After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                                          Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                                          The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                                          I would like some...
                                          05-10-2025, 09:19 AM
                                        • joshAU
                                          Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                                          by joshAU
                                          Hi all.
                                          This notebook was showing no signs of life.
                                          I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                                          However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                                          If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                                          I tried replacing the MOSFET with a new one, but again no voltage on the...
                                          05-29-2024, 12:33 AM
