Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
  • grimacelord
    • Jan 2017
    • 402
    Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
    After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
    I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox again and found that my newly replaced Q9F1 had blown again. So this time, I used another donor board and replaced Q9F1, Q9F2, and U9F1 which both of the MOSFETs are connected to. I checked to make sure the short on the 12V rail was gone and it was until I connected the Xbox back to power and it blew Q9F1 again.
    What keeps blowing Q9F1? Looks like Pin 5 of Q9F1 is connected to L9F2 which is V_VREG_12P0_MEM_NBCORE and the other side of that inductor is the 12V line coming from the power supply (according to my interpretation of page 50 of the schematic), could the power supply be blowing it?
    Hoping someone could help. Thank you.
  • grimacelord
    • Jan 2017
    • 402
    Well, I decided to test my own theory and use a brand new power supply in case something was weird with the original and even using a new power supply, Q9F1 blew as soon as I connected it to power, so it's not the power supply causing it. Still not sure what to check...
    • grimacelord
      • Jan 2017
      • 402
      Attached two screenshots from the relevant schematic page.
      • grimacelord
        • Jan 2017
        • 402
        Hoping somebody can see what I am working with here because I am really not sure what I need to check for.
        • grimacelord
          • Jan 2017
          • 402
          Upon further probing, I have found a short on Pin 1 of C9F1 which is V_VTTB. I am reading 0.013V in diode mode and a working Xbox has a diode reading of 0.305V.
          The only components on that entire V_VTTB line is a whole bunch of resistors and a few capacitors. I removed ALL of the capacitors on that line and it's still shorted to ground. What does that mean? Internal short?
          • essuman32
            • Jul 2023
            • Ghana
            Xbox
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • nyar2
              ASUS G513Q short on 1.8 and 0.75v rail
              by nyar2
              I have this laptop that initially had a short on VBAT
              I found that the short was coming from U60600, a DC/DC converter responsible for 1.8v. There was also a shorted cap on pin 13, the LDO for the chip.
              Removing these has cleared the short on VBAT. But 1.8v and 0.75v rail read 0.1 OHMS.
              I have read another article here that said that this typically indicates a failed cpu.
              Is there any way to confirm? I was borrowing a thermal cam and now don't have one to see what heats up on that rail. I feel like I may be wasting my...
              11-26-2025, 10:51 PM
            • nagkiller
              Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
              by nagkiller
              Hello everyone!
              This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
              After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
              Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
              The attached boardview file is very similar to this grafic card, which I am basing the repair on.
              I would like some...
              05-10-2025, 09:19 AM
            • joshAU
              Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
              by joshAU
              Hi all.
              This notebook was showing no signs of life.
              I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
              However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
              If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
              I tried replacing the MOSFET with a new one, but again no voltage on the...
              05-29-2024, 12:33 AM
            • techrepairheide
              Gaming laptop Clevo NH79EP with short on 5VS-rail
              by techrepairheide
              first of all I want to apologize for my bad English, but I try to give my best.
              Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
              For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
              10-13-2024, 02:49 PM
