Whistling PSU
  • Tom41
    • Oct 2005
    • 336
    • England
    Whistling PSU
    You may remember I posted some time ago about the Kobian Mercury PSU failing due to bad caps. I replaced it with a new PSU, a dual-fan unit. Looking through the vents, I saw it was packed with Teapos.
    Now, the PSU has started making a 'whistling' noise both when powered up and on standby. The noise appears to be coming from the PSU itself, and if I flip the isolator switch the whistle drops in pitch and then stops.
    I've had another look through the vents and can't see any sign of caps bulging or venting. I wonder if the Teapos have failed without physical signs, like they're notorious for doing?
    Note: The PC is still stable; no sign of random reboots or memory errors yet.
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • shadow
    • Feb 2007
    • 732
    Re: Whistling PSU
    I have heard that some caps can whistle, however it is much more common with inductors.
    Vibration is the cause of whistling and most of the time glue is put over the inductors and some capacitors to stop the vibration.
    Chances are that it is nothing to be worried about, if you want to eliminate it, you can add some more glue to the component that is producing the whistling noise.
    • i4004
      • Oct 2006
      • 2029
      Re: Whistling PSU
      caps don't whistle...as shadow said look for shaky inductors and trafos...if it bothers you.
      • Fizzycapola
        • Oct 2006
        • 423
        Re: Whistling PSU
        Loose labeling can become like a speaker too. I read Corsair PSU tech support people returning PSU because of noise, Corsair stuck the label back down for them. Mine also had a shaky label, but I used paper glue instead of returning it, hope warranty wasn't invalidated.
        Edit: though the fault was a buzzing noise, not a whistle.
        Rubycon Rubycon Rubycon
        • Tom41
          • Oct 2005
          • 336
          • England
          Re: Whistling PSU
          I just opened up the PSU and had a look, now that I know it's out of warranty. Three of the Teapo caps on the output side have bulged, and one has exuded a tiny amount of electrolyte.
          Looks like I caught it just in time - while the system was still stable, the PSU may have smoked at any time and taken the whole PC with it! Now got a new PSU, how long will that last?
          Edit: Oddly, this PSU doesn't seem to have any kind of PFC, either mounted to the case or on the main board!
          I might take some pics of this PSU and post them in the Build Quality Pictorial thread when I get time.
          • zandrax
            Hit and miss
            • Dec 2007
            • 1157
            • Italy
            Re: Whistling PSU
            @ Tom: I saw your previous psu in the "Pictorial build" thread: it's empty.
            No filter caps, no X and Y caps, skinny heatsinks, likely overrated components: bad caps are the last of your problems, it is unsafe (and I think outlaw too) because it has no protections for your hardware and yourself. I hope your new one is decent.
            Don't even try to repair it unless you have some used caps you want to throw into: it's junk.
            Zandrax
            Have an happy life.
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              Re: Whistling PSU
              The only thing I ever had that made strange noises was a cheap audio power booster. It was a burnt out trashcan item that a friend fixed up for me. A bunch of resistor had fried in it. Since he had no spec sheet for it he made a best guess on the values to replace them with. It kicked butt when he was done but with a small problem. What ever music was playing you could hear that same music eminating from the case of the Power booster too...LOL My guess is that the iron core inductors in it were acting like little speakers.
              Mark Twain
              John Paul Jones
              Rod Serling
              • tony359
                by tony359
                11-28-2023, 05:18 AM
              • MegaZAC
                Onkyo TX-SR805 noise in one channel
                by MegaZAC
                Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                There's some logic behind it. As soon as I select an input I get only left...
                04-23-2025, 10:09 PM
              • courtcircuit
                Philips HTS8000 home cinema noise problem
                by courtcircuit
                Hello
                I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                Removed each of tyhe boards
                02-08-2025, 08:22 AM
              • mgjini
                any help with this please 820-3332-a whistling noise on U7000 when i connect either b
                by mgjini
                Hi all, i was wondering if anyone can help me resolve this issue with this macbook, it is 820-3332-a
                if i connect the battery to this board while power is connected to the power supply i get a whistling noise buy u7000, if i keep battery connected and reconnect power supply i still have whistling noise by u7000, if i remove power supply from board and battery still connected whistling dissapears, if i keep power supply connected and disconnect battery whistling goes
                i have replaced u7000 chip 3 times as i have got donor boards for the same model, L7030 gets warm...
                02-22-2019, 03:05 PM
              • karatzdi
                Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                by karatzdi
                I know some might say... just buy another one. Sell it as parts..!
                So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                Spent some time downloading the Service...
                06-11-2024, 08:38 AM
